Question about Maytag Atlantis MAV6000 Top Load Washer
How do I install a lid switch on my maytag atlantis mav6300aww
SOURCE: Quit Working
it would be the switch get a knife and swip at both ends off ware the top lid section meets front side[join at front]this will allow top section to lift up switch may be broken or to short to turn on if to stort drill hole & pot screw in to adjust lenght of swich leaver
Posted on Dec 24, 2007
Lumpy816
  • 246 Answers
SOURCE: Maytag Atlantis washer will not drain and spin unless you lift the lid
The cheaper thing to check first is is your lid bent? The lid switch is in the center of the lid. If it "droops" or has been bent, it shaft on the back of the lid cant hit the switch. Open the lid and apply pressure in the bottom, center of the lid. This usually corrects the problem without replacing the switch.
Posted on Jun 16, 2008
docjohn174
  • 943 Answers
SOURCE: Maytag atlantis washer
hi thanks for the question you say you activated the washer with screw driver . is the striker on the lid there ,.you could have a broken striker. check that if its there . replace the lid switch the appliance doc
Posted on Sep 28, 2008
  • 10865 Answers
SOURCE: Need to replace Lid Switch for Maytag Atlantis 2002 Washer
Hello, I can help you.
Let me explain to you how the Maytag washer lid switch works.
The lid switch is located on the controls panel, and is activated by opening and closing the washer door. The purpose of the lid switch is to prevent the washer from working with the door open.
It is a safety device to prevent the user from sticking their hands inside of the washer while the washer is agitating or spinning.
When the washer lid switch stops working, the result could be that the washer won't wash, drain, spin and in some cases the washer will not work at all.
You will need a multimeter to check the internal contacts on the washer lid switch.
You will also need to use the wiring schematic to see what contact should be close when the lid switch supposed to be on.
You will need to remember that the Maytag washer lid switch is one of the first parts that you will need to check, when the washer don't want to start filling, agitating, draining or spinning.
Posted on Jun 13, 2009
  • 11 Answers
SOURCE: My lid switch went out on my maytag atlantis
Very good reference can be found here... www.applianceaid.com/atlantis.html
Best wishes,
Bondo
Posted on Nov 12, 2009
My maytag atlantis will fill but now wont run or drain. If it is the lid switch how do I fix it?
If it is a lid switch, you replace it, however I suggest a continuity test with a Volt/Ohm meter. The switch needs to be able to open and close, electrically.
Jul 06, 2011 | Maytag Atlantis MAV6000 Top Load Washer
I have a maytag atlantis washer it will fill with water but then it won't do anything. what could it be?
This problem can be caused by a variety of malfunctions, or failures however the most likely culprit is the lid switch. The lid switch is part #3 shown in the following diagram. The switch mounts at the rear of the chassis top part #1 with screws part #12.
<img src="http://www.appliancepartspros.com/sect/0/1/j/01jjrlnuzz.gif></img>
Feb 03, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Maytag atlantis washer mav6300aww drains water but does not spin
my maytag washer model #MAV6300AWW will not spin out during cycle but can turn it back to spin and will spin out
May 30, 2010 | Maytag Atlantis MAV6000 Top Load Washer
I have a Maytag MAV6300AWW, it does not spin the clothes dry. It works fine otherwise. Any idea what the problem is. I saw an answer but it must be for another model. My model appears not to have carbon...
The plastic pulley is worn out typically at the bottom- most common issue. It needs to be replaced. Thanks, please leave feedback or contact me again for more info if you need it.
Nov 29, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Sep 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
May 31, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
