Question about Swingline 87860 PowerEase ? Full Strip Stapler
Model 8786X Can't get it open to load staples and it's possible it's jammed as it won't feed the last few through.
3 Suggested Answers
caroldon
  • 17130 Answers
SOURCE: how do I remove a jammed staple?
All you need is to use a thin sharp wire rod to push the damaged/cramped pin out of the hammer. You can achieve this only if you can have such a tool , remove the lid to get access, manually turn aside to relieve the presssure on the damaged pin, remove the cartidge and replace after the pin is removed. You can also slightly tap to get the pin released from the jammed position.
Posted on Oct 25, 2011
  • 36408 Answers
SOURCE: staples won't advance and come out
There may be a piece of a broken staple jammed in the end or the spring may be weak
Posted on Apr 19, 2013
900XDN-C SWINGLINE HIGH CAPACITY HEAVY DUTY STAPLER OPERATIONS MANUAL
auto parts store sells a pick with straight on one end and 90 degree on other end.
This should be slender enough to pull staples out.
Mar 27, 2013 | Tools & Hardware - Others
Arrow jt27 staple gun won't load or staple
Everyone here is assuming that you have fully operational gun. I have a business where we use these guns. I can tell you now that 3 out of 5 of the Arrow JT-27 just don't work. The staples won't advance. After looking at the information online, it is probably due to a weak spring. The best solution is to go with a different brand of stapler. This one is just not worth the trouble.
Jan 16, 2013 | Tools & Hardware - Others
The staples won't go fully into the Wood
1. The wood may be too hard for the staples to penetrate
2. The stapler drive spring may have ghotten weak
3. You may not be holding the stapler nose firmly against the wood while stapling
Jan 06, 2013 | Stanley TR250 H Heavy Duty Heavy Duty...
Staples are loaded and won't shoot
check for a jammed staple near the end. This often happens and prevents the staple from feeding all the way
Sep 17, 2011 | Garden
How do you load staples in ET501? I pinch the back of the loader together but it won't pull out.
Try pinching it and pushing it down at the same time. If that doesn't work then there is likely a jam.
Jul 02, 2011 | Heavy Duty Arrow Et501 Electric...
My PHT150 SharpShooter is jammed and won't spring back. The staple plunger is sticking out and won't retract.
Sometimes a bit of the staple material will be sheared off and jam the hammer in its guide, keeping the tool compressed. On the business end of a PHT150 there is a notch in the hammer housing and a slot on the staple carrier. Most times a standard screwdriver can be used by sticking the tip straight into the slot and using the notch to leverage the the two apart. If not, you can clamp the hammer housing in a vise and, using the screwdriver in the carrier slot, tap away from the hammer housing to release the jamb.
May 31, 2011 | Stanley Tools Hammer Staple/Tacker -...
Stanley light duty staple gun loads and shoots but staples not coming out. nothing jammed as far as I can see. Should I open it up and have a look at the interior? Thank you Denise
It sounds to me like you must have a staple that has seperated and probablygot stuck in staple feed shute' I wouold carefuflly remove side plate and see if there is a staple in there crooked or if their is is small metal chip left over from manufacture.I hope this helps you.THANK.
Apr 07, 2011 | Stanley TR40 Light Duty Tacker
My arrow fastener model t-50m is jammed how do I remove the few
I have a similar issue with my T50m stapler. To remove the staples unscrew the locking nut near where you load the staples and remove the tapppered bolt. The track will lift out and the staples can be easily removed. Why this is happening is unknown to me also. I purchased a new gun.
Feb 14, 2009 | Arrow Fastener 509 9/16" T50 Staples
Swingline 87860 PowerEase ? Full Strip Stapler Logo
188 people viewed this question
Top Swingline Office Equipment & Supplies Experts
Paul Bade
Stitch85
Level 1 Expert
Are you a Swingline Office Equipment and Supply Expert? Answer questions, earn points and help others
