Question about Singer 132QRFB Mechanical Sewing Machine
Singer 4411 needle, bobbin alignment
Need relation between needle position and metal bobbin holder so i can have the belt timed correctly
SOURCE: Singer 7442 - Needle hitting bottom
FIRST DETERMIN NEEDLE BAR POSITION TURN STITCH REGULATOR TO LARGEST STITCH, THEN TURN HAND WHEEL TIL' NEEDLE IS ABOUT TO ENTER NEEDLE PLATE.
AT THIS POINT THE FEED DOGS SHOULD BE JUST AT OR JUST UNDER PLATE. IF SO NEEDLE BAR IS, IN CORRECT POSITION,AND TIMING WILL BE SET AT THE HOOK.
TO SET TIME REMOVE NEEDLE PLATE TURN HAND WHEEL SO NEEDLE IS IN LOWEST POSITION. USING A SMALL RULE RAISE NEEDLE BAR 3/32 OF AN INCH ( OR 3 MM FOR A METRIC RULE) .HOOK POINT SHOULD BE IN CENTER OF NEEDLES WIDTH. LOOSEN THE 2 SHAFT SCREWS
SLIGHTLY,TURN HOOK TIL CENTER OF NEEDLE. TIGHTEN SCREWS. IF NEEDLE BAR IS OUT OF TIME. BRING HOOK TO CENTER OF NEEDLE AND LOOSEN SCREW IN LEFT COVER. RAISE OR LOWER NEEDLE BAR TO SET 3/32OF AN INCH. THE 3/32 MUST BE VERY VERY CLOSE.
Posted on Dec 19, 2007
  • 323 Answers
SOURCE: Singer-Inspiration 4220/4228
Send this machine back where it came from! machine. You have described a timing problem which you can not and should not need to do.
Change the needle first and test it to be sure the needle still hits on the hook. If it does,follow the above instructions. If it no longer hits then it's possible it is not as serious as I first thought.I'm not sure if the bobbin keeps coming out or the bobbin case(the plastic part the bobbin sits in) comes out.If it is just the bobbin, insert the bobbin in the case and pull on the thread. The bobbin should turn COUNTERCLOCKWISE. If it turns the other way, turn it upside down and try it again.
If it is the bobbincase,then Remove the needle plate and take the bobbin case completely out. On this machine there is a small lever which holds the bobbin case in position. Looking down on the bobbin case the lever is located at about 11 o'clock and has a small slot in it. It is also probably spring loaded which means it is not easy to turn without a small screwdriver. Insert the screwdriver in the slot and turn it to the left. Lift out the bobbin case and Carefully examine it for any nicks, scratches or rough spots. If you find any, they will need to be removed with an emery stick and or a sharpening stone. Buff with a very fine steel wool for total smoothness.
To replace the bobbin case use the screwdriver to open and hold the lever open while you insert the case back in. The straight part of the case will be on the right and you need to place the case so that the circular part rides on the slight grove in the hook.(The metal thing it sits on). Once you have it in place you can release the lever you've been holding open . It should fit over the edge of the bobbin case and not allow it to come out. Rethread the machine and turn it by hand a few times to see that it is working properly. Good luck!!!
sewman7
Posted on Jul 01, 2008
SOURCE: singer 5817c
Hi, actually I can help with your problem but maybe you can help me with mine. A friend gave me the same model...without the instructions. Would you be willing to give me a pdf scan or photocopy of the manual, please? Let me know at arielle.bkshlf@gmail.com. Thanks!
Posted on Jul 19, 2008
SOURCE: Bobbin won't p/u thread Singer 478
i have no idea how to thread this machine ?
