Question about Ridgid 15682 300 Complete Threader
Ridgid model 700 threader the 2 indch die is not threading right even after changing the cutters . The cutters appear to be to small of a diameter to fit the pipe O.D. yes I definitly have them in ri
I have tryed different pipes and three different cutter sets.
3 Suggested Answers
Healeyman
  • 1198 Answers
SOURCE: Threads are all chewed up and broken in places
First look carefully at your die, is one of the cutters out of place? I hope you have been using plenty of cutting oil, not lube oil. Lube oil will ruin cutters. If your cutters have chips out of the cutting edge, they won't work. Don't try to thread stainless steel. Only use a die that has a guide section on it to keep the die true to the pipe.
Posted on May 07, 2009
  • 1575 Answers
SOURCE: ridgid 300 pipe cutter owners manual
Could this be the manual?
http://www.jms-planthire.co.uk/media/pdf/1215_300_Compact-1233-300_535.pdf
Ken.
Posted on Jan 14, 2012
Needle threader on 830 operates but will not let go of thread
1. Try a high quality thread; usually embroidery. Your thread sounds like Walmart. Look at it at a light and see if there is fuzz. That's bad thread.
If this doesn't work you have a threader that is bent out of shape causing it to hang on. You can attempt to adjust the threader with small pair of needle nose pliers, maybe even tweezers. Careful, it is fragile. The cost of replacement and a repairman will be over $ 50 so it is worth the try at home.
Oct 05, 2016 | Sewing Machines
Fix thread cutter on singer quantum xl 100
Is it blunt? Is it angled properly . these and needle threaders are a pain in the neck, I just use scissors and thread my own needles.
Best wishes
Jan 24, 2015 | Singer Sewing Machines
Auto threader won't thread needle
Damaged needle is the most common cause of this, followed by a needle too small for the threader (see: http://www.picturetrail.com/sfx/album/view/17206792 for a size comparison) or a needle not in the correct position for threading, or the threading getting knocked out of alignment.
Personally, and maybe because I've been sewing for 55 years now, but I find most needle threaders seem to be the first thing to break on modern home sewing machines. If you want to thread by hand, simply cut the end of the thread at an angle with a *sharp* pair of scissors. It should poke through the hole easily. Because needle size and thread size really go hand in hand in making good stitches, a thread that is too fat for the needle's eye a) won't go through the eye easily and b) will make your machine stitch like it's suddenly had all the tensions go wonky. (Thread diameter should be about half the width of the eye of the needle; ordinary sewing thread generally works from size 10/70 through 14/90 needles just fine, and occasionally to 16/100.)
May 11, 2014 | Brother LB6800PRW Mechanical Sewing...
Ridgid 700 trips gfci
you have a wire that touch to the housing of the tool
or
the windings of the motor, a brush holder have a default isolation
this type of circuit breaker is disconnected when it detects a curent flowing through the ground
Nov 17, 2012 | Ridgid 41935 700 Power Drive 115v Threader
Have rigid 535 pipe cutter with new cutting blades but threads are not coming out right. it is almost like the threader is tearing the threads instead of cutting them. everything is clean and have new...
I have seen this a couple times when the die begins to slide out as your threading it will turn enough to rip the threads just keep steady pressure on the wheel so the die cannot slide out if this is the case the other reason is normally because the dies were not installed properly take notice to the fact they are numbered
Mar 22, 2011 | Model 535 Replacement Parts 45220...
May 06, 2009 | Ridgid 15682 300 Complete Threader
Singer Inspiration 4228 Automatic Threading Problems
The small hook that passes through the eye of the needle is bent or broken. If it is only bent it can be straightened with a small screw driver. If it is broken it will need to be replaced. Most dealers can get this part for you for about $5.00
sewman7
Apr 11, 2009 | Singer Sewing Machines
Show me how to use the auto threader
Thread the machine to the point where the thread is in the needle bar thread guide. With you left hand hold the upper thread towards you. With your right hand pull down on the threader unit and twist it so the tiny hook goes through the eye of the needle and hold it there. Now take the thread that you are holding in your left hand and pass it to the rear of the machine under the small guides on the threader hook. Release the threader mechanism and the thread and the tiny hook should pull a small loop through the eye. Pull on this small loop (which will be on the right side) all the way through the eye.
Viola!
good luck!
Jan 31, 2009 | Juki TL-98Q
Ridgid 15682 300 Complete Threader  Logo
32 people viewed this question
Top Ridgid Tools & Hardware - Others Experts
R Daniel Wolfe
 perry tradesman    ...
perry tradesman ...
Level 1 Expert
Are you a Ridgid Tool and Hardware - Other Expert? Answer questions, earn points and help others
