Question about Carrier Heating & Cooling
What is tonage mod.38ckc060570 prod 38ckc060---571--
Piston 93 ---power 3ph 208-230 com.16.0 rla 125lra max.design working pressur 700psig 4826kpa
  • 700 Answers
SOURCE: Tonage or BTU/hour rating from Ruud name plate
See this link
http://www.epinions.com/specs/pr-GE_Zoneline_AZ55H07D_Air_Conditioner
Its say 7100 BTU/hr
Posted on Jun 05, 2009
  • 3 Answers
SOURCE: receptacle. the box says 208/230 volts ac 15 amps
Buy a NEMA 15-R recaptacle at an electrical supply house.
Posted on Jan 27, 2010
shastalaker7
  • 1515 Answers
SOURCE: have tri zone 36k elect.
Hi, I am not quite sure of what kind of set-up you are saying you have when you say it says line ground natural? If you have a 115/230 volt power supply, this should be very easy to tie into. Look at the wiring diagram on the new unit real good and locate the 2- hot wires that should say line one or L-! and L-2. Your 230 volt wires will connect one to each side of those 2 connections, and will have a ground wire that grounds to a metal lug or screw on the unit. Look over the diagram for field wiring connections for high voltage and this will tell you where you need to hook your 230 volt wires and ground to. If this new unit is 208/230 volts, you should have connections like I have said either L-1 or t-1 and L-2 or T-2 that you will tie in your 230 volts to. Just look over the diagram and you will see where the beginning of the 2 hot wires come into the unit. There should be either 2 good sized black hot wires that are for your incoming hot wires to connect to, or they are already connected to the contactor, and you will need to connect yours to the line side of the contactor. I see what you are saying now, that they are only showing you 1- 115 volt connection to the new unit so you will have only 115 volts to run it. You want to know where the other 115 volt conductor hooks up for 230 volts. This is why you need to look at the schematic and wiring diagram that shows both of the 208/230 volt connections on this new unit so you can connect both hot wires to it. I can't pull up a picture of this on the Internet, but it will show you on the schematic on where they connect. This line ground neutral connection sounds as though its not for a hot wire, but for your ground, or if you happen to have a neutral wire that is being used for a ground. Please keep looking for the 2- line in connections as this is what you will need to find and where both 115 volt wires connect. They are your line voltage wires, so they need to connect to the load voltage hot wires at the L-1 and L-2 connections of this unit. This should be fairly laid out for you, but sounds like they have made it difficult? Look for what I have said and the schematic drawing and you will find the connections. Please don't forget to rate me as I know you will be kind. I will be checking back with you as I keep all of your information on file so I can look you back up if I need to. You can contact me by my user name below if you need me also. I wish you the best and follow my instructions and I know you will get it right.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Posted on Sep 02, 2010
hvac1960
  • 2133 Answers
SOURCE: what is the tonage of
I think it's 4.5 TR
Posted on Dec 08, 2010
  • 64 Answers
SOURCE: we have a weather king
I would bet the outside units contactor is bad. This is the device where the two thermostat wire connect outside. If this is pulling in/out as you turn the stat on/off then it is working. I just fixed one yesterday with the same symptoms and found the start capacitors were bad. If they are bulged at the top or bottom then they are bad. Good luck.
Posted on Jun 19, 2011
How does ac evaporative coil with piston work?
the evaporater coil's piston acts as a orfice. the size of the piston hole allows a certain amount of refrigerant through at design pressure. it produces a designed temperture drop at designed cfm of air across it.
Jun 19, 2014 | Goodman Heating & Cooling
Heat pump with High head pressure
HFC-134a ? Critical pressure is 588.9 a . With a 93 LL temp and 575 head, I would suspect 1. Air in system or 2. Ref. has gone critical.
With a 110 psig suction/85 deg.F and a LL temp of 93 deg.F/125 psig
Jan 13, 2013 | Ruud Heating & Cooling
I would like to know how many square feet a Model # BRCQ0421BD Serial # 990905429 Coleman Central Air Conditioning Unit will cover. The unit supply is 208-230V 1 PH 60 Hz 10.8 RLA 97 LRA.
The Old Rule of Thumb is 400 square feet per ton, but you really need to do a heat load calculation to be safe. A lot of windows on the west or south side of the house will really increase your load and you may need a lot larger unit. Insulation also changes your load so you may be able to cool a larger area. You may be able to get the Heat Load Calculation Form either online or from Johnstone supply. They are on the internet.
Aug 07, 2012 | Coleman Heating & Cooling
How do i connect he differenial pressure switch into the 3ph star/delta starter circuit?
Your question is a bit unclear, but I assume you are asking how to wire the pressure switch in a piston compressor.
See the diagram, below.
You should have a wire from the L1 (first incoming main voltage) terminal to the pressure switch, and from the other pressure switch terminal back to the starter coil. You will also have a wire from L2 (second main voltage terminal) to the overload, and from the other overload terminal to the other side of the coil. In this arrangement, the motor starter coil must be rated at the SAME VOLTAGE as your incoming power.
This diagram works the same for single phase machines (they just don't have the third wire coming from the supply through the starter and overload to the motor.
If your machine has other safety controls (like a low oil switch), It can be wired in series with either the pressure switch or the overload.
Nov 03, 2009 | Ingersoll Rand Type 30 Electric Driven Two...
How do i connect the differential switch into the 3ph star/delta starter circuit?
Nov 03, 2009 | Ingersoll Rand Ingersoll-Rand Air...
Goodman 2.5 ton 14 seer with txv. low compressor amps
no it's good,man. LOL. The RLA is a max not a target. What is the RLA for the compressor?
Aug 12, 2009 | Heating & Cooling
See this link
Its say 7100 BTU/hr
Jun 05, 2009 | GE Zoneline AZ55H07D Air Conditioner
Need assitance for vw repair
You are probably right, the clearance between the pistons and the valves is very tight on the 16 valve engines. one of the valves may have hit a piston., or even worse bent a rod or damaged the crank.
I would run a compression check, or leakdown check before pulling the head. I have a service manual for 90-93 Passats w/ 9A 16 valve engines. the manual says compression should be 145-189 psi. limit 109 psi w/ 44 psi max difference between cyclinders.
On these engines you also need to check that the timing on both cams is ok.
Apr 16, 2009 | 1984 Volkswagen Scirocco
Heating & Cooling Logo
343 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
