Question about Zhone (6218-I2-200) Router
How to log into zhone router model 6381-A4-200
SOURCE: Zhone 6211-I3-200
user: user
password: user
firmware update: www.zhone.com
Posted on Jun 30, 2008
rickatnight1
  • 72 Answers
SOURCE: where can i log on to the router or change its password?
To access the router's configuration you need to type its IP address into a web browser. The default IP is 192.168.1.1 but if that doesn't work you can find it out with the following steps:
  1. Go to Start->Run
  2. Type "cmd" without the quotes into the box and press Enter
  3. type "ipconfig" without the quotes into the larger black box and press enter
  4. The number across from the "Default Gateway" is your router's IP address
I hope this helps!
Posted on Jul 09, 2008
SOURCE: default login information on a 6381-a3-200
username: Admin
password: Admin
username is case sensitive too.
Posted on Oct 27, 2008
  • 27 Answers
SOURCE: i can't log in my router to config it..
its not actually a problem, all u have to do is to manually restart ur router and try again with the user name admin and with the password 123456 or 1234. hope it solves ur problem.
Posted on Apr 07, 2009
govinda123
  • 2260 Answers
SOURCE: I cant open port for Zhone 6211-I3-200 Router
Some times you will need to open the Logical Ports on the router.
These are the logical ports.
For this you will need to open the set up interface of the router.
Once you open the set up interface of the router, you will be able to find the settings on the router where you can open the ports for the particular program.
If you are opening the ports for a special device in your network, then you must know the IP address of that device.
For example, wireless camera, DVR, X-box, Play station ...
You can choose the option PORT FORWARDING for a special device application.
If you just want to open the ports for all the network, then you can choose PORT TRIGGERING
Click Here
for more info
Posted on Dec 18, 2009
Hello there, need to know how to config a phone line modem Zhone 6381 I guess its called the Zhone 6381-Ax Router. I happen to prees the reset button and losst the programed IP. how can I go about...
To configure your router, make sure you are connected to it first, open your web browser. Ignore any error about lacking a connection. Type the default IP address (192.168.1.1) into the Location field of your browser and press the Enter key. The following screen appears.
The default user name is Admin and the password is Admin. Both are case-sensitive.
Note: You should have your PCs configured for DHCP mode (if your router will be), and have proxies disabled on your browser. If you see a login redirection screen when you access the web interface, verify that JavaScript support is enabled in your browser. Also, if you do not get the screen shown above, you may need to delete your temporary Internet files.
The first screen that appears after the log in screen is the Home page.
From this screen you can configure the LAN and WAN connections, configure the router's security, routing, and filtering, access debugging tools, obtain the status of the router, and view the online help.
From here, go to the Setup Tab and click the New Connection on the left.
Input your numbers and don't forget to save.
Hope this helps!
Dec 21, 2010 | Zhone (6218-I2-200) Router
I need the download device driver for 6381
you will find the drivers that you are looking for on this web page:
http://www.zhone.com/support/downloads/drivers/
they should be the 2nd or 3rd from the bottom
Oct 15, 2010 | Paradyne ADSL/R 6381 Router (6381-a2-200)
How to enable upnp with zhone router
hello, this picture should help ya.
http://screenshots.portforward.com/Zhone/6381-A4-200-1PR/UPnP.htm
Jul 31, 2010 | Zhone (6218-I2-200) Router
What is the IP address, Username and Password for the 6381-A2-200? Thanks for your help!!
The IP number is: 192.168.1.1.
The login info is UserID: Admin (case sensitive)
The password is Admin (case sensitive)
Also here is a link to the users manual:
http://www.zhone.com/support/manuals/docs/62/6210-A2-GB21-10.pdf
Good luck and if you found my solution to be helpful please rate it.
Apr 02, 2009 | Paradyne ADSL/R 6381 Router (6381-a2-200)
Zhone (6218-I2-200) Router Logo
129 people viewed this question
Top Zhone Computers & Internet Experts
Prashant M
Prashant M
Tejodhar Atreya...
Tejodhar Atreya...
Are you a Zhone Computer and Internet Expert? Answer questions, earn points and help others
