Question about Dryers
STACK DRYER DIED
MY DAUGHTERS DRYER DIED , WASHER STILL WORKS , NOT START SWITCH OR DOOR SWITCH ..HAS POWER
    Genius:
  • 1,122 Answers
Heater box main fuse?is it turning inside and belt turning?-mike
Posted on Oct 26, 2008
How do i replace a stack washer dryer dryer door switch?
when you open washer door you hit a stopper pin that holds the door open. there are 2 screws located around that area on both sides of panel. remove them and you'll see vent hook up and water line hook up and power cord. Now at the backside of washer door panel there are two screws remove them and pull washer door panel towards you. under the door panel connected to panel is where you will find door switch. if you jump out door switch and it works then you need new door switch.
Apr 30, 2014 | Whirlpool Thin Twin Washer and Electric...
Frigidaire FEX831CS Top Load Stacked Washer / Dryer dryer won't start
Hello - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and start normal cycle. If this proves to be ineffective, then contact a professional to move forward accurately. Possible causes could be a faulty power cord or house wiring, defective control board, thermal limiter or door switch.
Oct 22, 2012 | Frigidaire FEX831CS Top Load Stacked...
My dryer door switch doesent work
Hello Shawn Leonard - Try resetting the unit at the household circuit breaker first and then retry the unit. If this proves to not be successful, then typically this is something that a professional would need to diagnose. Possible causes could be a faulty power cord or house wiring, defective control board, thermal limiter or door switch.
Oct 03, 2012 | Frigidaire FEX831CS Top Load Stacked...
Dryer start button doesn't work
door switch or possibly the motor. if you hold the door switch in and push the start button have someone turn the drum by hand if it starts running it is the motor
Jul 04, 2010 | Frigidaire FEX831CS Top Load Stacked...
Dryer electric when i push the start button nothing happpens
Make sure you have 220 Volts of power at outlet, check circuit breakers. Then, with dryer door open, look for door switch actuator on door. It may be broken. Use flat screwdriver to manually push door switch in, then push start.
Feb 21, 2010 | Whirlpool LTE5243D Top Load Stacked...
My washer and dryer will not come on what is wrong
Check the door limit switch/s. all power goes through the limit switches first.Assuming the power to your plug is correct.
Sep 15, 2009 | Kenmore 98702 Stacked Washer/Dryer
Wont start
did you check the door switch,and the heating element(make sure it's not grounding out,check to make sure you have 120volts coming in on both legs-mike
Mar 16, 2009 | Kenmore 98702 Stacked Washer/Dryer
Dryer
I WOULD CHECK DOOR SWITCH FIRST
Jan 31, 2008 | Frigidaire GLGT1142CS Top Load Stacked...
Maytag stacked washer/dryer
CHECK THE DOOR SWITCH TO SEE IF THE WIRE ARE CONNECT CORRECTLY. ON THE SWITCH THE WIRE FROM THE BULB SHOULD GO TO N/O IF ALL WIRES ARE CORRECT .THEN YOU NEED TO REPLACE THE DOOR SWITCH
Jan 03, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Dryers Logo
Top Dryers Experts
