SOURCE: Panasonic HDTV 1080i Lamp out
If the lamp is actually out - replace it - if the lamp is still working just reset the lamp hours - at 10,000 hours it automatically says that but it is just the lamp time needing a reset.
SOURCE: finding mirror glass replacement in projection tv
mirrow broke in transport philips 65in model 64P9161006
SOURCE: Samsung HDTV 1080i pictures doubled and theres rainbow colors!!!!
The convergence is dead.U know how to solder?Buy the kit with ur tv name and model.
Replace the parts in that kit.Should be back to normal itself.Or have to go to the menu see the convergence make miner adjustment.
Tries this website.TV Repair World.com have kits and instructions for many DLP tv's with this prob.
Testimonial: "I really appreciate your help. Thank you soo much!"
SOURCE: convergence panasonic HDTV 1080i bbe hi definition
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herehttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
We have a blue line across the bottom of our screen how do we fix it?
