Question about Kenmore 24 in. 15689 Built-in Dishwasher
Dishlex Hi there, thanks for your quick response. I turned the unit off last night, and tried again this morning. I can see the wash pump on the side and it looks easy to get at, but the drain pump looks a bit more of a mission. are you able to expand a little bit. Should i remove the rinse pump and check that it's not obstructed by anything maybe?
  • Kenmore Master
  • 19,396 Answers
Hi there, now I do not remember the original problem, if there is not water coming into the appliance, start checking the water pump. Also locate and check the water level floarting switch, that stop the pump.
If water is not drained out, then you need to check the drain pump.
Try entering the exact model number here and see if you can get schematics for your appliance.
Posted on Oct 26, 2008
My lifestyle 50 M1 interface is displaying "No response". I have tried all the standard reboot options but apparently I need to replace the capacitors. Can anyone tell me the values of these?
I have had the same issue with LS50 for some time and stumble last night on the blog:
It is written in German though the detail worked perfectly for me this morning.
Bottom line is that they suggest you replace on the P1 unit 4 x caps (C9- 47uF 16V, C10-47uF 16V, C17-10uF 25V, C18-10uF 35V).
I did the work on my unit this morning and all is good - remote now connects immediately to P1 (as it did when new).
Hope that's useful.
Jan 27, 2016 | Bose LifeStyle 50 System
Xperia arc LT15i wont turn on
the charging pin of ur phone is not working properly ..... take it to the service statio they will fix the problem
Nov 06, 2013 | Sony Ericsson Xperia Arc
When wife started car this morning it dumped all the power steering fluid. she hasnt had a poblem since this morning. the resevoir was empty and when i filled it back up it was foamy and drained right...
drained out from where exactly.. a hose , the pump or what..sounds like a pressure valve is stuck and the fluid has no where to go..try to turn the steering wheel slightly side to side and se if the system will kick the valve open or what ..repost findings
Jan 20, 2013 | Cars & Trucks
I want to download a Dishlex DX103 dishwasher manual
want to know as this is my first dishlex dishwasher dx103. As there is no instruction manual being a rented property i want to know how to get solution on my problem. Was working last night but went to put a load on this morning but now have lights and thats it no cycle please help.....
Sep 19, 2009 | Electrolux Dishwashers
I have a Dell Dimension 5100 Desktop that will not turn on.
hi...try to open side cover then find the memory then pull out and clean the pin connectors using Paper Eraser only..thanks...
May 10, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Hi again,
Appreciate getting back to me and the direct "Ask Me".
My last response in the Live Session was:
  • let's try Plan A first. pls have the unit plug back into the mains, wait for about 10~15 seconds to stabilize electronics, press and hold "options" and "select" buttons continuously for 5~10 sec or until a single beep is heard.
Pls try the above procedures and update soon as convenient.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 07, 2008 | Frigidaire GLTR1670A Front Load Washer
Dishlex global 300
try holding the start and program buttons simultaneously for a few seconds, it seemed to reset itself for me-i have done this a few times now.
Feb 04, 2008 | Dishwashers
Hi, did you try taking out the battery and letting it discharge overnight then pop the battery back in, plug the pda into the power mains and try to turn it on again?
Nov 28, 2007 | HP iPAQ hw6515 Pocket PC
Kenmore 24 in. 15689 Built-in Dishwasher Logo
127 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
