Question about Dryers
Kitchen aid dryer
I have a kitchenaid dryer model kgye665bwho the igniter glows but the gas valve won't open to allow for ignition,,,i have tested things but am stumped,can you please help.
thank you,Mike
  • 5,911 Answers
The following link explains a little theory about glow bar type igniters:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
Now...I know the link explains how to replace an igniter in a gas range. The theory of operation and the types of igniters are the same, however. Just because your igniter glows, does not mean it is good. Igniters become weak through frequent use and age. Over a period of time, the igniter will not draw the necessary current to open the gas valve. An igniter does not have to be that far out of tolerence on some model burner assemblies to cause a no ignition problem. If you have tested the igniter and it is within the tolerances prescribed in the link I provided for you, I would recommend replacing the gas valve solenoids. There are two of them. If you go to replairclinic.com and type in the model number you provided, the solenoids will be listed as item number 3479. The igniter is listed as item 3415. The parts are not that expensive and are simple to replace. I'm not stating that these components are bad, but these are the more common fail items on a burner assembly and it would be a recommended place for you start. I hope this helps you. Let me know if you have further questions.
Posted on Oct 26, 2008
Samsung Gas Dryer model DV328AGW/XAA, not getting gas to ignighter,
Could be a defective igniter, thermocouple, or gas valve
Mar 06, 2017 | Samsung Dryers
Oven,broiler won't light
The igniter is the most commonly defective part for a gas oven that won't turn on. The igniter has two main functions. First, the igniter draws electrical current through the oven safety valve to open it. Second, the igniter gets hot enough to glow and ignite the gas in the burner assembly. If the igniter gets weak, it will fail to open the safety valve correctly. If the valve does not open, the oven will not heat. To determine if the igniter is defective, observe the igniter when the oven is on. If the igniter glows for more than 90 seconds without igniting the gas flame, this indicates that the igniter is too weak to open the valve. If the igniter is weak, replace it. If the igniter does not glow at all, use a multimeter to test the igniter for continuity. If the igniter does not have continuity, replace it.
Kenmore Oven Won Turn on
Jan 20, 2016 | Kenmore Kitchen Ranges
Oven and broiler won't work surface burners ok
Troubleshooting Why Your Gas Oven Won Ignite or Heat PartSelect com
I bought whirlpool gas range Mod WFG231LVSO last year, the flame is too small, how can I fix that? Thanks
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Jan 06, 2011 | KitchenAid KGST307 Gas Kitchen Range
Kenmore gas range model 790 oven won't light "glow plug igniter not coming on there is continuity through thermostat "valve"
Dec 18, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Both oven glow bars stay lit oven takes very long time to heat up and is 25 degrees off from true temp using a oven thermometer. takes over an hour to reach 450 and has a gas smell when unit turned on. any...
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. Sometimes the igniter glows but still does not reach the correct amp draw to fully open the gas valve. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Dec 11, 2010 | Viking VGIC305-4B Gas Kitchen Range
I have a Sears Kenmore lp gas rangemodel# 362.75491991. The stove top works great, the broiler works great, but the oven will not light or very intermediately. The glow bar comes on perfect nut the gas...
The problem is usually the igniter(glow bar) not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Dec 08, 2010 | Kenmore Kitchen Ranges
Although the termal coupling will glow, our oven burner won't ignite.
On this range it is called a glowbar style igniter.
Nov 18, 2010 | Frigidaire FGF326AS Gas Kitchen Range
Bake oven does not light. Igniter glows for many minutes but no gas to oven. When I wrapped gas valve with hammer it lights!! When oven burner goes out when reached desired temp, it will not relight...
The igniter needs to draw between 3.6 and 4 amps to open the gas valve even thogh it is glowing the resistance may not be the same . Check the amperage and then replace igniter
Dec 14, 2009 | KitchenAid KGRT607 Gas Kitchen Range
Dryers Logo
89 people viewed this question
Top Dryers Experts
