Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Frigidaire d. w. grit and white film on glasses
  • Official Brand Answer
  • 2,267 Answers
Good Morning Friend,
I see that you are receiving grit and a white film on your glasses, in your Frigidaire dishwasher, model# FDB1050REC. Here are some common solutions that you can begin with.
-Check your water hardness. Hard water can cause lime deposit buildup on the interior of the dishwasher. Dishes and glasses may also get spots and film for a number of reasons. To remove buildup, spots and film, clean using the following instructions:
1. Load clean dishes and glasses in a normal manner. Do not load any metal utensils or silverware.
2. Do not add detergent.
3. Select the NORMAL WASH cycle. Close and latch door. Press START/CANCEL pad.
4. Allow your dishwasher to run until it starts the second water fill (approximately 10 minutes).
5. Unlatch and open the door, and pour 2 cups of white vinegar into the bottom of dishwasher.
6. Close and latch the door and allow the cycle to finish.
For extremely hard water, it may be necessary to install a water softener.
-Your water temperature may be low. Avoid extremely low or high temperatures.
-Avoid overloading and improper loading.
-Make sure you are using fresh detergent. Old detergent is ineffective.
-Make sure your rinse aid dispenser is filled.
-Check to see that the proper amount of detergent is being used for cycle selected.
-Your home water pressure may be too low-it should be 20 to 120 pounds per square inch (psi).
If none of these suggestions helps, I would suggest contacting either the manufacturer or a local authorized technician. Hope this helps.
-Best Regards-
WP
Posted on Apr 09, 2014
3 Suggested Answers
  • 677 Answers
SOURCE: I have a FDB8986GCS0 that is not getting the
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Posted on Mar 30, 2010
news775
  • 699 Answers
SOURCE: New Frigidaire dishwasher installed week ago. All
You need to adjust the water softener setting on the machine.
THe machine takes dishwasher salt and needs to be set to the hardness level in your area (water company will tell you the value) or some machines come with a test strip to test.
Please dont forget to vote this answer was helpful
Many thanks
Posted on Feb 13, 2011
In florida, water carries a white film and it gets over the glasses - dishes and etc.
It's happening all over Florida (and anywhere there is hard water). There's a new Florida company with a solution. Search for CitriClean of FL
Aug 02, 2011 | Frigidaire 24 in. FDB750RCC Stainless...
We get a white film on the dishes, glasses and plastic glasses in the upper tray of this new dishwasher. What is the cause and what is the solution?
If you have hard water glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1/4 of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Feb 11, 2011 | Frigidaire FGHD2433K 24 in Builtin...
There always seems to be a sandy grit substance on my dishes especially glasses, what do you suggest? thank you
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle. Make sure that your soap dispenser drawer is opening and closing fine.
Hope this helps... Please post back if more information is required.
Daniel
Jan 26, 2011 | Hotpoint 24 in. HDA3740G Stainless Steel...
My ADB 2200 appears to have a rinse problem. the glasses, cups, plates etc have a residue or grit attached after the entire process is finished
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Jan 20, 2011 | Amana 24 in. ADB2200AW Built-In Dishwasher
Frigidaire dishwasher FDB1500LFCO is not cleaning dishes properly. Glasses have a cloudy apprearance, other dishes are not clean, silveware is a mess. Have hard water so am using LemonShine for hard...
heatman101
Dec 28, 2010 | Frigidaire FDB1502RG Built-in Dishwasher
I keep getting grit on my dishes, I have changed dishwashing agents, rinse agents, and done evrything I can think of to stop this. what else can I do?
Hi
Daniel
Oct 25, 2010 | Frigidaire Dishwashers
I have washed and rewashed my dishes with no soap and my glasses have a horrible white film and any of my plastics now have white film almost as if the soap is not rinsing off. I have resorted to hand...
heatman101
l'l
Sep 25, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
White film especially on ziploc containers and utensils. Glasses come out spotted and clear glass dishes are streaked with a white film
Hi
Daniel
Aug 07, 2010 | Dishwashers
My Frigidaire dishwasher is leaving soap, a lot of soap, on dishes under where the dispenser dispenses. It just started hapening. Also, it has always left a light film on the clear glasses.
I scrubbed the screens with a brush and added two cups of white vinegar to the bottom of the washer, then ran it. Cleaned up nicely. I most likely will add a cup of vinegar once a week.
Sep 13, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
I have a FDB8986GCS0 that is not getting the dishes clean. No matter what I use. Sometimes there is brown grit on dishes or white film on glass.
Jun 27, 2009 | Frigidaire 24 in. FDB635RF Built-in...
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
122 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
