Question about Panasonic Computers & Internet
I can successfully download the software, "Image Creator 1.5" from Panasonic's web site but then when I try to install it I get an error message, "Error reading file." Could it be because I have XP Home instead of XP Pro edition of Windows? I emailed Panasonic over a week ago without any response. I've never had any trouble installing downloaded software before. Any suggestions? STW
    President:
  • 2,712 Answers
The downloaded file is probably corrupt/didn't download properly, or there could be a conflict with another software. A "clean boot" may resolve the symptoms you are experiencing. Booting clean is a way to eliminate programs from conflicting with installation of software.
Download the latest version of the software for XP from the manufacturer's website.
1. Click Start --> Run --> Type MSCONFIG --> Click OK
2. On the General tab, choose Selective Startup
3. Uncheck Process SYSTEM.INI file
4. Uncheck Process WIN.INI file
5. Uncheck Load Startup Items
6. Click on the Services tab
7. At the bottom, check Hide All Microsoft Services
8. Uncheck all boxes in the window or click the button labeled Disable All
6. Click OK
7. Click Restart
After restarting, reinstall the downloaded software. Next, do the following:
1. Click Start --> Run --> Type MSCONFIG--> Click OK
2. Replace checkmarks in the items that you previously removed them from.
3. On the General tab, choose Normal Startup
4. Click OK
5. Click YES, when asked to restart your computer
Hope that helps...Should you have any further questions, please feel free to post them here.
P.S. Before you assign a rating, please make sure that the issue is resolved or you are satisfied. If not, please post back as to what you did, and/or any other questions you may have, and I will try to assist you as best I can. Please do not assign an ‘Inappropriate’ or ‘Thanks for trying’ rating if your issue is not resolved after the first response itself, as sometimes a bit of to and fro dialogue may be necessary before we can find a fix or an answer to your query.
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Oct 26, 2008
Calendar creator 6.0 windows xp
If you can get to the cd and explore it, open the NT Setup folder. Then open the DAO folder. Open Disk 1 folder and run setup.exe. Then try running the program. It worked for me after I had the same error.
Jun 24, 2012 | The Learning Company Calendar Creator...
We are installing Movie Creator version 2 on Windows 7, the camera drivers fail to install and an error occurs when opening the software - ***Direct Show Error: Class not Registered*** already tried the...
if the drivers fail to install on win7( no longer supported by Microsoft) try going to the publisher web page and downloading the drivers direct from there for win 7
if there is no microphone connection shown by the product before installation, might I suggest a program that has that connection listed or find out if a mic driver for the michrophone would solve the problem
Nov 19, 2017 | Digital Blue Digital Movie Creator...
Impossible to set up this external DVD drive on my laptop computer. The genuine CD/DVD drive is out of order. I've attemped to copy the CDrom on a usb key, then on may computer : no success. If you have...
Normally, the external USB DVD rom's are plug and play devices.
But in case its now working for you right now then there could be a case that it needs some drivers or so. Have you received anything with it? Any disk of something?
Which operating system are you using?
Admin
HNetworking.com
Feb 03, 2011 | Computers & Internet
Burning error - error code 0x80004005
hi!!!
try to re-install the software of your burner!!
Nov 20, 2008 | Roxio Easy Media Creator 7
Videocam suite v1.0 download for a Panasonic SDR-H280
I've successfully downloaded & install the videocam suite 1.0 + update from here: http://www.brothersoft.com/videocam-suite-297215.html Thanks to Google!
Oct 20, 2008 | Video Cameras
Hp officejet 6110xi all in one
I did a search of your product's help pages on HP.com but didn't come up with an exact match for your error message relevant to an Apple Mac OS X. Before offering suggestions, let me make sure I understand the problem.
You have a Word document open on your Mac and you want to insert an image into the document that's on the scanner.
I'm actually not clear as to whether you successfully scanned an image in the first place. If you did scan the image, where did you store it to? Have you tried scanning the image and saving it to your computer? If you can do this successfully, try inserting the image into your Word document from the location on your computer.
If you tried to scan an image and got the error message, then there is a communication problem between your Mac and the printer. Since you can print, the cable connection must be good. If the error message is suggesting that you reinstall the drivers, you can find the instructions for how to do this at the following web page at HP.com:
Installing and Uninstalling Printer Software on your Mac
You may or may not have your original software disc that came with the printer. If you don't or if you need an updated print driver, you can download that software from the following web page, assuming you are running Mac OS X:
Mac OS X Printer Software and Driver Downloads
Occasionally, you can solve errors by installing print drivers that are more recent than those you originally installed when you first got your printer. That's the benefit of downloading the latest drivers from HP.
On the off change you are using Mac OS 9, here's the relevant software download page (the version of the Mac operating system matters):
Mac OS 9 Printer Software and Driver Downloads
If all you want to do is to insert an image into a Word document, you shouldn't need Adobe Photoshop or any other expensive software application. You aren't trying to do any fancy editing of the graphic, just insert a pre-existing image into a document.
I hope some of the above suggestions help. Post back your results and good luck.
Oct 15, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Having installed Roxio Creator 10, I get a recurring message: "RoxMMTrayApp Module has encountered a problem and needs to close." Etc. It occurs even when I am not editing with that software. ...
ROXIO Multi Media Tray Application Module Has Encountered a problem and needs to close.
This Means ROXIO Creator 10 Try Application Encountered an error.
And since it happens while burning a disc
You should
1. Uninstall ROXIO Creator 10 , and reinstall it to make sure nothing is corupted.
2. If you still get the same problem it's time to check your intire system for errors.
This can mean you will need to take trouble shooting steps.
1. Use another burning program to see if you can burn without errors.
2. if you can burn fine with another burning program like NERO then chances are
you have an incompatability with ROXIO Creator 10 and should consult the documentation
to see if your drive is actually supported by it.
Do these things weed hopper and all will be well with you.
Az.
Sep 16, 2008 | Computers & Internet
Cannot install softaware for quickcam messenger from the internet
if your pc is networked disconnect it.install a good antivirus software like quickheal.then download it again.it will work fine.
Feb 08, 2008 | Logitech QuickCam Messenger Web Camera
Computers & Internet Logo
53 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
