Question about Minolta Office Equipment & Supplies
How to reset the transfer belt of a bizhub c360 machine
I there a fuse in the transfer to be replaced
  • Minolta Master
  • 6,161 Answers
Yes there is a fuse in the transfer belt
Posted on Feb 19, 2015
SOURCE: Transfer unit Bizhub C250
reset life of actual transfer
Posted on Feb 14, 2009
  • 12 Answers
SOURCE: how do you reset the life of the transfer unit on the Bizhub C250
Yes,
Remove Trasfert belt unit.
On the left handled remove one screw ( spring fixer) and remove right srew (over the belt / bar whit finger fixee).
Remove, on the left spring stoppage and metal handled.
Remove black little srew and take to hand fuse contact.
Change fuse (behind) with new identical fuse and reassembly.
It may be reset trasfert belt counter.
Sorry for my not good english.
Bye.
Posted on Mar 20, 2009
  • 12 Answers
SOURCE: Reseting counter after installing new image transfer roller unit
You need to go into tech rep mode to reset.
press: stop 0 0 stop 0 1, then 0 0 0 0 0 0 0 0, press enter, then press counter on the left, select life, then highlight image trans roller and press the C button, repeat for paper dust remover and exit tech rep mode
Posted on Apr 06, 2009
SOURCE: Bizhub C450: After replacing the image transfer roller & ozone
In Service Mode -> Counter -> Life -> Select the one you want to reset and press 'C'
Posted on Aug 23, 2009
jqsababa967
  • 145 Answers
SOURCE: Need to reset the fuser and transfer belt alarm in
can not be reset .it has to be reset manualy by a technician or replacing the units...
Posted on Mar 01, 2010
Please how do reset transfer unit unit on konica Minolta bizhub c-252
for reset belt unit you have to change one fuse.
You need a new 50-80 ma fuse.
Remove the belt from the machine, the fuse is in the left side of the belt, under the left handle.
Replace it with a good same fuse.
For detailed guide see the link below:
Konica Minolta Service Manual
Aug 06, 2016 | Konica Minolta bizhub Office Equipment &...
Bizhub c224
In order to enable this function, you will need AU-101 / AU-102 Biometric Finger Vein Authentication Device. These biometric finger vein readers connect directly to the MFP and work in conjunction with the machine's internal authentication capabilities, or integrate with Konica Minolta's PageScope Enterprise Suite.
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Aug 19, 2014 | Konica Minolta Bizhub C224 Color Copier /...
How to know Transfer Belt fuse is gone
The fuse blows as soon as its put in the machine. Thats how the machine knows to reset its count
Dec 20, 2013 | Konica Minolta bizhub 250 All-In-One Laser...
How to know bizhub c451 Transfer Belt fuse is gone
The fuse blows as soon as you install the transfer belt. Thats how the machine knows it has been replaced.
Dec 20, 2013 | Konica Minolta bizhub C250 All-In-One...
After BizHub C450 copier has stopped and said replace Transfer Belt, is there anyway to get back up running until new belt shows up
Remove the transfer belt unit and change the chip fuse on transfer unit.The fuse is or a little green pieces or glass fuses ,the value 0,065mA/250V rapid fuse.After change the fuse pull on the unit and turn ON the copier.Before change the fuse reset the transfer belt counter in the Present parts life mode.
Mar 29, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
C13c8
C13C8 A new installation is not detected when a new Transfer Cleaner Unit (Image Transfer Belt Unit) is installed.
When a new transfer belt unit is installed in a machine an internal component on the transfer belt unit changes state; this now indicates that the transfer belt unit is used
http://kmcopierservice.blogspot.com/2011/02/how-to-reset-transfer-belt-bizhub-c203.html
Apr 10, 2012 | Konica Minolta bizhub 350 All-In-One Laser...
I have a konica Minolta bizhub C250 and the screen is reading "replace transfer unit" and "replace fusing unit". I contacted a local repair guy that said he might be able to reset the counters and the...
I can only tell you they are definately resettable as I do it all the time.
The fuser "fuse" is located in the connector wiring. Once you get the fuser out just look in the area where the large connector is. It is a very small fuse similar to a resistor, green, and is encased in shrink wrap.
The Transfer belt fuse is behind a small black cover. If you pull the transfer belt unit out of the machine about 6 inches, it is located on the front right corner. In other words standing in front of the copier with the belt unit partially out it is on the corner closest to you. You have to remove a screw, a c-clip, a small metal plate and the small black cover is held on with a very small phillips screw.
He is the parts availablitity and part number info.
Fuses are available at http://www.digikey.com/
Transfer Belts
Replace glass fuse 80ma , counter resets automatically.
Item # 507-1218-ND
Fuser Units
Fuse is wrapped in shrink wrap. Cut it out and splice in a 1/16 ma fuse.
Item # F2307-ND
Good Luck and Thank You for using Fixya.
Oct 08, 2010 | Konica Minolta bizhub C250 All-In-One...
Where can I get instructions on how to replace the transfer unit of my Bizhub C252?
Please visit the site http://www.resetkit.eu
There you can find how to reset your fusing unit and transfer kit unit for almost all Konica Minolta MFP's and printers, Bizhub C252 included.
You don't need to replace it, you can just reset it and save a lot of money.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
Oct 22, 2009 | Konica Minolta bizhub C250 All-In-One...
846 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
