Question about Panasonic PT-47WX51 47" Rear Projection Television
Cleaning I need to remove the main screen to clean inside. I've had several flys get in there and as a result have specks and smears (all black) being projected on the screen. How do I remove it (the screen and bezel)? My guess is all the screws around the perimiter from the back? Any secrets I need to know?
If you go in the back, you can clean the screen from the back without removing it. Be careful not to scratch it. If you have one, try a feather duster first. Also while you are in there, clean all three color tubes, Use a mild cleaner or just water as the lens may be coated and strong cleaners may remove the coating. Ours went 7 years without cleaning and the only question is why we could still see a picture.
Posted on Mar 23, 2008
SOURCE:
IWL16 mildew or black specks on clothers
could just need a good clean. these machines remove dirt from clothes very well, but it can build up on the inside of the outer. disconnect power, remove top (two screws under covers under lid), remove top bowl ring (8 clips) remove agitator (1 screw deep inside) remove inner bowl. scrub it. also trying a hot wash with some cleaning product to flush the machine every couple months can stop this happening in the future.
Nov 10, 2013 | Fisher Paykel EcoSmart GWL15
Consistent dots down print
Try to print clean page ,
Print a cleaning page During the printing process, paper, toner, and dust particles can accumulate inside the printer and can cause print quality issues such as toner specks or spatter, smears, streaks, lines or repeating marks. Follow these steps to clean the printer's paper path.
  1. Load copier-grade paper (not bond, heavy, or rough paper).
  2. On the printer's control panel, touch the Menu button.
  3. Touch Configure Device .
  4. Touch Print Quality .
  5. Touch Process Cleaning Page .
A Cleaning message appears on the printer control panel display while the cleaning is taking place. The cleaning process takes a few minutes to complete. Do not turn the printer off until the cleaning process has finished. A page will be printed when the task is complete. Discard the page. You might need to repeat the cleaning process to thoroughly clean the printer. Print a few more pages to see if the problem is resolved.
Mar 20, 2013 | HP LaserJet 5550DN Printer
There is a black dotted line whenever I make copies on the cannon imagerunner 400s
It's either a speck on the scanner glass for the document feeder, or a smear of toner on one of the rollers. Check the skinny band of glass inside the document feeder for specks and clean it with a lint-free soft cloth and a little rubbing alcohol or a very little bit of water.
May 30, 2012 | Canon imageRUNNER 400S Copier
I am getting white specks on all four colors on my phaser 8500 and some black smudges. I just did a smudge clean and it helped, but it didn't clear it.
Hello.
Try a laser printer roller cleaner (paper sheets), like PathKleen or Perfect Data. You may need to run sheets through several times before the cleaning is complete. Do not use a sheet more than once.
Hope this helps.
Feb 03, 2011 | Xerox Phaser 8500/SN Color Laser Printer
Black spot on pictures - cleaned lenses and inside
The spots can be in the inside of the lens settings to the CCD/imager.
If the cleaning of the lens is done well it can be a speck of dust logged in to the screen and having it on the image.
A careful cleaning in a dust proof set up is required.
Sep 25, 2010 | Nikon D50 Digital Camera
Epson Stylus C86 smearing
Your printer has ink build up inside it. This comes from cleaning cartridges and builds-up steadily over time. Remove top cover. Wet a cotton swab with isopropyl alcohol (available at drug stores) and clean the inside. use a cotton bud where the swab gets entangled.
Aug 07, 2009 | Epson Stylus Photo 1290 InkJet Printer
My iP6700D won't print black either!
Your printhead is plugged and cleaning can't help a lot. It'spossible that the purge unit is not cleaning properly, in which case a new printhead could be ruined in a short while. Otherwise if you aren't printing something at least once a week, the ink has just dried in your printhead and you need a new one.
Aug 07, 2009 | Canon PIXMA iP6700D InkJet Photo Printer
Smeared lines
Okay, this was the problem I posted a few days ago. It's fixed now, so in case you have the same problem with smearing, here's what the help desk from Canon suggested: Open the cover and remove the ink cartridges. There is a gray lever in front of the cartridges. Lift this lever and the printhead can be easily removed.
Our printhead had a buildup of black ink on the surface. I carefully removed this with rubbing alcohol. I let the printhead dry and replaced everything. No more smearing. Imagine a help-desk that actually helped!
Nov 16, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Black particles on focusingscreen
If the specks are just on your viewfinder focussing screen, they won't be on your pics. If they're on both your pics and focussing screen, you need to find someone else to clean your camera. Cleaning either your CCD sensor or your screen yourself can leave scratches. Changing lenses often can suck dust into the inside if the body is dusty. Try another repair shop for thorough cleaning - it shouldn't cost more than $50.
Dec 17, 2006 | Nikon D70 Digital Camera with 18-50mm Lens
Panasonic PT-47WX51 47" Rear Projection Television Logo
64 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
