Question about Konica Minolta Office Equipment & Supplies
Bizhub 420 error code c-2702 - Konica Minolta Office Equipment & Supplies
  • Konica Minolta Master
  • 6,161 Answers
When you open the door on the right side on the door is a assemble that has paper guides cover to very find wires, that assemble is either bad or the wires in the assemble are bad, have a tech look at it might require replacement.
Posted on Jan 22, 2016
5 Suggested Answers
  • 158 Answers
SOURCE: minolta bizhub 420 code c2403
this error code means there is a problem with the toner bottle drive most likely the toner rotation sensor will need to be replaced
Posted on Nov 21, 2009
firecontrol7
  • 6161 Answers
SOURCE: Bizhub 420 Photocopier
Have you check the Printer control board. Also does the toner bottle turn? You can force it in 47 Mode. to turn the bottle motor CW or CCW
Posted on Aug 04, 2009
  • 21 Answers
SOURCE: c5201 error konica minolta bizhub 420 i removed
reconnect again your fusing unit. then before you ON your machine you long press utility/counter then press the small circle black, then press trouble reset.off/on
Posted on Apr 06, 2010
  • 32 Answers
SOURCE: How to fix Error Code C3901 on a Minolta Bizhub
Enter service mode & Clear All
Utility>Stop>0>0>Stop>0>1
All of this within 3 secs.
Please Rate me.
Posted on Aug 15, 2010
Code irror 2702
If you wish to get some details; check the site linked here. Pull up older posts.....
http://electro-medical.blogspot.com/
Apr 26, 2016 | Konica Minolta BizHub 360 361 420 421 500...
Bizhub 420 is showing me a C2801 code please help if u have an idea.
Please explain as per documentation what is C2801 error code I can help you
Jun 29, 2015 | Office Equipment & Supplies
How to find bizhub 420 problem with code 1102
C-1102 is a tray lift motor failure. Your copier is equipped with a FS-511 finisher. The trays on the left side (where the paper comes out) is being blocked when its trying to move up/down. Ensure the are no obstructions an restart your machine.
Oct 26, 2014 | Konica Minolta bizhub 420
Rror 2703
Subject:
C-2702 and/or C-2703 code.
Description:
Solution:
PROBABLE CAUSES:
1. Failed T/S corona.
Remove the T/S corona unit. If blank copies can be printed without a service code appearing, replace the T/S corona unit (p/n 57AA R715 00).
2. The HV unit has failed.
Replace the HV unit (p/n 56AA 8401 2).
Oct 16, 2014 | Konica Minolta Bizhub Press C6000 Copier
Error code d282 bizhub 420
communication error between the main control board and the scanner control board the scanner is that what is below the big glass particularly the mirrors and exposure lamp (Bright light) something is not talking!!!!
Jun 25, 2014 | Konica Minolta bizhub 420
Error 2803 konica minolta 500
TCR output abnormality.Toner control ratio abnormality error code.Restart the machine if code removes then its OK otherwise simply replace the developer and execute TCR adjustment again.
Dec 11, 2012 | Konica Minolta bizhub 420
Server disk full in bizhub 420
malfunction was detected cs remote care c2403
Aug 21, 2012 | Konica Minolta bizhub 420
Bizhub 420 error code c-2801
error code 2801 plesce relese the code prectical met
Feb 08, 2010 | Konica Minolta Office Equipment & Supplies
May 06, 2009 | Konica Minolta Office Equipment & Supplies
1,308 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
