Question about Kenmore 9781 Electric Laundry Center with Dryer
Kenmore electronic laundry center 417.99195120 E8
5 min after begining a cycle in the dryer, its stops and appears in screen "E8". I already cancelled and changed cycle but still happens. Do you know what this E8 stands for?
5 Suggested Answers
  • 156 Answers
SOURCE: Kenmore Elite HE3 washing machine model 110.45862404
ck pump door lock
Posted on Feb 28, 2008
Master_Tech
  • 770 Answers
SOURCE: HOW DO YOU TAKE THE DRYER OFF?
If it is stack from the factory (ie..came as one peice) you cant
Posted on Jul 26, 2008
  • 1937 Answers
SOURCE: Kenmore 70 Series Washing Machine Just Hums (Won't Agitate)
First, see the Sears Parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.22712100
Also see the Whirlpool / Kenmore service manual.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Initial thoughts are a worn/broken motor coupler.
See the following for how to get to it and check it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135&osCsid=6019c5e82bfa177df953f5d6ebeac983
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
It's possible that the prongs have broken and the humming that you hear is the pieces rubbing against the center rubber piece.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Posted on Jan 10, 2010
Testimonial: "Awesome - Thanks!"
  • 2468 Answers
SOURCE: loud jet noise in spin cycle on Kenmore stackable top load washer
it is the drum bearing seal and it has gone out and ruined the bearings,you would need a lip seal kit and appropriate bearings for that particular unit,i do a lot of maytag front loads and it can take anywhere from 2 hours up to 8 hours depending how the old bearings come out and the damage to the bearing and seal surfaces,the sooner you get to it the less chance of severe damage it will cause,because water will kep on destroying bearings till they lock up and destroy the drive pulley
Posted on Mar 05, 2010
Kenmore 27 in. laundry center won't spin out
The lid may not be mechanically closing the switch even though the switch was replaced
Apr 11, 2013 | Washing Machines
Kenmore 110 60942990 dryer works but takes 3 hours to dry a load.
Venting. When elements or thermostats burn out it is almost always caused by venting restrictions. Vent is plugged with lint, smashed(usually from the dryer being pushed back to far) vent run is too long, or nylon stocking on vent outlet. Also check to see if you can pour water through your lint screen. Sometimes fabric softener builds up on the screen and restricts the air flow. Scrub your lint screen to get this build up off. Good Luck, Appliance Specialists
Dec 16, 2009 | Kenmore 62802 Electric Dryer
Dryer stopped heating
this is likley to be the heat seconsers or its the heater/s burnd out if one of the elements have died on you it will only partly dry the washing,, not a hard job to fix but still a bit pricy,
Oct 24, 2009 | Kenmore 88732 Top Load Stacked Washer /...
Dryer is displaying AF
i got this from the other site.
The code AF indicates that the control senses a restricted air flow. To clear the code, press STOP once and the estimated time remaining countdown will return to the display. The AF code will continue to appear with each cycle until the low airflow condition is resolved.
Try the following troubleshooting to resolve the air flow problem:
  • Clean the lint screen.
  • Check at the outside of the home to make sure that the vent exhaust hood is not blocked.
  • Check the flexible vent connection behind your dryer. Make sure that it is not kinked or clogged.
  • You can disconnect the flexible vent and start a cycle with the dryer venting directly into your laundry room. If the AF code does not appear, this will verify an exhaust vent duct problem. Otherwise you may have a component failure.
  • Have your home dryer venting run cleaned professionally.
hope i was able to fix your problem,
tnx 4 using fixya,
drcool
Oct 04, 2008 | Kenmore 67082 Electric Dryer
Kenmore 9781 Electric Laundry Center with Dryer Logo
23 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
