Iomega screenplay director remote control codes
SOURCE: Remote code for the iomega screenplay
I bought the JELLY Universal PC Programmable remote in Portugal for 10 euros. The code for Iomega Screenplay is 2297. See it here: http://www.wiltsgrove.co.uk/sub-category.php?ID=1709&CID=0026&PID=IR2005
Posted on Mar 30, 2009
SOURCE: Iomega Screenplay Pro HD - No Menu
I had the same problem with the Screenplay Pro HD. My Iomega was working fine and one day after exchanging files with a friend I got the logo, then the loading message and then it went into a black screen while the blue light kept blinking.
Obviously the connection to the TV was fine because the logo appeared.
I solved the problem by downloading and reinstalling the firmware.
I downloaded the firmware from the iomega web site.
Notice that during the installation process you get the message that it will delete your data and then shortly after you have the option to delete or keep it. Hang in there. This part is a little nerv wrecking.
Hope this helps.
Rainer
Posted on Jan 03, 2010
SOURCE: my iomega screenplay director is having problem
DTS audio only works with Optical Cable. If your TV/Surround does not have optical buy a Optical to Coax Converter.
Posted on Oct 13, 2010
  • 74 Answers
SOURCE: How can I format my Screenplay Director?...
Formatting the Data Partition
The data partition on the ScreenPlay Director is formatted with an NTFS file system and will appear as a read-only volume under Mac OS X unless special software is installed on the Mac. If you need to transfer files to the ScreenPlay Director by direct USB connection on a Mac, you must reformat the data partition to FAT32 (see instructions below).
NOTE: On a network connection, Mac OS will see the ScreenPlay Director as a shared SMB volume. This means you can use the network to copy files from a Mac to the ScreenPlay Director without changing the format from NTFS to FAT32. (Recommended if available.)
If you reformat the ScreenPlay Director data partition for use with a Windows PC, it is recommended that you use the Windows format utility to reformat with NTFS. Right click on the drive letter for the data partition and select Format.
CAUTION!
  • Do NOT change the partitioning on the ScreenPlay Director as this will remove the firmware that enables the ScreenPlay Director to communicate with your TV set. Only media files stored on the active data partition can be viewed or played on a TV.
  • Formatting the data partition will erase all existing data! If you have files on the ScreenPlay Director you want to save, move them to another drive or volume before reformatting.
Posted on Dec 22, 2010
SOURCE: I`ve buyed an Iomega screenplay director. I connect
I assume you've figured it out by one, but just for anyone whole googles across this (like I did). Just put your sub-folders and videos on the drive that's titled "screenplay" (or something like that, the media player is connected to my tv now) and it seems to be working away grand now :)
Posted on Feb 11, 2011
Iomega screenplay director firmware
Iomega i ScreenPlay Director SPDHD - Lenovo Community
forums.lenovo.com > ... > Iomega Desktop Network Storage
Nov 16, 2013 - 5 posts
Hola, tengo un iomega screenplay director y hasta ayer me ... aqu?: Versi?n 1.4.0.92 del firmware de ScreenPlay Director: Leer primero Iomega Screenplay Director HD doesn't work on TV
Mar 15, 2015
Firmware Iomega screenplay HD500
Feb 9, 2014
How to find, download and install firmware on my i...
Jan 14, 2014
Iomega ScreenPlay Director error 12
Jan 10, 2014
More results from forums.lenovo.com
Dec 25, 2015 | Iomega ScreenPlay Director 1TB HD Media...
Still wont connect iomega screenplay 1tb media player with philips universal need different programming code.???
Mine is the same problem too cant connect Iomega Screenplay-director with my Philips 32pfl LCD with hdmi though composite connection works.....with hdmi its just blue screen which says video mode not supported....
Sep 10, 2011 | Iomega ScreenPlay
When i connect my screenplay director to my tv the picture is in black and white, how can i fix this problem?
Confirm that the ScreenPlay Director is correctly connected to video input on your TV set.
Make sure the ScreenPlay Director is connected to power and turned on.
Make sure you have selected the correct video input on your TV to display output from the ScreenPlay Director.
The video output setting on the ScreenPlay might not be correct for your TV. Press the TV SYS button on the remote control repeatedly until the screen displays normally.
Try on a different TV, you TV may not be supported with this device.
Oct 25, 2010 | Iomega ScreenPlay Pro MP3 Player
I purchased an iomega 1TB screenplay director at P.C world in the U.k On my return to Spain I discovered ther was no "users manual" in the box, only the quick set up guide. Obviously I do not want to...
ScreenPlay Director HD Media Player:
User's Manual: View Online [HTML] http://www.iomega.com/support/manuals/hdd2010/spdirector/en/main.html
Download [652KB zipped HTML] http://download.iomega.com/english/manuals/english/screenplay-director-en.zip
Quick Start Guide [PDF 1.2MB] http://download.iomega.com/qsg/spdirector_us.pdf
Specifications https://iomega-na-en.custhelp.com/cgi-bin/iomega_na_en.cfg/php/enduser/std_adp.php?p_faqid=22159
Oct 12, 2010 | Iomega ScreenPlay Plus 34499 Digital Media...
I need to download iomega Screenplay 1T user manual
You should be more specific with which unit you have when asking questions about it.
ScreenPlay Director HD Media Player: User's Manual: View Online [HTML] http://www.iomega.com/support/manuals/hdd2010/spdirector/en/main.html
ScreenPlay Multimedia Drive: User's Manual: View Online [HTML] http://www.iomega.com/support/manuals/hdd2008/scrnply/en/consolidated/main.html#scrnply
ScreenPlay 60GB Multimedia Drive User's Manual: http://www.iomega.com/support/manuals/allhdd/screenplay/en/main.html
ScreenPlay HD Multimedia Drive: User's Manual: View Online [HTML]: http://www.iomega.com/support/manuals/hdd2008/sphd/en/main.html
ScreenPlay Plus HD Media Player: User's Manual: View Online [HTML] http://www.iomega.com/support/manuals/hdd2010/scrnplyplus/en/main.html
ScreenPlay Pro HD Multimedia Player: User's Manual: View Online [HTML] http://www.iomega.com/support/manuals/hdd2010/scrnplyprohd/en/main.html
ScreenPlay TV Link User's Manual: View Online [HTML] http://www.iomega.com/support/manuals/hdd2010/sptvlnk/en/main.html
ScreenPlay TV Link HD Media Player Director Edition: User's Manual: View Online [HTML] http://www.iomega.com/support/manuals/hdd2010/sptvlnkdir/en/main.html
Oct 10, 2010 | Iomega ScreenPlay
How do switch i switch on subtitles ?
ScreenPlay Director HD:Press the Menu button on the remote control to display the action menu and select Subtitles, then choose the language you need.
Sep 19, 2010 | Iomega ScreenPlay
How do i download a manuel for my new screenPlay Director HD Media Player I have 700 Albums and it takes forever to scroll throught them on my TV
Downloadable Manual [652KB zipped HTML] http://download.iomega.com/english/manuals/english/screenplay-director-en.zip
May 25, 2010 | Iomega ScreenPlay
I have lost the operating instructions for this product.when I press power on the remote the unit blinks for some time and then goes the blue light goes out.what else should I be doing. Thanks in...
Downloadable User's Manual [652KB zipped HTML] http://download.iomega.com/english/manuals/english/screenplay-director-en.zip
May 15, 2010 | Iomega ScreenPlay
Mar 15, 2009 | Iomega ScreenPlay
Televison & Video Logo
283 people viewed this question
Top Televison & Video Experts
Electro Med Services...