Posted on Aug 16, 2008
  • 4 Answers
SOURCE: singer quantum sewing machine won't pick up bobbin thread
Try changing your needle
Posted on Dec 13, 2008
How to wind bobbin on model 4411
Do you mean the Singer 4411 Heavy Duty sewing machine? If so,
first place the spool on the spool pin with an appropriate sized spool holder, if you are starting the project. Snap the thread into the thread guide to the left of the of the spool pin. Wrap the thread clockwise around the bobbin winder tension discs (slightly to the left and forward of the thread guide). Bring thread towards the bobbin spindle. Thread the bobbin (put the thread through the hole in the bobbin). Place the bobbin on the spindle with the hole up. Move the bobbin spindle to the right. Hold onto the thread above the bobbin and step on the foot control pedal. When the bobbin finishes winding the thread, cut the thread at the top of the bobbin and the incoming thread from the spool. Move the bobbin spindle to the left and remove the bobbin. If you have already threaded the machine for sewing, you will need to remove it from the various guides and tension discs that are used in sewing. Then after winding the bobbin, re-thread the top thread.
The directions to wind the bobbin are in the manual on page 12 (page 19 of the PDF). You can find many Singer manuals at the Singer support page: https://www.singer.com/support . The 4411 support page is https://www.singer.com/search/support?lp=support&title=4411 . The current link to the manual is https://www.singer.com/sites/default/files/product_manual/SINGER%204411%20Heavy%20Duty%20Sewing%20Machine.pdf .
I hope this helps.
Apr 30, 2018 | Sewing Machines
The hand wheel does not move. removed the needle, still not working
sounds like you have thread bunched up in the bobbin case. take out the entire bobbin plus the bobbin holder and clean it. it is worth a try....
May 20, 2016 | Singer 4411 Heavy Duty Sewing Machine
How to remove the bobbin case on singer 4411 sewing machine. Thread is accumulated under the bobbin case and the case is sin wrong position.
Hai, I think your machine time is changing. So you can't remove the bobbin case. Please go to mechanic shop. First time you look and see. Next time you can try.
Apr 01, 2014 | Singer 4411 Sewing Machine
I 've been using this 2639 Singer since 2006. It was working perfect until one day the bobbin case popped up away from the shuttle causing the needle to be blocked from moving. So, I removed the p
First change that needle. It's likely bent. A bent needle won't create a stitch.
Then double check your timing. It sounds like you have it ******** a bit... But that's hard to determine from a description. Before you start the timing process, make sure that your needle bar is in the correct position. (typically the upper timing mark on the needle bar is just below the lower needle bar guide when the needle is at its very lowest point) If necessary loosen the needle bar holder and make a correction. Once the needle bar is positioned correctly... then move on to the shuttle/needle timing.
Nov 03, 2012 | Singer Sewing Machines
How to thread a bobbin on singer 4411 sewing machine
If you've threaded the bobbin per instructions... then make sure your needle isn't damaged, bent, or dull. Also make sure the needle is seated fully and correctly oriented into the needle bar.
Aug 24, 2012 | Singer Sewing Machines
Bobbin won't spin to allow needle to catch thread
sometimes when you break a needle it can cause the machine to
jump time, the machine would have to be taken to a sewing machine
shop to be checked by the technican
Aug 17, 2012 | Singer Inspiration 4210 Mechanical Sewing...
The bobbin holder turns so the needle hits the holder and breaks.
Out of alignment means the timing is off...take it to a pro to have it cleaned and re-timed...if that's the real problem.
However, it seems that you think the issue is may be a bobbin holder that wasn't installed properly??
Do you have a top, side, or front loading bobbin?
Sorry...I don't understand: "If I manually turn the bobbin and holder clockwise just as the needle comes down, it goes all the way down without breaking or bending."
Do you mean that you're turning the hand wheel towards yourself...and that works properly? If so, it's probably not a timing issue.
If you have a metal bobbin case that you insert a wound bobbin into and then place that bobbin holder w/bobbin into your machine...perhaps the bobbin case just needs a slight turn in order to snap into place.
If that's not it, check your machine's manual to see what part might be missing...then, to find that small, shiny metal part, try shining a flashlight across the area where it was lost.
