Question about Home
My triton shower keeps dripping from the shower head when its turned off
5 Suggested Answers
  • 44 Answers
SOURCE: Triton T80si shower will not switch off
its the water solenoid valve stuck in the open position so when the shower is turned off the shower stays running
Posted on Dec 15, 2008
co7196
  • 3433 Answers
SOURCE: shower head dripping cant turn shower knob off
Mixer valve needs repair. special tools required.
Posted on Aug 22, 2009
jeff_drakesr
  • 155 Answers
SOURCE: i have a drip, drip, drip from my shower head on
A shower head will drip for a period of time but I will assume that it is dripping continually. Servicing the Mixing Valve is what is needed to fix the continual drip. there are several 'O' rings washers that eventually wear down causing problems. These parts are serviceable and kits with instructions can be purchased at plumbing shops, DIY Stores, Hardware Stores. I hope this has helped thanks for using FIXYA. Good luck and have a great day. Jeff
Posted on Apr 07, 2010
Testimonial: "THANKS FOR YOUR HELP I WILL TRY THAT"
SOURCE: my new triton shower keeps dripping when switched off
The actual cause of this will depend on what type of shower unit this relates to - ie Mixer Valve, Electric Shower etc.
Generally though if the unit is new and therefore under the manufacturers warranty period the best course of action would be to contact Triton Service Dept direct - Tel 0844 980 0750 where a in warranty service visit may be arranged for you.
Posted on Jul 28, 2010
Testimonial: "thanks will do !!!!"
My Triton shower Eco Excite 8.5kW keeps tripping fuse when turned on !!
Could be a pump jam, do you have hard water ? Could be scale build up.
Is the shower head blocked ? Unscrew just the head (leaving the hose line attached to shower) and try again. If that is the blockage, then clean it with descaler.
Also check you have a good pressure on your water supply going in the Triton. Low pressure can set off safety switches. Again, check for blockages.
Check also for breaks in wiring and check there is no water ingress at any and all connections.
Is it an old unit ? Is it serviced regularly ? .......finally....
are all the settings set to MAX ? if so then use lowest setting first.
If it works then move settings up gradually until it trips.
Any filters need to be checked if possible.
Good luck Red.
Jul 16, 2016 | Home
Triton shower faults
If its a trickle occasionally its normal, when you turn off shower the water is still in pipe right up to shower head, it cools down, contracts and backs away from the head, when house gets warmer water expands up to the shower head and trickles out.
Dec 14, 2013 | Home
The water flow from my triton electric shower does not stop even after unit is switched off
28487001 is not an electronic shower head made by Hansgrohe. It is an overhead shower head that has no electronic parts. Triton is a completely different company. If you have an electronic shower system by Triton you will need to contact Triton. If you have a Hansgrohe product feel free to contact Hansgrohe at 1-800-334-0455.
Apr 13, 2013 | Hansgrohe Showerhead Shower Power ...
Drip from shower head triton t90 when turned off
The shut off is not closing completely remove the handle and faucet assembly and take it to the hardware store to purchase the right washer, o-ring, or gasket. If there are two take them both so you don't have to do this again for the other side.
May 08, 2012 | Home
I have a triton dart shower which is operated by turning a flow control block. This is so hard to turn that I sometimes struggle and my family require my assistance. It is just as difficult to turn off...
I can't offer you a solution but will say that I have the same problem with my Triton Dart. I have put it down to a build up of hard water inside the valve but not sure. Think I'm going to have to contact Triton under their warranty although they do say that they will not cover faults resulting from limescale.Great
Nov 09, 2010 | Home
My new triton shower keeps dripping when switched off
Jul 27, 2010 | Home
I have a drip, drip, drip from my shower head on my triton t90x can you please advise. thank you
Apr 07, 2010 | Home
Triton ivory 2 drips from shower hose when switched off any ideas or does it all need replacing thanks
heat from my shower keeps changing temperature, it will not hold the same temperature for very long...any tips ?
Mar 20, 2010 | Grohe 25 597 Talia Tub Filler w/Personal...
A single handle delta shower control lets water drip through shower head when shut off......how do I fix it ?
Make sure the drip is continuous because the shower head will drip for a few minutes until it empties out. Replace the cartridge or washer kit if it keeps dripping.
Sep 25, 2009 | Delta & Single Handle Shower Faucet
Dec 09, 2008 | Home
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
