Question about Poulan Garden
Poulan pro 5020av starts but will not keep running, What are the hi and low settings?
Starts but will not keep running. What are the carb hi and low settings for this saw
  • 14 Answers
SOURCE: 2375 ''wild thing'' poulan saw hard starting after carb rebuild
Through trial and error on fairly new Poulin Pro, found that the usual 3-half turns for both high and low was too much (flooded) (Used to be good starting point on weed eaters years ago. So, turned both all the way in, and only backed out 1-full turn. (2-halves) Saw fired up perfectly, and ran wide open just fine. Try that.
Posted on Nov 19, 2008
SOURCE: how to adjust carb. settings on a McCulloch Pro Mac 610 chain saw
turn both jets in untill snug (don't force) turn out ccw one full turn. increase by 1/8 turns untill set proper. should be between 1 1/4 and 1 1/2 normally. good luck. be safe.
Posted on Sep 21, 2008
  • 373 Answers
SOURCE: Poulan chain saw after carb rebuild.
Is thereadjustment somewhere on the saw
I think there is 2 .
Posted on Feb 03, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Poulan Wild Thing and Wood Shark Saws try to run, but stall down.
They could be sucking gas from the base gasket, head gasket or the bearings. Also, Check your flywheel very wheel and your armuter, if either are rusty then they need some sand paper to help create spark. There are rebuild kits and they are cheap. I always tell my customers to fix there older machines cause the new ones are **** and they leak everywhere and if anything brakes they are REALLY expensive to repair. You can get a rebuild kit whole machine for about 65 dollars
Posted on Feb 16, 2009
Editor925
  • 285 Answers
SOURCE: chain keeps turning while in the idle position
There will be an idle (Low) speed adjustment screw somewhere on the saw (look in your manual). Adjusting this setting lower will prevent the chainsaw chain from turning in the idle throttle position. Basically you want to set it so the chain has just stopped moving... but you need to set this after the chainsaw has warmed up a little.
Posted on Mar 13, 2009
I want to buy a 16" 3/8 Husky bar that fits the 55 Rancher to replace my 20" bar on my Poulan Pro 5020av...where can I get it?
as long as your 5020av has a 3/8 sprocket it will work they make a professional landowner and homeowner for these saws each costing different prices tell the dearler what your doing and he can decide what you need
Dec 10, 2012 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
How to set carb and idle on poulan pro chainsaw 4218avx
I took carb out changed hoses cleaned hi and low port and all other openings with starting fluid it is high pressure and drys fast and clean put back together now this is were it got tricky the H and L
I put H closed and L almost closed started and now runs great.
it took awhile to figure were they should be some say 1.5 out that was not my case they are very very sensive the idleler screw is barely positioned to open the idle now i have a great education on this type of saw
Apr 16, 2012 | Poulan Garden
I have a Poulan Pro BVM200 blower that will not run. I've cleaned the carb, changed the plug, and added new gas. It will fire up with starting fluid and die within two seconds. I tightened the head and...
turn the needles all the way down to where they just stop dont tighten to tight just when they stop then back them out 1 full turn and see it should start then adjust from there if no start or runs wildly then a carb kit is needed
Feb 13, 2011 | Poulan Garden
Poulan chain saw will not stay running after i start it. What are the carb settings ?
a good starting point is the low speed screw at 1 3/4 turns and the high side at 1 1/2 turns. Hope it helps
May 20, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Pro 42CC 2 Cycle Chainsaw, 18": i can't figure out how to adjust hi low settings d...
They are called "tamper proof" or "tamper resistant adjusters. Amazon has a pretty good set for a reasonable price. Search on Tamper Proof Tool. It's nice the have a set around as you never know what you will run into.
For the Poulan, go to eBay and search on "Poulan Craftsman Walbro carb adjusting tool". You will find what you need there. I hope this helps.
May 16, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Pro 295 won't keep running.
pull the black dust cap on top there are three screws going down, the idle screw is on the left side (if you were holding the saw) near the top of the carb it has a spring around it. the 2 weird screws under that are the mixture screws hi and low rpm you really shouldn't mess with those unless your sure of what your doing. if that doesn't work there is a really small hole ( and I mean small) in the bottom of the carb for a diaphragm if that gets clogged it runs bad, also vibration can loosen the cylinder bolt turn the saw upside down and there are (or should be 4 bolts) make sure they are tight if one already rattled out take the one kitty corner to Lowe's or a hardware store and get a replacement.
Mar 04, 2010 | Poulan Pro Chain Saw 46cc 20"
Carb. settings for poulan 3400
set both of them at 1 1/2 turns out and then fine tune it from there if necessary. This setting is usually right on. Hope this helps you, Jeepfxr
Jan 27, 2010 | Poulan Pro Chain Saw 46cc 20"
Base adjust. on carb high and low needles on carb polen 42 18" thanks
The standard setting on needles is to screw them in all the way and then back them out 1 and a half turns.
You need to set the mixtures for the carburetor. You will find a Low and High adjustment screw. turn the low adjustment screw out. You will notice that the rpms should start increasing. keep turning it out until the rpms start to drop then turn it back in a quarter of a turn. You may need to readjust the idle speed so the chain doesn't turn during idle. Do the same for the high adjustment screw.
Oct 01, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan 3700 will not keep running
SONUNDS LIKE WE STILL HAVE A CARB PROBLEM
Nov 23, 2008 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
321 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
