Question about Precor 933 Premium Series Treadmill
Precor 933 has burnt rubber smell
Treadmill not used in 3 yr. it now has a burnt rubber smell when in use
4 Suggested Answers
  • 14 Answers
SOURCE: ???maximum user weight for Precor 9.45i
Normally most home treadmills are 250-300lb user capacity.
Call Precor with your model # and S/N and they can tell you exactly.
Posted on Apr 29, 2009
ercupa190
  • 12223 Answers
SOURCE: 9.1.0 TREADMILL PRECOR PACE ERROR
Dear Sir:
Hello I hope everything is fine.
I will give some Tips:
Description Errors 00 through Error 04 check upper PCA memory locations, RAM memory locations and EEPROM checksum during the power up test sequence. If a fault is found during the power up test sequence, the appropriate error code will be displayed. Possible Causes 1. These errors messages almost always indicate an upper PCA problem when they are consistently displayed. Failures causing these error messages to be displayed are rare. Possible Remedies 1. If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see one of these messages displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in one of these messages being displayed. Treadmills operating on non-dedicated A.C. circuits may see these messages displayed on an intermittent basis.
In other words, you need recalibration in your equipment, I recomend after you make a test for a RAM MEMORY.so contact your service call. I recomend Strong, INSTALL regulator Voltage is cheap about us$15,00 Radio Shak or another Electronic Place.
Thank you in advance , sincerely. Blessing. If you need additional Help, please do not hesitate to contact me.
E.CUADRA MANAGUA, NICARAGUA. C.A.
Posted on Sep 27, 2011
ercupa190
  • 12223 Answers
SOURCE: Trying to fix a 20+ yr.old treadmill (Precor USA
Dear Sir:
I hope you are very well, in union with your family.
Thank you by your request, and I will help you inmediately.
Please follow the next step with very carefully:
    • 1
Makesure that the surge protector being used is properly grounded(Very Important) and turned on.Check that the treadmill power cord is properly plugged into the surgeprotector.
    • 2
Checkto see that the key is inserted in the console.
    • 3
Checkthe circuit breaker on the frame near the power cord. If the reset/off circuitbreaker has tripped, wait 5 minutes and then reset the breaker by pressing theswitch in.
4)Check the circuit braker panel house, and reset.
Static Shock Problems:
Many people face a conundrum when using a treadmill. The problem is that a treadmill has you walk or run in a motion that causes you to build up an electrical charge on your body while you are exercising.
The problem if you are swinging your arms, you are totally isolated from any common ground so the charge just builds and builds and many discharges have been measured above 30,000 volts.
You may say, how in a frost-covered hell can I build up 30,000 volts on my body without killing myself? Good question and it has a good
answer...there is very little amperage. It will pop you good when you do ground and sting but it won't hurt you.
The problem is that it can damage the treadmill's electronics if it is not properly designed and we still see poor designs in this respect
If you don't like getting popped or if your treadmill is shutting down or going crazy, there is a fix. You can ground yourself to keep the electricity from building up on your body.
We now have wrist grounding straps that can be reused and attach to the frame of the treadmill without causing any markings and do not require any permanent modification to your treadmill. You can find them in any online catalog by electronic sales by searching for Grounding Strap.
Thank in advance, sincerely. God bless you.
If you need further assistance, please contact us.
E.CUADRA
Posted on Sep 28, 2011
While running after few minutes I get rubber burnt smell
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Oct 01, 2015 | Exercise & Fitness
My tredmill works but after few mins I get burnt smell?
Treadmills are relatively simple machines, which means a burning smell can be quickly determined.
Check your treadmill belt for wear. Try to find where on the treadmill feels hot when you smell the burning. It could possibly be the electric motor or wiring giving out under load.
Oct 01, 2015 | Cars & Trucks
Inconsistent Speeds and Motor Smell
A new treadmill is in order! It sounds like the motor is either old, or it has a factory default. Definitely do not use the treadmill if it produces burning smells this is in fact the wires in the motor heating up and melting this could cause a fire.
Jan 23, 2014 | Advanced Fitness Group AFG 1.0 AT Folding...
Honda passport problem
The louder noise and burnt smell possibly was the bearing getting worse, or going out, causing the belt to slip over the pullet and start heating up.
Was it a burnt rubber smell?
I don't see how this could have anything to do with the flywheel though.
Dec 18, 2013 | Cars & Trucks
Hi there i have a york treadmill and we moved house and when they were moving it it lost all this oil and now the automatic release button does not work so easily and i think it is starting to smell a bit...
you need to buy silicone 100% FOR LUBW the deck belt and rollers bearing.
You need to buy in any store for tredmills.RFemember LUBE the treadmills by each 5 hours of use.
God bless you
Nov 16, 2012 | Exercise & Fitness
Treadmill INCLINE DOES NOT WORK?!?
Is it new? If so you need to call the manufacturer. If it is not, call Treadmill Doctor at 800-750-4766 and have you make, model and serial number of the treadmill ready so that they can diagnose it.
http://www.treadmilldoctor.com/?utm_source=fixya&utm_medium=cpc&utm_campaign=mendi
Jul 04, 2012 | Reebok Exercise & Fitness
Treadmill rubber tread has strong odor
Turn off and unplug the unit before making any adjustments. Check the belt alignment on the treadmill. If the treadmill is making noise or you smell burnt rubber, the belt may be loose or out of alignment. There should be a belt roller on the side or the front of the unit. You can use a hex wrench or an adjustable wrench to loosen the belt so it can be properly aligned. Make sure you tighten the belt so it does not rub against the machine. Consult the user manual for specific instructions in adjusting the belt.
  • 2 Reposition the heart rate monitor. If the monitor does not show a reading, it may need to be repositioned. The monitor should be placed against your skin so the sensor is facing toward your body and the HealthRider logo is facing away from you. The monitor will only work if you stay on the treadmill, walking in the middle of the belt.
  • 3 Test the hand grip monitors for a correct reading. These are the metal plates that are secured to the hand railing. If the plates are dirty, they may not function correctly. Wipe them clean with a damp cloth. Your palm will need to wrap completely around the plates at all times for a proper reading.
  • 4 Reset the unit if the treadmill still does not function correctly. Unplug the unit from the electrical outlet. Leave it unplugged for about one minute and then turn the machine back on. Remove the safety key from the treadmill and reinsert it into the key slot. Taking out the key will reset the unit, clearing all memory and resetting it to factory defaults.
  • Nov 09, 2011 | Exercise & Fitness
    The motor is making a whirring noise a bit of a smell coming out (burnt type smell)
    Sounds like either the drive belt is slipping or your motor is going bad. If you see fine rubber dust on the floor or machine hood area it's the belt.
    Jan 25, 2010 | Exercise & Fitness
    Speed fluctuates randomly
    Try calibrating the console. If it doesn't work, you'll need a new motor control board.
    Feb 15, 2009 | Reebok 8050 ES Treadmill
    Precor 933 Premium Series Treadmill Logo
    44 people viewed this question
    Top Precor Exercise & Fitness Experts
    Sportsmith LLC
    Sportsmith LLC
    Howard
    Howard
    Ross Metcalfe
    Ross Metcalfe
    Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