Apr 06, 2017 | Brother XL-2230 Mechanical Sewing Machine
Singer Model 5050 Timing Problem
Actually,timing of needle vs, shuttle is not very easy job several factor you should check on.There is belt ot sometime a shafting with worm gear and helical gear under machine w/c drive the shuttle with the bobbins in timing order,Any one of them is present on the timing adjustment can be done by releasing the belt or the helical gear,besure machine is unplug then set all mechanism on low dead center meaning the needle move to utmost lower position catching this by the shuttle and bobbins at center position.No motion applied if this was set up,engage the belt with pulley and the bobbins link holder tigh allenscrew besure the needle is lower dead center at the center of shullle bobbins catching needle without motion when setting back at original position.If this was made manually move it on handwheel going up and side down the needle gradually if the needle move freely several time and it was catching this by the shuttle hook bobbins.if ok put thread bobbins and upper thread dial tension with the needle.Move machine on handwheel try to catch the bobbins thread,If this so your machine is ready to sew again if problem occurs on alignment repeat adjustment on perpect alignment,besure all parts on upper casing of machine specially two drive gear are in normal alignment.
Mar 15, 2009 | Singer 5050 Mechanical Sewing Machine
Needle hits the bobbin holder and doesn't grab the bobbin thread
Check you have the right size bobbin case the gap where the needle enters should be 13mm approx at the widest point. A lot of other pfaff bobbin cases seem to fit and can be easily be mistaken. I have two pfaffs and have accidentally mixed the cases and had a similar problem.
Mar 04, 2009 | PfaFF Creative 7570
I need to thread an elna air electronic su sewing machine
that's a nice machine, one of the last mechanical Elnas with the discs for extra stitches. Firstly, you need to wind a bobbin, always use Elna swiss metal bobbins, with holes on one side only, slightly dished. Put on top of the bobbin spindle and take the thread from your spool on the spool holders at the back of the machine across to the tension disc on top left, its white bump, thread through the tension then back to the bobbin and pull the tail through a hole in the top of the bobbin. Flick bobbin across to the right against the stop, disengage the clutch by holding the outer flywheel and turning the inner towards you. Now press the foot pedal to start winding a bobbin, holding the thread tail so it starts off. Wind one full coverage of the bobbin so that the starting point is covered, then stop and cut the tail off with scissors. Now continue winding at 3/4 speed until bobbin is full, watch as it winds and give the thread a nudge with your finger so it fills top and bottom as well as in the middle of the bobbin. When it is full, the bobbin spindle will stop winding. Move it to the left, cut the thread and reennage the clutch by holding flywheel and turning the inner the other way. Now install the bobbin and click the thread into the tension device, see image.
Now thread up the top thread by taking the top thread from the spool, through the tension discs, across to the eyelet on top, down to the check spring, back up to the take up lever, then down to the needle catching the thread into the two thread guides enroute.
See this image.
Now thread through the needle front to back, hold the top thread, close the bobbin cover leaving the tail sticking out the top, lower the needle down by turning the flywheel towards you through one cycle and pull the top thread, drawing the bobbin thread up to the top of the needle plate with it. Pull both threads under the pressure foot to the back and your ready to go. Remember, top tension should be on 5 and bottom tension should be on the red 1, don't change it. Brush out the bobbin holder assembly each time you use this machine and add one drop of oil into the middle of the bobbin holder, there may be a red dot or just the indenation. Run the machine for 30 seconds after oiling without thread, slowly to spread the oil through the bobbin mechanism. Standard 130/704H needles, change regularly (6 hours of sewing) and pick right sized needle and type point for the work you are sewing. Good luck with your SU. If you wanted to join, there is a Yahoo group called "Elna Heirlooms" for fellow Swiss Elna owners.
Aug 24, 2008 | Singer 7462 Mechanical Sewing Machine
Singer 132QRFB Mechanical Sewing Machine Logo
139 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
