Question about Honeywell Heating & Cooling
How to wire honeywell aquastat L4103 - Honeywell Heating & Cooling
2 Suggested Answers
  • 182 Answers
SOURCE: My L4103 aquastat is set
phl4103-3.jpg on the left side of the dial will be a little metal arrow that will not move when the dial moves, this is the set point. set the temp. you want at this point.
Posted on Dec 17, 2010
I have installed honeywell aquastat relay per instruction manual on my dunkirk xeb-4 lp boiler furance with honeywwell ignition unit s8610u but it wont ever start the exhaust fan checked everything several...
If aquastat wirings are ok, and control module had been set up properly, the the furnace should start.
Check if bypassing the control the furnace starts, if it starts then check aquastat wirings.
If it depends on the furnace, check the valve, the safety sensor and the ignitor.
Here is the guide to set up the Aquastat control:
Guide to Setting & Wiring Heating System Boiler Aquastat Controls
Sep 13, 2008 | Honeywell Heating & Cooling
Well my furnace wont turn on at all i got power to the aquastat "honeywell L8148A1017" but no power coming out of the b1 b2 "burrner outs on the board at all but i hear the click in the...
the relay on the aquastat is probably bad ( contacts ) try actuating the relay with a screw driver to see if it engages the unit. if it does theres your problem new aquastat
May 09, 2017 | Honeywell Heating & Cooling
My L4103 aquastat is set too hot, it does not clearly stat temps on set dial which way do i turn it to lesson temp
Dec 17, 2010 | Honeywell Heating & Cooling
Looking for simple wiring diagram to wire ******** aquastat
What are you fanning??? the fire?
Do you have a circulator that circulates when the water is up? Many controls have a AUX connection ... wire the AUX to your fan --- alaternatively, wire directly fron your circulator connection to the fan.
I hope I understood your question ...
Let me know what happens.
a
Oct 16, 2009 | Honeywell International Honeywell&...
My john wood hot water tank over flows through the relief valve every 3 - 6 months. The hot water is too hot and I can't seem to adjust the Aquastat L4103 on the hot water heater to a good temperature....
There should be plate on the front of the hot water heater tank.. Pop that off..
There might be some insilation to move and you should see a set screw for adjusting the temp..
If there are no indications for hotter or cooler - then do a 1/8 turn to a 1/4 turn counter clockwise..
Hope this helps !I
rate me good ;o)
Jul 14, 2009 | Honeywell Heat/Cool Thermostat
I want to increase the boiler temp by using the your aquastat
Warning! Can cause electrical shock! Here is the instruction manual
for L7248c
http://customer.honeywell.com/techlit/pdf/PackedLit/68-0281.pdf
Jan 12, 2009 | Water Heaters
Heating & Cooling Logo
311 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
