Question about Keurig Platinum B70 Coffee Maker
Keurig blown fuse, plugged into 220 volts.
Deployed to Afghanistan, New machine was accidentally plugged in to 220 volts. Can anyone tell me where to locate and replace the fuse??
3 Suggested Answers
  • 248 Answers
SOURCE: I have a 110 volt Keurig coffeemaker from the U.S.
find a power converter to change voltage
Posted on Oct 08, 2010
SOURCE: Does Keurig manufacture a coffee
No they do not; I emailed Keurig Customer Service several times and received the same response each time; Keurig stated the EU has not approved the use of their devices in Europe. They have no 220v coffee makers that we can buy here in the U.S> and do not sell their K-cups in Europe. I am moving there next month and will take the easy way and just buy something when I get ther
Posted on Apr 09, 2011
My Keurig was accidentally plugged to a 220 v outlet instead of a 110. Need a repair shop located in the Philippines. . It won't operate anymore.
Chances are pretty good that you blew a fuse in the unit. I think it would be worth it for you to take it apart and check. If there is not a fuse you have lost nothing.
Nov 13, 2014 | Keurig Elite B40 Coffee Maker
How can I tell if maker is wired for 220 or 120
If its been changed to 220V plugging it into 120V won't damage anything, it just won't work. Replace the plug with a 120V plug end and plug it in. If it works its120 if it doesn't, its either a 220V setup, or you have a blown fuse in the unit/power supply or some other defect.
Nov 04, 2014 | Bunn CWTF Coffee Makers & Espresso...
I plugged 110 volts xbox 360 into 220 volts outlet. and it's dead. what will i do?
Unless the item has internal fuse, it is burned up.
Look for product manual.
Many times, there is a glass fuse rated for unit voltage.
Replace fuse.
Each fuse has specific markings.
Oct 17, 2012 | Microsoft Xbox 360 with Kinect
Hi, I stupidly turned on my brand new Francis X7 machine without using a transformer (I bought it from the US, used it in Malaysia), and of course, something blew, and it now doesn't work at all. Any...
The machine is made to work with 120 volts and you have plugged this on a 220 volt mains circuit thereby blowing up the fuse, or the power circuit, possible heater and the main controller unit board.
A step down transformer was needed to work this unit safely . Now unless the unit is opened the damage cannot be confirmed but if you are lucky the fuse would ahve blown and saved the rest. if so test it with a new fuse using a 220 to 120 volt convertor.( transformer with good rating)
Jul 05, 2011 | Microwave Ovens
I accidentally plug my aiwa excelia cd player model xc-003 to 220 volts instead of 100 volts. Iheard a small popping sound when i plug the unit to 220 volts.
If you're lucky you'll have just blown the internal fuse.
You need to remove the cover and look for the little glass fuse on the PCB where the power cord comes in. If it has blown then look at the metal cap on the end of the fuse and is should tell you what rating it is (2A etc). You should also check to see if any other components appear damaged before replacing the fuse.
May 03, 2011 | Aiwa Audio Players & Recorders
I plug it in 220V
Do I understand you plugged this device into 220 Volts? Is this a machine designed for 110 Volts? Check the fuse - if it is burned out (as I suspect it will be) replace it. If the machine comes on - check out its operation. If it does not come on - I think that is the end of the road for your machine. To get to the fuse, remove the cover. Find the fuse near where the cord enters the cabinet.
I don't know where you live (please do not say) nor what the prevailing standard house hold voltage is. I don't know where you got the oven and please don't say. I really don't understand how you accidentally plugged a 110 Volt machine into a 220 volt outlet - that would be interesting to hear about.
Thank you for your interest n FixYa.com
Mar 09, 2011 | Microwave Ovens
My drier 110 volts was accidentally plugged to 220
The least of your problems would be a burnt out relay or internal switch which can be replaced at reasonable expense. In a worst case the motor or heating element "fried" and it'll be cheaper to buy a new dryer.
BTW 110 and 220 plugs are entirely different and a 110 plug cannot be plugged into a 220 outlet.
Apr 16, 2010 | Whirlpool LGR5636L Gas Dryer
The power supply of my pioner dvd was burn
Hi
check all semiconductor in the power board and look for a shorted and open parts! then replaced the defective parts.
Thanks!
Dec 05, 2008 | Televison & Video
Blown fuse
usually these step up transformers are design for one appliance at a time , let me know the brand and model number of transformer so I can get the specs info , does the stereo also shuts down?? let me know AJ
May 09, 2008 | Samsung DVD-V4600 DVD Player/VCR
Keurig Platinum B70 Coffee Maker Logo
112 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
