Question about Hitachi CP-X270 Multimedia Projector
Hitachi CP-X270 Hi, im trying to hook up my projector to my toshiba laptop (satellite pro L10) and it keeps bringing up the same message: No Input is Detected on RGB/ S-Video & Video i have tried following the instruction set out in one of your postings but cannot seem to find the function key (FN key perhaps?) or the fact that the key doesnt work i believe i have done as your instructions have said but i am having trouble ''verifying that simultaneous viewing has been enabled'' Cheers
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 124 Answers
FN is function. Try another configuration.
Posted on May 30, 2017
simplemitch
  • 752 Answers
SOURCE: No input detected on projector
it sounds like the A/V reciever does not upconvert the component signal to HDMI. Not many do. The Marantz recievers will (SR6001, SR8001, etc..). Also bear in mind that HDMI cables are finicky and may require amplification over a few meters long.
Posted on Dec 04, 2007
Marrie
  • 563 Answers
SOURCE: Hitachi CP R555 Multimedia LCD Projector
Hi there
In your Menu options there is a subfolder where it either reads lamp or lamp timer.
Scroll down to it and hold down you right or left arrow key on the Projector for a couple of seconds.
Posted on Mar 26, 2008
Marrie
  • 563 Answers
SOURCE: Presentation mode is off...
Hi there
You cannot hook up a PC & Projector with just a USB cable , you have to use a VGA cable for signal ( picture )
The USB cable is just to use the scroll up or down function from the standard remote controll when doing a presentation.
Posted on Apr 15, 2008
SOURCE: Resetting the air filter timer
If you do not have a remote here is how to reset the filter time. Use the "Menu" bottun to get the "easy menu" to display. Push the down arrow until you get to "Filter Time," then push and hold the RIGHT arrow to reset the filter time. DO NOT try to reset using the "Reset" option on the easy menu, it will not work.
Posted on Oct 02, 2008
Hiya there, just worked out how to reset the filter timer so for those that need to know here's the solution;
Bring up the menu and go right the way down to "Option" where it shows you the lamp and filter hours.
Next highlight/select the filter timer section and while its on there hold the RESET button on the remote for 5 seconds.. this then pops up with a resert option and hey, 0h again, good as new! :-)
Oh and if you dont have a remote, just hold the right arrow button instead for 5 seconds in place of the reset and follow instructions as above!
Hope this helps.
Regards,
Omar.
Posted on May 07, 2009
I replaced the lamp, but am unable to reset the lamp so that the projector works again. It keeps giving me the message that I need to replace lamp and reset timer. And then it turns off.
1. Switch power ON, and press the TIMER button on the remote controller, or the RESET button
on the control panel, for approximately three seconds. The 'LAMP xxxx hr' message will appear
on the lamp timer on the bottom of the screen.
2. Press the MENU button on the remote controller, or the RESET button on the control panel,
while the lamp timer is displayed. The 'LAMP xxxx ? 0 CANCEL' message will then
appear.
3. Press the and select 0, and wait until the timer display is cleared.
Feb 18, 2011 | Hitachi CP-X270 Multimedia Projector
I have a Hitachi LCD projector model No. CP-RX70. When I connect with my laptop (Compaque) and start both then only starting window XP message appears through projector and laptop works normally but again...
The setup is not correct. Check the requirements of the projector, (size, refresh rates etc.) and set the laptop up accordingly.
You will se the XP Screen because the laptop hasn't loaded any drivers yet and the screen is low resolution.
Hope that helps.
Dec 06, 2010 | Hitachi Performa CP-RS55 Multimedia...
Toshiba Satellite Pro L10 - Fan does not work!
Take out fan from CPU. test it using external power Batt 5v. if its works, its could be your motherboard going to spoilt soon..
Oct 27, 2009 | Toshiba Satellite L10 Notebook
DISPLAY DRIVER FOR TOSHIBA SATELLITE L10
Hi there.
There are many variations of the Satellite L10, most of them come with XP, but in most machines the the graphics are Intel 852GM.
Thanks for using FixYa!!
Mar 23, 2009 | Toshiba Satellite L10 Notebook
Hi there
Apr 14, 2008 | Hitachi CP-X260W Multimedia Projector
Toshiba projector
Change it to clone the display. It is probably set to extend your desktop not to clone.
Nov 12, 2007 | Hitachi CP-X270 Multimedia Projector
LCD Toshiba TLP s10
You probably have the input set to component video (Y/Pb/Pr) which will distort the colors
Oct 23, 2007 | Hitachi CP-X270 Multimedia Projector
Toshiba TLP S10 Projector
http://www.toshiba.de/projektoren/resources/pdf/manual_s10e.pdf That link will take you to the owner's manual. It should answer whatever questions you have.
Aug 28, 2007 | Hitachi CP-X270 Multimedia Projector
Hitachi CP-X270 Multimedia Projector Logo
48 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
