Question about Garmin Forerunner 205 GPS Receiver
Garmin forerunner 205 will not stay OFF and none of the buttons respond.
If I turn it off using the off button it immediately turns itself on again, starts locating satelites then goes to the normal timing page, yet it won't start timing or do anything else when any of the buttons are pressed. It seems to be charging ok and connects and transfers date to the Garmin Training Centre. I've tried the soft reset but it immediately switches itself on and back to non responsive mode. If i try the hard reset and have to lose oall my date can I put it back on the Garmin from the info stored on the Training Centre software?
Yes you can restore your data from the TC after a hard reset. You have to go thtrough the setup menu like chose which language etc first.
Well I have exactly the same problem as you and a hard reset did not work either ...
Upgrading / downgrading the firmware also did not work.... the thing keeps on switching itself on regardless....
Do you have found out something more in the mean time?
Posted on Jul 23, 2012
SOURCE: Forerunner 205 won't sync with computer to download history
This guy had a fix. Don't know yet if it works. Basically, get latest software....
http://www.fixya.com/support/t235113-computer_problem_communicating
Posted on Aug 30, 2008
SOURCE: Training Centre switches itself off when I connect Garmin to PC
Well,
without any logical thinking behind, I decided to try to download the new version of the Training Centre.
After I did that, the Training Centre stopped quitting, but would not read the Garmin data. I checked the reason for this lack of communication and found out I had made a few changes to the my profile on the Training Centre and the Garmin - therefore - had different settings. Maybe this is what caused the problem in the first place. I told the Training Centre to use the device setting and the problem disappeared.
Posted on Jun 17, 2009
jgr4
  • 9 Answers
SOURCE: garmin forerunner 205 won't stay
The battery circuit connects to the main board with spring clips, near the top of the case. If the case is coming open it can cause the unit to spontaneously turn off. These spring clips may also be a little corroded from sweat or water that has leaked into the unit. Try squeezing the top of the unit gently a few times to wiggle the clips inside the case.
If you feel up to it you can open the case, clean and bend the clips, and seal it back up with silicone adhesive.
Posted on Aug 15, 2009
SOURCE: how do I change my garmin forerunner 205 from miles to kilometers
To change this setting go to the menu on the Forerunner by pressing the Mode button then follow the steps below:
  1. Select Settings
  2. Select General
  3. Select Units
  4. Select Distance and/or Elevation and change this to Metric if you wish to see the measurement units in kilometres and metres, select Statute if you wish to see units in miles and feet
Posted on Jan 23, 2010
  • 84 Answers
SOURCE: Missing training data from my Garmin 305....
Unless you created a "back up file" with the Training Center software unfortunatly you will not be able to retrieve the data.
Regular back ups will insure you do not lose information in the future.
To back up your data in the Training Center go to "File" and "Back up" I believe the early version of the Training Center did not have the Back up feature so you would then need to use the "File" Export" option.
Posted on Mar 03, 2010
How to remove battery from garmin 205 ?
they are fixed in you have to take the hole thing to bits
Jul 27, 2014 | Garmin nuvi 205W GPS Receiver
Garmin 295 forerunner will not turn on
Did you mean the Forerunner 205?
It is most likely that the battery has died in the unit or there may be a problem with the battery charger.
The internal battery in the Forerunner 205 is not user replaceable and the unit would need to go back to a Garmin repair for replacement.
Please call Garmin Tech Support for assistance.
1-800-800-1020
Feb 29, 2012 | Garmin Forerunner 205
Does garmin 205 have a light up screen for night use?
Yes it does. Pressbutton 1 (top left hand button) to turn on the light and again to turn it off.
If you don't have a copy of the user manual, go to http://static.garmincdn.com/pumac/984_OwnersManual.pdf to down load a copy.
Dec 12, 2010 | Garmin Forerunner 205 Gps Training Watch
My forerunner 205 was charging just fine until I pressed the power button. The screen went blank and I cannot turn it on. Does this mean the battery needs to be replaced. If so, how does one go about...
Probably it is not due to the battery.
Your device is crashed. Perform soft reset :
press & hold mode plus lap/reset keys for 10 seconds, release then press start long enough until device starts.
Sep 26, 2010 | Garmin Forerunner 205 GPS Receiver
Battery is fully charged on my 205 and yet it turns itself off
Can it be turn on when the device is attached to the cradle with electric supply?
If so, I think the battey is aged and it cannot be charged to the operating voltage to turn the device on.
A change of battery is required.
I had such a case recently.
Jul 30, 2010 | Garmin Forerunner 205 GPS Receiver
The power wont turn on
The instructions say that you should "press and hold the ON" button (top left).
Perhaps you are not holding it on long enough (I think that a delay is built into the buttons to prevent accidental operation due to catching it on something).
Jan 17, 2010 | Garmin Forerunner 205 Gps Training Watch
Garmin Forerunner 205 Battery won't charge. A few
Hey everyone. Just called Garmin and got it fixed. Sometimes the forerunner goes into power saver mode and needs to be reset
1. Hook up the usb cable and docking station to the computer.
2. Next, hook up your forerunner to the Docking station - It should pop up saying battery charging in progress
3. Leave it all hooked up and Hold the Mode and Lap/Reset Button together for 15 seconds - screen should go blank.
4. Let both go - should pop back up saying battery charging in progress.
5. Let Charge 20 minutes and it should be good to go.
Hope this helps!!!
Kenny
Feb 20, 2009 | Garmin Forerunner 205 GPS Receiver
Garmin forerunner 205 won't stay turned on
Jun 21, 2008 | Garmin Forerunner 205 GPS Receiver
Garmin Forerunner 205 GPS Receiver Logo
78 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
