Question about Sony Ericsson Z520 K750 W550i Headset Black Left/Right Earloop Handsfree Headset
Help plz my phone wont turn on its flashing red where u should turn it help plzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz
0 characters
1 Points
Motorola s9 headset wont turn on
Mine is doing the exact same thing. Does anyone know what the problem is? If so, what is the fix.
Apr 27, 2012 | Motorola Mobility MOTOROKR S9 Wireless...
Ps3 afterglow bluetooth flashes red and blue and wont let me talk, what do i do?
When the afterglow headset flashes from red to blue, it is in pairing state, youve held the power too long after power-on. Shut it off again and turn it back on and dont hold the power button untill it flashes red to blue. The directions provoded with it aare quite easy to follow. Took me 30 seconds to set mine up
Apr 09, 2012 | Mad Catz Headsets
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
I cant pair my phone N95 8 GB to plantronics explorer 230 using 0000
It's important to follow these pairing instructions carefully if you're having problems connecting the two devices. If you have a flashing blue light on your headset, hold the button in on the headset until you see red, release it so it will turn off. Then hold in that same button until you see the light on the headset flashing red/blue, red/blue. Once the headset is flashing red/blue your phone should find the headset. If your phone asks you for a passkey, that is 0000 (4 zeroes). Hopefully this should help you.
Good luck from Headsets Direct - 800-914-7996.
Aug 13, 2011 | Plantronics Explorer 230 Bluetooth Headset
After i try to turn it on, I get 1 blue flash and 3 short red flashes and it wont turn on.
When you turn on your headset, the blue light indicates it's on and
the three red flashes indicates a charged headsets. If it's not
turning on after that, try resetting the headset (turn off and on).
Turn it off by pressing the call control button until the indicator
glows red (you'll hear descending tones). Once off, turn it on in the same way (you'll hear ascending tones).
Jul 08, 2011 | Plantronics Hama Voyager 520 Bluetooth...
Phone wont recognize bluetooth
When you say "phone wont recognize bluetooth", do you mean that the phone can't find it, or that it finds it but doesn't complete the pairing? It could be that that headset is not completely in pairing mode. It should have either flashing blue or flashing red/blue or solid blue.
Sep 09, 2010 | Motorola Mobility H710 Bluetooth Headset
Head set not pairing with sony erricson k750i
The solution for paring the explorer 240 is found in the bottom of the product page for the embedded link on the User Guide Link. I have also provided the instructions below. I hope this helps
How to Pair Your Phone With Your Headset for the First Time
1 Turn on the Bluetooth feature on your phone.
For most phones, select Settings/Tools > Connections >
Bluetooth > On. See your phone’s user guide for more information.
2 Turn the headset on.
Turn on your headset by sliding the Power Switch toward the microphone. Wait until the indicator light flashes red then blue.
If you don’t see the red then blue flashes, turn the headset off, then turn it on again. Press and hold the Call Control button until you see the red then blue flashes that indicate pairing mode status.
3 Set your Bluetooth phone to ‘discover’ to locate the headset.
This usually involves going to ‘setup’, ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add a device’.
4 Once available headsets are listed, select your headset (for example 2XXPlantronics or 3XXPlantronics). If prompted for a passkey, enter 0000.
When pairing is successful, the indicator on your headset flashes blue. Your phone will also confirm when pairing is complete.
John M
May 06, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Headset does not flash red/blue so I can pair it with my phone
To get it into pairing mode (flashing red and blue) turn the headset off.  Hold the main button down until the light goes red and then off.  Then push and hold that same button and keep holding it even after the blue light comes on.  It will now go into pairing mode, flashing red and blue.  Set your cell phone to find it and it should work.
May 09, 2009 | Plantronics Discovery 925 Bluetooth...
The device wont pair with my phone
  1. Make sure headset is off.
  2. Press and hold the answer button until the light flashes green and red.
  3. If it only flashes green, press and hold both volume buttons until the light flashes red and green.
  4. It is now ready to pair: follow the instructions in the bluetooth menu of your phone. When asked for the passcode enter 0000.
  5. All done.
Dec 02, 2008 | Sony Ericsson Universal Bluetooth...
I had this problem. I fixed it doing follow: hold volume keys together, so the indicator is flashed red and green (reset to default settings mode). Then press power button to turn the headset off. Then turn it on again and try to find the headset again from my phone. Then select "pair" from phone menu and typed "0000". The led stopped flashing and headset was connected. Before this my phone couldn't see the headset at all. Hope it will help you! (sorry for my English, I'm from Russia =))
Nov 27, 2007 | Sony Ericsson HBH-PV705 Headset
Sony Ericsson Z520 K750 W550i Headset Black Left/Right Earloop Handsfree Headset Logo
19 people viewed this question
Top Sony Ericsson Headsets Experts
Justin Peters
 Mike M
Mike M
Are you a Sony Ericsson Headset Expert? Answer questions, earn points and help others
