Question about Eljer TITAN One-Piece 1.6 GPF Toilet - 081-0
Pf 2 toilet not flushing properly how can i fix it
3 Suggested Answers
projdoc
  • 2237 Answers
SOURCE: toilet wont flush completely. it may take 4 times
there is no air release. the vent must be clogged somewhere. you can take a hose up there and see if it drains all the way or floods over. since the tub drain has a trap and the toilet itself is a trap, there has to bee a good amount of air pressure coming up without a release. i would say an obstruction. possibly at the junction of the main and the vent.
Posted on Nov 13, 2009
  • 454 Answers
SOURCE: on my eljer toilet, I get continuous running of
I don't know what you mean by "pumping" the tank. If the toilet runs, then either the fill valve is defective or the seal on the flush valve is defective. First, check to see that when you move the float, the toilet stops running. If it does not, then replace the fill valve. If it does, then inspect/replace the seal on the flush mechanism at the bottom of the tank. If this seal is bad, you can usually see water continuously flowing (slowly) into the bowl. You will see ripples on the surface of the water in the bowl.
Posted on Jun 04, 2010
Elver PF/2 Energizer won't flush. Chain is tight but plunger and spring comes loose
Sorry but this is a hands on fix and only your hands are there . reconnect it .
Nov 21, 2015 | Home
Dux toilet cistern problemsolving
can only be one of 2 things. the inlet valve is not shutting off properly and so the tank is overflowing into the toilet bowl or the flush valve rubber is worn out. you can find this at the bottom of the flush valve mechanisum.
Dec 04, 2013 | Home
Problem with a PF/2 Energizer (pressurized) toilet. After the flush and the refill... a small stream of water keeps sipping and hissing out from a small tube located towards the bottom of the housing...
there must be some dirt on the seat of the valve as when water is turned off and on sediment , dirt can plug up small orficies take apart the valve by getting a schematic from the manufacturer online to take it apart
Sep 14, 2013 | Home
The lever (handle) to flush the toilet does not rise after it is pushed down, causing the toilet to run. One has to push the lever (handle)up after the down motion to make it function properly.
I had this issue as well with my toilet. My chain was unattached and had been sucked down the drain under the stopper valve preventing the toilet stopper valve from completely closing and causing the water to continually run. After re-attaching the chain I noticed when I flushed the toilet that the handle did not rise again until I manually pushed it up. After readjusting the chain to a tighter position where the chain was not floating at all but instead holding the stopper valve in place I again flushed to check the reaction. This fixed the issue of the water continually running and also the handle not resetting itself properly.
Here is the steps I took to resolve my issue:
Step 1: Remove the lid off of the tank.
Step 2: Check to see if the chain coming from the Toilet Handle to the Stopper Valve is loose, unattached, or broken.
Step 3: Flush the toilet and check to see if the problem has been fixed. If not readjust the chain to a different position and flush again.
Step 4: If all is resolved replace the tank lid.
Other possible things to check:
Check the Float Ball to see if it's Half-way or more submerged in the water. If it is it needs to be replaced.
I hope this helps!
Nov 08, 2010 | Toto Home
On my eljer toilet, I get continuous running of the water. If I shut valve off and pump the tank, the running stops (but only for a week or so). Suggestions? model 150-403 power flush pf/2
Jun 01, 2010 | Eljer Home
Flush button won't work. 12 yr old Duravit Toilet
The push button siphon assembly is worn out. Just replace it entirely.
May 26, 2010 | Home
My toilet does not flush properly. It seems to
You might check under the rim of the toilet, there are about 12 little holes that when you flush water comes out to start the most important part of the flush. The swrill, with out it hard to flush. Talk a piece of wire hanger ( I know "NO WIRE HANGERS") and use it to push up into the holes. Hard water deposits sometimes build up there.
Sep 27, 2009 | Home
Kohler Cimarron elongated comfort height toilet not flushing correctly
low water in the bowl is only caused by the float being to high! the gurgles is Usually because of air coming back up through the pipe, check your vent pipe that come out the roof. this will help the draining.
May 30, 2009 | Kohler Cimarron 2-PC Elongated Toilet with...
Push Button - Have to Hold Down Button
I had the same problem. The fix cost me 50 cents (literally). I just placed a quarter on top of the Blue and White flush buttons (not sure of the technical terms) inside the tank and now it flushes properly. It seems that the 2 plastic poles the extend from the faux chrome buttons are just a bit too short.
Hope this helps
Feb 18, 2009 | Toto Aquia II Dual Flush Toilet
Eljer TITAN One-Piece 1.6 GPF Toilet - 081-0 Logo
55 people viewed this question
Top Eljer Home Experts
john h
Mike
Donni Steen
Are you an Eljer Home Expert? Answer questions, earn points and help others
