Question about Kenwood KR-V8080 Receiver
Kenwood KR V8080 receiver
My receiver quit working when one of the speaker wire tips brushed across one of the receiver's power cord prongs while it ( the receiver)was plugged into the 110v outlet. This happened when I was messing around with the cords and cables behind my entertainment center, and the power cord was not pushed in all of the way. Since that time, the "Main Power" on/off switch powers up okay and the power light is on, however when I push in the "Remote Power" button the unit turns on for 1 second and then shuts down. After this the "Main Power" light flashes on and off. There os also a click simultanious to the unit shutting off that is coming from a small blue plastic box that is near the fuse in the back of the unit. Can you give advise as to what is wrong? The fuse appears to be okay.
    Scholar:
  • 119 Answers
If you sent 110v down the speaker wires & into the amp you most likely have damaged the audio outputs or the output ic. Look for a big aluminum heatsing & on one side you may find 1 or 2 ic's or numerous transistors, the ic's are hard to check, the transistors are easier to check, if transistors replace in pairs. also check for burnt /open resistors near outputs
Posted on Nov 02, 2006
SOURCE:
Kenwood KR-V8070 has power but audio quit working. Speakers work fine.
Can you hear the speaker relays clicking on ? unit might be in part protection
Jun 07, 2014 | Audio Players & Recorders
How can i repair amp
Looks like the amplifier output transistors have blown (hence the pop). Quite expensive too repair - I would have a look on eBay for a cheap used but working Kenwood receiver, it would probably work out cheaper.
May 10, 2014 | Kenwood Audio-video Stereo Receiver Kr...
I have a Kenwood kr-v8010 and all a suddenly one channel is only working just woundering if its a easy fix?
Could be a speaker wiring issue, defective speaker or possibly a speaker protection fuse inside the unit has blown.
1. Check speaker wires for proper connection.
2. Swap left and right speakers to see if the problem follows the speaker.
3. Check for internal speaker fuse that may have blown. PLEASE proceed with caution inside the unit. With the AC cord unplugged there are still high voltages resident inside...BE CAREFUL!!
Oct 31, 2012 | Audio Players & Recorders
I have a kenwood KR-V8080 and i had 4 subwoofers hooked up to it. then one day it jus shut off an smoked a little. now when i turn it on an try an hook up speakers it sparks an the speaker pops. i dont kno...
You blew the amp. If you were running 4 subwoofers off of a dual channel amp you most likely running them bridged off of two different outputs. You most likely blew the resistor and because it was pushing more power then it could handle. Also when you bridge speakers it brings down the impedance which allows for the more power to course through. Suggestion is to buy a new amp that can handle 4 subs or 2 different amps for both sets.
Sep 13, 2012 | Car Audio & Video
Hi, My friend (who has a visual impairment) moved house recently, they own a Kenwood KR - V5570, I assisted with re setting up PC etc. I am now baffled with connecting her left and right speakers to this...
If you keep guessing you may succeed in blowing something up.
The cables have RCA connectors or bare wires for a reason.
Get the manual out and read it.
Register and download it for free at retrevo.com
http://www.retrevo.com/support/Kenwood-KR-V5570-Receivers-manual/id/479bh938/t/2/
Don't pay too much attention to the actual colors of speaker wire. Use the colors as reference. Each speaker has a plus and a minus. Connect them to corresponding plus and minus for their respective amplifier outputs.
Jul 04, 2011 | Kenwood KR-V5580
Yesterday, I connected two speakers to my Kenwood KR-V7070 Receiver and it worked fine but today I can't hear anything coming out of the speakers. I may have pressed a wrong button on the remote. Also,...
Tell us some details about the speakers.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Kenwood-KR-V7070-Receivers-manual/id/479bh947/t/2/
Familiarize yourself with the controls. Understand every indicator on the front. There may be a clue there. Turn the volume to a medium or low level before changing any settings or you may be in for a BIG (and costly) surprise when you find the one that was in the wrong position.
Let
Mar 02, 2011 | Kenwood Audio Players & Recorders
Where can I download an owners manual for a Kenwood KR-V8080 tuner/amp. Thanks
You can download at:
http://www.kenwoodusa.com/z_Support/Home_Electronics_Owners_Manuals/
Select your product number from the list and the download link will appear below. Four thumbs, please.
Jan 05, 2010 | Kenwood KR-V8080 Receiver
I have a Kenwood KR-A4010 Am/Fm Stereo Receiver. Every five seconds the sound fades in and out. Can anyone find a solution to this problem?
Something in the unit is smoked and potentially dangerous. Get that puppy down to a repair shop. Don't leave it unattended if you turn it on. Got a fire extinguisher handy?
Apr 28, 2009 | Audio Players & Recorders
505 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
rigger094
Mike Duncan
Mike Duncan
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
