Question about GE JVM1650 1000 Watts Microwave Oven
Microwave Oven shuts off by itself - JVM 1650SH03
At first when I used the automatic sensor - for microwaving a potato it shut off before it was done. It did that for awhile. Now it just doesn't work. It shuts off immediately. Is this a fixable problem for the home handyman or should a microwave repair person be called in or should I just throw it out. It 3 years old and not used very much.
Also, are there schematics that I can locate on the Internet or from maybe GE?
Thanks for your help!
I found diagrams on the GE parts website - free!
Posted on Nov 11, 2008
I microwaved something while leaving chinese (metal) container in kenmore 665.61612100 microwave, and it stopped working. What do I do?
The magnetron may have been damaged, the thermal fuse will shut down the microwave to stop further damage and reset itself in 20 to 30 minutes, since that has not happened I recommend a professional at this point.
May 30, 2012 | Kenmore 68361 Microwave Oven
GE spacemaker - JVM 1653 SH unit shuts down after power up. Start back again when cool? Do I scrap it or is it repairable?
For most microwave problems it will cost more then is practical to make repairs to them...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Nov 19, 2010 | GE JVM1650 1000 Watts Microwave Oven
While in use my microwave shut off and stopped working. Could it be a fuse? If it is a fuse where would it be located.
mwaves shut off when they overheat and take a time to recover. This is a failsafe to prevent fire.make sure the unit has plenty of airflow around it and the vents are not blocked off ( hutches are notorious for overheating Mwaves) Sometimes the steam from a potato or a cup of water will overheat the sensor and cause it to shut down.
If it is a fuse the whole outer case hasd to be removed and it's usua;;y top left or right on the inner pod.
please rate my help++++Thanks for using FIXYA
May 08, 2010 | GE Advantium SCA2000B Microwave Oven
Shuts down on potato button only
Not much info to go on here. Are you putting in the number of potatoes vs.the cook time? Most microwave potato functions would not read "5 minutes." It would be read as a request to cook 500 hundred potatoes.
Oct 15, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Turntable and cooking power not working, everything else does.
You have a shorting membrane keypad.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
Feel free to contact me directly (and please include your full model number from the tag in or on the unit) for a free estimate and free tips & do-it-yourself advice.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Oct 05, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Magic chef over the oven microwave shuts off.
Is not normal for a microwave to shutdown after 4 minutes of operation.
From the info you are providing, It looks like the magnetron might be overheating causing the thermal fuse to shut it down until it cools down. There may also be a loose connection in one of the switches or a cold solder joint in the low voltage power supply.
I would suggest to check and make sure that the fans are functional, If always did; it could be that there isn't much air circulation where the appliance was installed.
Mar 03, 2008 | Microwave Ovens
Fire in Microwave Using Sensor Control for Potato
Please contact your home insurance to have the problem logged as a failure of the microwave. The insurance company will most likely help you with the smoke damage to the house and will contact the manufacturer to get their money back... there might be an issue with the manufacturing of these appliances.
Jan 04, 2008 | Amana ACO1860 Microwave Oven
FIRE
Manufacturers will note that they warn in their owner manuals to never leave a microwave running unattended, so they won't help you any further, I'm sure.
Mmost modern microwaves have a flame sensor inside that will shut the microwave down completely in case flames get too high.
Then the cooling fan and power will shut off, and the fire will almost certainly be smothered pretty quickly due to a lack of air inside the oven.
Also, the inside is metal, thus the only fuel for the fire would have been the potato, which would not have lasted long.
So as scary and disturbing as this event was, I would say the real danger of a fire outside of the oven was miniscule.
The fire probably occured due to a dry or irregular spot in the skin of the potato. Once it's dry, it will of course burn much easier.
So now to the smell...
You should do a Google search on "odor microwave" or "microwave smell" where you can find tips on boiling water & baking soda, then vinegar and water in the microwave to neutralize the smell.
If your microwave does not work, then it may have blown the flame sensor (thermal fuse) and that would have to be replaced.
Please let us know if we can help further.
Nov 15, 2007 | Kenmore 62702 Microwave Oven
Magic chef microwave shuts down
We had the same problem with our brand new Magic Chef. Before going through the trouble of taking it back I called Home Depot. After talking to a Home Depot Rep I am told that the overheat sensor is under the glass plate directly beneath the popcorn bag. Popcorn gets very hot and the heat of the popcorn causes the sensor to shut the machine down. I would imagine this would be the same for a baked potato.
Very poor design.
I was told to put a microwave safe plate down and put the popcorn bag on it. This should help to reduce the heat and not trip the sensor.
A safety sensor is great, but not if it keeps tripping the machine and shutting down!
Sep 02, 2007 | Microwave Ovens
GE JVM1650 1000 Watts Microwave Oven Logo
180 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
