Question about OfficeMax Office Equipment & Supplies
Manual & gear guide for model #OM04226
Officemax 8 sheet micro cut shredder #OM04266 - need diagram for gear assembly
FixinFax
  • 3085 Answers
SOURCE: Staples(Fellowes?) micro cut shredder - blades not turning
Sometimes the main gear is attached to the motor with an ALLEN SET SCREW
Posted on Jul 05, 2009
SOURCE: OfficeMax OM99729 Shredder with bad gear
If it happened within a year, you should have just had the warranty replace it. We had it happen after nearly 11 months, it was replaced within two days.
Posted on Oct 19, 2009
  • 9 Answers
SOURCE: C-320C Cross-Cut Shredder need a parts list
get ahold of thetapped@yahoo.com he has parts
Posted on Mar 18, 2010
edgreason
  • 120 Answers
SOURCE: my OfficeMax shredder OMO 1288 wont stop running!
your auto insertion sensor (electric eye) is probably dirty or malfunctioning. clean or replace the "eye" or disable auto-reverse on jamb feature.
Posted on Apr 06, 2010
KingDWS
  • 1606 Answers
SOURCE: I have a paper jam in my OfficeMax paper shredder.
Usually for a jam you just need to reverse it. If it is really jammed you may have a staple caught in there or too many sheets of paper. If you unplug it and then see if you can pull out the jam. If it is a staple you may need to use needle nose pliers to get enough of a grip to get it out. If this has seen heavy use and lots of multiple pages then you could have burned out the motor. These are not much more complicated that scissors so there isn't much to do to fix them. Most don't like staples or more than 2-3 pages max at a time (if that many) even if they claim more than that.
Posted on Sep 08, 2011
Motor runs but teeth do not
Some of these units use plastic gears on the shredders and motors. They can strip or it could be a shear pin on the drive shaft or gears that breaks when something hard is put in the machine.
Feb 20, 2016 | Omnitech 10-Sheet Micro-Cut Shredder
PROBLEM SENSOR PAPER DETECTION
There is a lever inside the shredder that is connected to a micro switch that detects the paper. Its usually located in the center of the opening where you insert the paper. This switch will make a very slight click if you turn the shredder off and insert a sheet of paper at the opening. If you can hear it click and it still doesn't work the motor could be defective.
Feb 19, 2015 | OfficeMax 10-Sheet Micro-Cut Shredder...
My shredder is showing the bin is full when it is empty - how to I fix it?
Depending on the shredder model, there is a sensor of some kind telling it that it is full. The two possible solutions are to unplug it and plug it back in, and to try to find the sensor and do what needs to be done to make it not active.
Dec 03, 2014 | OfficeMax Om04229 15-sheet Diamond-cut...
How do I get an Owners Manual?
Search on google "OfficeMax Shredder OM01288 Manual"
And you should find one.
Jun 20, 2014 | OfficeMax 10-Sheet Cross-Cut Shredder...
My shredder stoped working
My shredder was under warranty--not officemax warranty--so I sent it back to the company that manufactured the shredder, at my expense. They sent me a new one at their expense. Had I added a few more dollars to the shipping for a new shredder. I never could get my to accept paper or lubricating sheet. Did not open the exchanged shredder until 2 days ago and so far it works, however the original one worked for about a week before stopping. I believe--should I have the need I will purchase a different brand.
I hope that helps.
Apr 11, 2014 | OfficeMax 10-Sheet Micro-Cut Shredder...
Bin full door open
I found the nylon "bin full" flapper in the center of the head of the shredder is supposed to trip a microswitch indicating bin full. I removed the flapper and tapped on the switch. It came loose with a puff of paper dust. I replaced the flapper and it's back to good as new. Seems the dust built up around the switch and it was stuck.
Mar 31, 2014 | OfficeMax 10-Sheet Micro-Cut Shredder...
Overload light stays on
Most likely the cutters are still stuffed with paper shreds and needs to be dismantled and cleaned
Mar 29, 2014 | Honeywell Seven Sheet Micro Cut Paper...
Running sluggish and will only shred about 5 pages at a tiem model #OM 96146 Office max
Favorite with shredders... put some shredder oil on a sheet of paper and shred the page ... you may have to do this a few times if you have never oiled inside the cutting blades.
Sep 27, 2010 | OfficeMax 0M96431 Shredder
OM99733 15-SHEET SHREDDER
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Sep 04, 2008 | OfficeMax 0M96431 Shredder
735 people viewed this question
Top OfficeMax Office Equipment & Supplies Experts
ROCKIT957
Randy Schumann
Randy Schumann
Colin Stickland
Colin Stickland
Are you an OfficeMax Office Equipment and Supply Expert? Answer questions, earn points and help others
