Question about Fisher and Paykel Dryers
My fisher paykel dryer squeaks model #DE05-US1
SOURCE: help with a noisy Fisher & Paykel dryer
I have the same problem. Replacing the front glides (two glides cost under $20 plus labor and service call). The second time it seems to be more than the front glides. Service tech says that it is the blower moving back and forth on the motor shaft. (Because of a worn indentation on the shaft..). Therefore, he says that I must replace the motor and the blower--parts cost approx. $290, plus labor and service call. Ouch! Also says that the plastic front support piece is worn. More money! So, I am looking at a new dryer instead of trying to patch up the one I have (it's out of warranty.)
Posted on Dec 22, 2007
SOURCE: Squealing Fisher Paykel Dryer DE05-US2
dryer's have a long belt that runs around the drum. a common culprit is an idler pulley on the belt tensioner. you can take off the front of the dryer and oil it for a temp fix. it will probably need to be replaced
Posted on Dec 16, 2008
RescueTech
  • 145 Answers
SOURCE: how do you remove the
Welcome...
You need to look up near the top of the cabinet front, there are screws way up near the top on each side that secure the front panel to the cabinet. Take them out and tip the front forward and then pull up. be careful of the door switch wires.
if you need a comprehensive service manual for that dryer, it can be found here:
http://www.fisherpaykelparts.net/ecart/category.php?category_id=53
Posted on Jan 23, 2009
TheMobilian
  • 8220 Answers
SOURCE: Fisher & Paykel Dryer model ED56 constant beep
Diagnostic Mode
Entering the Diagnostic Mode
(a) Turn the power supply to the dryer on.
(b) Press and hold the Auto Dry down button, then press the Power
button.
The dryer is now in level 0 of the diagnostic mode. After initial entry into the
diagnostic mode, the Start/Pause button operates the dryer as normal. Press
the Auto Dry up or down buttons to scroll through the fault levels.
There are several levels of diagnostics, most of which are used in
development and production. These levels may bring on various LEDs, but
the level of use for the service technician is that of the last fault.
Last Fault
To enter the last fault diagnostics, enter the diagnostic mode as described
above, then press the Auto Dry up button three times. The last fault will be
displayed on the drying progress LEDs.
The manual is here
Posted on Sep 08, 2009
rogrrabbit
  • 986 Answers
SOURCE: my fisher paykel dryer is squeaking it works great
All dryers have to have a way of allowing the tumbler (that's the thing you put the clothes in) to turn freely, not all of them are the same tho,some use bearings, some use slides,others use rollers. Over time these rollers will need to be oiled,the slides will get thin and start metal to metal contact causing a noise, The rear bearings will then start to make their way to china and cause the tumbler to rub into the heating element and OUCH! These things will cause the motor to prematurely DIE! Its best to examine the dryers, rollers, and slides when you first hear the noise, but who does?
Posted on Sep 12, 2009
How to change output vent from side to bottom on my Fisher paykel de05-us2 dryer
It should be able to be accomplished by using an adjustable 90 degree elbow you can buy at a local HomeDepot or Lowes. The elbow should be 4" four piece adjustable ell. The radius of the ell should match perfectly with the knockout on the bottom when slipped over the discharge opening of the dryer.
Mar 04, 2015 | Fisher and Paykel Dryers
How can I find out the part number for a bearing on my fisher & paykel dryer?
Your model number might be DG62T27GW2.
You can get a user manual from this site.
http://www.ajmadison.com/ajmadison/itemdocs/3969_USA_EN_Smartload_Dryer_UC.pdf
To find the part numbers from Fisher and Paykel parts catalogue you need the serial number or product number of the dryer. This should be on a sticker on the inside of the lid. Once you find it go to this site and download a parts manual.
Appliances User and Installation Manuals Fisher Paykel
Sep 03, 2014 | Fisher and Paykel Dryers
Fisher Paykel Dryer Model DE08-US1. Dryer won't start. When pushing the start button, there is a "humm" from the electric motor - like it's trying to start. Very sudden problem. ...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 18, 2011 | Fisher and Paykel DEGX1 Electric Dryer
My dryer is a top loading Fisher and Paykel and it has started squeaking.
It could be bearing or guide in the drum.Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem
Sep 21, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Have a Fisher Paykel model DE05. As long as I hold the start button in it will dry fine. When released it just stops.
heatman101
Sep 15, 2010 | Fisher and Paykel Dryers
Dec 16, 2008 | Fisher and Paykel DE06 Electric Dryer
Getting belt back on dryer
Try this website www.repairclinic.com/SmartSearch/smartsearch.aspx?SearchText=%60Awashingmachine&gclid=CP_yiYL_8ZICFQHBsgodrEYP5A
Apr 23, 2008 | Fisher and Paykel Fisher & Paykel Washer
Open Questions:
Dryers Logo
73 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Bill Eager
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
