Question about Intel Motherboard
Chipset pm400 ce 8327
Audio comes up grey what do i do?
    Scholar:
  • 89 Answers
Really need more description--What's the actual m/b? Usually easiest way to figure out the drivers.
Most likely it means you need to install the audio drivers.
Posted on Oct 28, 2008
What software need for programming motorola pm400
The PM400 utilizes the RVN4191 software package. This is a proprietary Motorola software which is available by subscription to Motorola dealers and qualifying entities. You would also need the cable and radio interface box (RIB).
Best regards.
May 07, 2014 | Motorola AXU4100 (10 Channels) 2-Way Radio
Couldn't find audio driver for IBM thinkcentre MT-M 8327-77G for windows 7
That because this system came XP. You will need to run drivers on compatibility mode if possible.
Oct 09, 2012 | IBM ThinkCentre 8172 Intel Desktop PC -...
Bios volume control is locked
Hello
It could not be controllable
Apr 13, 2012 | ASUS K50IJ-C1 Notebook
Can i install need for speed mostwanted in windows ce 6.0
Unfortunately, you cannot install it on Windows CE as it doesn't support DirectX 9 and only Direct3D Mobile.System requirements
Microsoft Windows
Nov 17, 2011 | Computers & Internet
Need motherboard manual for soyo k7v dragon plus
SY-K7V DRAGON Plus! - SOYO
AMD Socket-A Based VIA KT266A Chipset ATX Motherboard
AMD Recommended Motherboard
D: DDR266 SDRAM
R: Promise IDE-RAID (0,1)
A: CMedia 8738 6-channel hardware audio on board
G: Universal AGP Pro slot
O: Overclocking, set up FSB by 1MHz increment
N: 10/100 Mbps Ethernet by ICS PHY Controller
Specifications
Processor
Click here for maximum CPU support
Click here for maximum Front Side Bus (FSB) support
Interface
Socket "A"(462)
Chipset Type
VIA KT266A
Chipset Description
VIA KT266A / 8233 CE Version Chipset
Supports 200/266 MHz FSB
Form Factor
ATX
Memory Type
DDR SDRAM
Memory Description
Three DDR 2.5V DIMM sockets support up to 3GB*.
184-pin PC2100/PC1600 non-ECC, unbuffered DDR SDRAM memory.
*recommended to use 3 sticks of DDR200(PC1600), or 2 DDR266(PC2100) memory on this board.
Expansion Slots
Five 32-bit Bus Mastering PCI slots (V2.2 compliant)
One Universal AGP Pro slot (supports 1x/2x/4x modes)
Expansion Slot Types
IDE Type
UDMA 33/66/100
IDE Description
Four independent channels for 8 IDE devices (2 for RAID)
Supports up to PIO mode 5 & Ultra DMA 33/66/100
Two PCI bus mastering ATA E-IDE ports
Audio Description
On board CMI 8738 audio chip providing 6-channel audio solution
IO Port Description
Two RS-232 serial ports (16550 UART compatible)
One parallel printer port (SPP/EPP/ECP mode)
One FDD port (supports 3 modes, 1.2/1.44/2.88MB FDD)
Provides IrDA with optional cable for transceiver
Provides 6 USB ports (2* rear, 4*front)
IO Connection Description
PS/2 Mini-DIN mouse & keyboard ports
Two USB ports
One RJ45 connector
Two D-Sub 9-pin male serial ports
One D-Sub 25-pin female printer port
Audio I/O: LINE-OUT x 1, LINE-IN x 1, MIC JACK x 1
One game port
BIOS Description
Award PCI BIOS with ACPI function
Supports multiple-boot from E-IDE / SCSI / CD-ROM / FDD / LS120 / ZIP
2 Mbyte Flash ROM
Health Monitoring Description
On board voltage monitors for CPU Vcore, +3.3, +5V & +12V
CPU fan speed monitor
CPU temperature monitoring through flexible thermal sensor
Dimension Description
Four layers, 30.5 cm x 23 cm (12" x 9.05")
ATX form factor
Certification
FCC Class B & CE EMI Regulation CompliantPC99 Compliant
Compatibilities
WinXP / Win2000 / WinNT / WinME / Win98SE / Linux / FreeBSD
Warranty
All SOYO products are designed to offer stability and flexibility, and are tested to ensure highest reliability. We offer a 1 year limited warranty on this SOYO product.
CPU Support
Compatibility
RAM Memory Support
Compatibility
Manufacturer - downloads drivers, manuals and BIOS : SOYO
Prodejce v èR : Mo?nost vlo?ení odkazu prodejce - info zde
Recenze : Odkazy na recenze vlo?íme po dohodì
Problems, experience, griffs.....:
Jun 06, 2010 | Computers & Internet
Starview codes for chorus cork 4th March 2009
00=CE 19 2E 87 80 61 74 90
01=62 FA D9 F3 CE 05 FA 79
should work
Mar 04, 2009 | StarTech.com StarView SV211K 2-port KVM...
I cant play a movie full screen on my hp laptop.. it goes black and grey everytime. what should i do =[
I think you need to update the graphics driver. It might be downloadable from the laptop or chipset manufacturer's support website. For example, if your chipset is made by intel, please go to intel.com/support/chipsets then select the chipset family. Choose the specific chipset then click on "download" under graphics. After this, please select the operating system...hope this helps.Please let me know. Thank you.
Sep 30, 2008 | HP Computers & Internet
No sound for my dell inspiron 5000 notebook
Download everesthome
Install and run the program.
click on motherboard tab on left
click on chipset
click on southbridge in right column
the southbridge is the id of the audio chip set
the audio controller will be listed
google the chipset driver or audio controller driver.
Mar 30, 2008 | Dell Inspiron 5000 Notebook
Exact chipset
VIA® K8M800-CE Chipset
You can download the drivers at
http://www.msicomputer.com/product/p_spec.asp?model=K8MM-V
Mar 04, 2008 | MSI K8MM-V Motherboard
Intel Motherboard Logo
116 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
