Question about Sewing Machines
I need a manuel for amitsubishi DB-170 sewing machine
I have bought an old industrail sewing machine mitsubishi DB-170 an do not have a manuel.I have several ways to thread it but it is still not working. If anyone can help me that would be great .Thanks Jan
SOURCE: Sewing Machine
check if you are using the original bobbin... There are some similar bobbins but they are not the same...
Posted on Sep 05, 2007
bargainbox
  • 1388 Answers
SOURCE: HUSKY DELUXE SEWING MACHINE
Your local Husky dealer or via their head office in your country ought to be helpful unless they are out of print.........if so, ......Try sewusa.com or sew4less.com
Posted on Jun 02, 2008
SOURCE: Shark Euro-Pro Sewing Machine
I had the same problem with my Shark Euro Pro 7133. My problem was in threading the upper thread. The manual does not quite explain so I had to figure this out the hard way.
In threading the upper thread . the thread first goes down from the spool througt a groove. When it comes up it must catch a silver lever that moves up and down before moving it down againPlease let me know whether this helps.
Posted on Jul 26, 2008
  • 323 Answers
SOURCE: how to thread sewing machine
Yes, but it is a good basic machine.
Here's how to thread it:
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
Posted on Mar 20, 2009
Mimito7
  • 128 Answers
SOURCE: I need a manual for a Mitsubishi industria sewing
Hi there, Have you tried www.2instructions.com ?
They have alot af manuals.
Posted on Apr 23, 2009
Why wont my Bernina 170 QE embroidery unit work
Electronics fail eventually. It is a bummer because I bet you love your old Bernie. Electronics are nothing for the novice to mess with unless they have loads of component level experience. I would take this to your sewing tech and have them check it out. (maybe get a new one?)
Jul 21, 2014 | Bernina Artista 170
Nee Elna Envision 8006 ownersw manuel
see if the link for a manual is the right one for the machine Elna 8006 Instruction Manual
Apr 19, 2014 | Sewing Machines
I need an extension table for my Husky 170 Sewing Machine.
Ebay or Etsy... sometimes has "parts machines" or just parts.
Mar 19, 2013 | Husqvarna Husky 170
I'm not a seamstress by far lol,bought a used sewing machine and need the instruction manuel. does anyone know how i can get one?
Check on-line for that make and model...you might be able to either order one or download a copy directly from the company themselves...that's how I got mine for my Janome and how I was able to fix my machine myself by getting the instructions to do a reset and save myself a couple of hundres dollars
Sep 13, 2012 | Brother LS-2125 Mechanical Sewing Machine
Machine skipps stiches whats wrong
You need a heavy duty needle #16 or #18 to sew leather and teflon presser foot is helpful
Apr 15, 2010 | Singer 7442 Mechanical Sewing Machine
Breaking thread
What type of machine to you have? I sew on a industrail machine and I can not use the small stools of thread. I have to use the large spools. The 3 for a dollar thread to me is thin. Try upgrading the thread. Try some silicone spray. And also check the tension, it may be to tight.
Aug 08, 2009 | Kenmore Sewing Machines
MITSUBISHI DB 130G threading instructions
I am looking for a manual for the Mitsubishi relsew DB-130. I need to know the best way to thread the bobin and the correct way to put in the needle. I will take a photocopy of the manual if someone has one?
Aug 02, 2009 | Sewing Machines
Apr 23, 2009 | Sewing Machines
Machine vibration
check to see if the machine is setting securely on the quilt frame .also check to see if the frame is setting level on the floor
May 01, 2008 | Janome 1600P-DB Mechanical Sewing Machine
Sewing Machines Logo
191 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
