Question about Dryers
HAMPTON BAY REMOTE #UC7052 DOESN'T WORK WELL - Dryers
SOURCE: Hampton Bay Ceiling Fan - Clarington 503837 52"
It slides in above right above the ball, in the mounting bracket where the canopy is. You may have to kind of encourage it to go in there, and you will need to push wiring off to the sides and out of the way to help it have clearance to get in there.
Posted on Apr 15, 2008
  • 157 Answers
SOURCE: hampton bay fan, wall mount remote control
Hello burrow31. There maybe a switch located on the fan stating 'remote/manual'. Check your manual. Remove the battiers in your remote and short out the battery contact terminals. Reinstall the battiers, start the fan and after fan has reached set speed press & hold fan speed button for one second. Still no speed change contact the Mgfr. with model & serial #.
Posted on Oct 13, 2008
  • 75 Answers
SOURCE: Hampton Bay 60" Brookedale fan remote not working
The Remote (TRANSMITTER) control AND the RECEIVER must both be set to the same CODE in order for the REMOTE to operate the fan.
!!WARNING!! YOU ARE ABOUT TO ENTER HIGH VOLTAGE ELECTRICITY ZONE!!
The RECEIVER is located in the CANOPY, the part of the fan assembly next to the ceiling which is also called the Hanger Bracket.
At the bottom of the Canopy you will see what looks like a large flat washer. Rotate the washer counter-clock wise to release it.
Then rotate the Canopy counter-clock wise to release and lower it. You will see the RECEIVER, which will have a short antenna at one end, tucked in among the electrical wire and bracket. Simply pull the RECEIVER out and you will see the CODE switches. Remember to set both devices to the same CODE.
Good luck. :)
Posted on Apr 26, 2009
  • 3 Answers
SOURCE: Lost Instructions for Hampton Bay remote control 838956
Go to www.kingoffans.com and follow the site. They are the makers of Hampton Bay.
Posted on May 24, 2009
  • 87 Answers
SOURCE: my hampton bay remote control fan doesn't work for
Your recever in the fan is bad if this is a new unit take it back to the store and they will give you a replacement, I have seen this problem on this model before.
Posted on Oct 03, 2009
Remote wont work for fan.
http://www.ehow.com/how_6104129_instructions-hampton-bay-fan-remote.html You may need to reprogram the remote
May 15, 2013 | Televison & Video
My Hampton Bay Brookedale ceiling fan worked fine for a while. Went to turn it on the other day and won't work. Ceiling fan remote seems to work (light goes on when buttons pressed) but fan or l
The light on the remote is a battery light. First mistake was buying a store brand fan which are mostly low-end parts. Try adding a different remote w/receiver.
Mar 02, 2013 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
Ceiling fan remote control doesn't work
Sounds like you have an add-on remote. Try changing the frequency in the receiver & transmitter. If that doesn't work you probably need a new receiver.
Feb 03, 2013 | Hampton Bay Dryers
Installing a Hampton Bay Trieste ceiling fan, and I don't know where to locate the remote receiver. It doesn't seem to fit in the canopy or the fan base. It is rectangle shaped about the size
If it's a thin rectangular receiver (probably has UC7067 printed on it) It "slides" into the mounting bracket up by the electrical box. If this doesn't help you can call toll free 1-866-600-3267 at http://www.fanmanlighting.com/default.asp and ask for Jack Jr
Oct 15, 2012 | Hampton Bay Ceiling Fan. Trieste 52 in....
Ceiling fan with remote control stopped working suddenly, ruled out battery for remote control, because I changed a new one, ruled out circuit since everything is working, I don't have a pull on the...
with Hampton Fans,, normally if the remote is good with a known good battery , and it quits working,, its the remote receiver, not the actual remote that goes bad. you can contact these guys I heard they have the part you need http://www.ceiling-fans-n-more.com/hampton-bay-ceiling-fan-parts.php
Sep 07, 2011 | Hampton Bay 24750 Huntington III Ceiling...
Purchased Hampton Bay Ceiling Fan, Midili White 44", Model #71606 with remote from Home Depot. I have 2 switches wired to the lattter with 1 for the fan and the other for the light. Can I install...
Yes, you could, but you want have any way to control the fan speed. Unless, you install a rheostat that is rated for electric motors. A light dimming rheostat is not heavy duty enough, to handle the fan motor without over heating.
Hope this helps you and thanks for choosing FixYa.
Aug 25, 2011 | Hampton Bay Heating & Cooling
Changed batteries in remote fan still doesnt work hampton bay model uc7083t
If you're gettig a red light whenever you press a button on the handle remote, That means the hand held is working. There are also batteries in the receiver , inside the fan's cowling. They need to be changed too. Also, be sure the wall switch is ON. The remote has no control, if the wall switch is OFF.
Hope this helps and thanks for choosing FixYa.
Jul 28, 2011 | Hampton Bay Heating & Cooling
I have a Hampton Bay Cieling fan, model # FAN- DH L3H2003, and the remote control does not work. How can I get a replacement?
before you buy a new hand-held remote ... have you changed ALL the batteries. There's a set in the hand-held remote and batteries in the receiver, which is behind the fan's cowling. If you haven't changed them all, I'd do that before investing in a new remote control.
if you find, after changing all the batteries, you do need a new remote control, here is a link to one for all Hampton Bay Ceiling Fans.
http://www.homedepot.com/h_d1/N-5yc1v/R-100071965/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
Hope this helped you. Please let me know. Thanks.
Jun 01, 2011 | Hampton Bay Heating & Cooling
Remote control, changed battery, still nothing
There is a a major ceiling fan manufacturer in Fort Lauderdale FL called King of Fans (website: kingoffans.com) that deals strictly with Hampton Bay ceiling fans & parts. They are the Home Depot distributor for Hampton Bay ceiling fans. Their number is 1-800-330-3267. There is also a 1-877-527-0313 number for Hampton Bay products other than ceiling fans...
You can also try ebay for OEM replacement fan remotes for various brands including Hampton Bay...
Nov 25, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Dryers Logo
Top Dryers Experts
