Question about APC Smart-UPS 1000VA UPS System
Dead UPS--Won't Power Up, Even with New Batteries
I acquired an APC Smart-UPS (in fact, it used to be my UPS at work). When it was last working, one of its two batteries were failing, as it was notifying me so via the Powerchute software utility. When I took it out-of-service, I had some difficulty shutting it down. It did not want to respond to pressing the power switch on the front panel. I was finally successful in getting it to power off, but, as I recall, I wound up pressing both the power button (several times) as well as also hitting the TEST button. One of these combinations finally caused the unit to shutdown. Out of frustration, I think I could have pressed those button(s) pretty hard.... It then sat fallow in my cubical for at least 2-years before the company allowed me to "dispose" of it. My thought was I would purchase new batteries myself, and turn this into a nice UPS for home use. Well, I bought the batteries, and pulled the old ones, re-connected the necessary wires/and 60-amp fuse, buttoned it all up, plugged it in, and pressed the power-on switch, and absolutely nothing happened.... Just nothing. No sounds, no lights, (no sparks). Nothing. Dead. However, I refuse to give up on this thing, because I believe I can fix it if I could manage to find a service manual or something to aid me in checking out the unit. I have since acquired another exact same model, whose batteries had also long since died, (and the company was going to dispose of this unit, too). Therefore, I took it home, pulled the new batteries I had procured for the first unit--and put them into this second unit, and this unit powers up and works fine. This rules out the new batteries. There is something wrong internally in the first unit. As a capable electronics technician (US Navy), I know I could probably fix this unit (if I had access to the proper documentation), and really do not wish to send it off somewhere to be refurbished if I can, at all, possibly help it. I am supposing the power-on switch is as good as any place to start, but if someone on the receiving end of this request has experience and suggestions on exactly what to look for, and how best to proceed, I would be very happy to listen. FYI, I took the whole unit apart and gave it a pretty thorough visual inspection. I saw no evidence of destroyed components, overheating/melting, etc. The internals all look perfectly fine to me. Also, I metered the back panel fuse, as well as the 60-amp fuse in series with the 2 batteries. Both fuses read as a "short", as is proper for fuses :-) Any assistance afforded me in this effort would be appreciated. Regards, Mike Gentry
  • rlme Dec 09, 2008
    My APC Smart UPS 1500VA won't ON..
    Is there anyone experience the same problem with mine ?
    Can you give some possible solution to this'
    Hoping for your eirlier response to my problem...
    many thanks
    Problem Solver:
  • 7 Answers
Http://www.apcc.com/resource/include/techspec_index.cfm?base_sku=SU3000NET&tab=documentation Above is the link to your manual and troubleshooting guide. After that your on your own. These small units like this are throw away units if the battery replacement does not work. Thier cost is so low most times it is better to buy a new unit rather than new batteries.
Posted on Jan 25, 2007
You mention Navy. I wonder if this would help you. Specifically, if your product number ends in X93, it is a shipboard ONLY UPS. The following article will explain further.
http://nam-en.apc.com/cgi-bin/nam_en.cfg/php/enduser/std_adp.php?p_faqid=1125&p_created=1010390400&p_sid=gpgT74Tj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTczLDE3MyZwX3Byb2RzPTYxLDExNDQmcF9jYXRzPSZwX3B2PTIuMTE0NCZwX2N2PSZwX3NlYXJjaF90eXBlPWFuc3dlcnMuc2VhcmNoX25sJnBfcGFnZT0y&p_li=&p_topview=1
Posted on Jan 27, 2010
SOURCE:
Apc smart ups rt 10000 internal fault, what will cause it?
if you can give me the source code I can tell you. the code is going to be in the form of zero's and one's
Aug 21, 2014 | APC Smart-UPS RT 10000VA - UPS ( external...
Apc smart ups rt 10000 internal fault, what to look for?
you should check the inverter and the charger boards as well.
Mainly IGBTs and drivers (IGBT drivers).
better locate the fault and replace the defective board
Hi my APC smart 3000 UPS THE AVR boost LED IN ALWAYS ON. DO I NEED TO CHANGE THE BATTERY?
How many years the batteries working?
Usually every 4 years change the batteries.
Do you have power down often?
Feb 24, 2014 | APC Smart-UPS RT 3000VA UPS System
APC 10kva UPS SUVTP10KH1B2S is not turning on
check the battery bank, and the battery must be in good condition
May 13, 2013 | APC Smart-UPS VT SUVTP10KH1B2S UPS System
APC1000 is totally dead...no lights, no nothing. Was working fine last week with all lights lite! No response to the pushing T or o. Do not know of any long term power outage - there's power to...
Pull out your batteries and check them. The UPS wont restart with out good batteries.
Call Gruber Power Services for free tech. support 800-658-5883 ext.256 ask for Eric
Aug 23, 2011 | APC Smart-UPS 1000VA UPS System
If it's newly bought, let it charge for at least 10 mins. to be able to power on and can be use. If it's not working then call APC Help Center for instructions on how to replace the product with a working one..
Aug 25, 2010 | APC Smart-UPS 1000VA UPS System
Could you tell me how many batteries a matrix UPS 5000 has in it as well as an APC Smart UPS Smart cell
A UPS 500 uses two smartcell batteries. As for the APC Smart UPS, there are different models, but most UPS's will generally use two batteries.
Jun 23, 2009 | APC Matrix-UPS 5000 UPS System
APC external Backup battery is not working plz
It may just need a new battery. The UPS will do a self test on the battery when you turn it on. It may have tried to read the battery and the result came back as "failed". The batteries last about 3-5 years, even less if you live in an area with bad power. The batteries are very easy to change. You can buy replacements at www.batteryinternational.com/apc-backups-es-be350es-ups-battery-ups-batteries-f1.html
Jun 08, 2009 | APC Back-UPS ES 350 - UPS ( external ) -...
APC back UPS 400 fails to give back up
I have the same problem with an apc smart-ups VS 650.
New batteries - charge in batteries is good (also tested under load).
When AC power fails, no power is supplied to PC connectors by the UPS.
UPS self test works fine. UPS does not report any problems via software - Power Management under Windows XP.
Oct 12, 2007 | APC Back-UPS 400VA (BK400) UPS System
SMART UPS APC 3000
let the ups be turned on just charging the batteries, u can have the voltage but the batteries still not fully charged. good luck
Feb 27, 2007 | APC Smart-UPS 3000R3BX (SU3000R3BX135) UPS...
APC Smart-UPS 1000VA UPS System Logo
12,161 people viewed this question
Top APC Computers & Internet Experts
Shawn DuRee
Alun Cox
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
