Question about Sewing Machines
Needle wont move on my bernina 930 - Sewing Machines
  • Sewing Machines Master
  • 9,939 Answers
Could very well be the basting stitch mechanism. This is a very common issue on the Bernina 930 Records. The basting stitch should be run frequently (once a month). If it locks up, the machine has to be taken to a technician.
Posted on Jun 08, 2015
SOURCE: Needle won't move on Bernina 930
If the machines motor is running but the needle isn't going up and down then the baste stitch finger is gummed up and needs to be serviced.  This is a simple fix and it happens all the time on those machines.  Take it to your local Bernina dealer for a standard service.  Also if you really need it in a pinch try pushing up on the needle bar that sometimes will fix the problem but it will still need serviced.
Posted on Oct 22, 2007
  • 19 Answers
SOURCE: Bernina 930 where to put oil
There are two key points I suggest customers can do themselves to help lengthen the life of their machine. One is your hook and the other is the needle bar...
Hook - Open your bobbin door, removee the bobbin case/bobbin. On the upper left corner there is a small latch, push in the latch and your shuttle race ring will fall down forward. You can now remove your stainless steel hook. You need to keep this hook clean and the lip it fits back into clean and void of lint and debris. On the back of this hook or the "lip" that the hook fits back into apply a small amount of hook/sewing machine oil.
Needle Bar - Open up your head cover, the needle and needle bar clamp is attached to a long stainless steel rod that travels vertically inside your head. All sewing machines have a needle bar that looks like this. This bar travels thru two brackets attached to the frame of the machine. Rotate your handwheel and clean the needle bar well of debris. Rotate the handwheel so that the needlebar is in it's highest point and apply a small amount of oil to the upper and lower bracket of the frame, rotate the handwheel so the needlebar slides back down and therefore lubricating it and the inside of the brackets.
Hook oil or sewing machine oil is relatively inexpensive from all quilt, sewing machine, repair shops.
Be sure to take your machine in a minimum of every three years for proper cleaning and lubricating of all the other parts (This is of course for average home sewing machine use 8hours a week)
Posted on Jan 08, 2009
SewTechWayne
  • 186 Answers
SOURCE: Bernina 930 won't zig zag
You probably need to take it in to the shop, the needle position knob is bound up. It's worth spending the money, this is a good machine. You can try to soak everything with penetrating oil over night and carefully try to move the knob, you may be lucky and it will free up.
Posted on Feb 08, 2009
SOURCE: Zig Zag Stitch not working
THis problem occurred as I was sewing on Neoprene. I was using Gutterman all-purpose thread and a size 80 needle. Tried switching to a size 70, then to size 90. Still unable to zig zag. After inserting a test sample of cotton, the zig zag worked perfectly, so I knew it was not a mecahnical problem. I switched needles again. This time to size 90 for stretch fabric. Voila! Problem solved.
Posted on May 24, 2009
SOURCE: My Bernina 930 was stored in a cold room 2 yrs ago
I cleaned just above where the needle goes in.  There was some fabric lint.  It works now. I used the little brush that comes with the machine
Posted on Feb 02, 2010
Bernina 930 Record presser foot lever won't move. On the inside you can see the shaft going up and down but nothing happens to the presser foot. It is currently in the up position but won't go down.
I suspect the machine has seized due to lack of regular oiling. The old oil turns to varnish and acts like glue preventing the parts from moving freely.
CAUTION: your 930 has a basting stitch that will tend to lock up if it is accidentally oiled (or if it hasn't been used for a long time). AVOID applying oil to the middle of the take-up bar (right next to the basting stitch dial behind the case)! A frozen basting stitch is evident when the needle is at its highest point and will not descend.
Wheel on right side that controls the needle up and down is very tight...
Jun 20, 2017 | Bernina Sewing Machines
My bernina 930 speed has basically came to zero. the wheel is turning but the needle is moving very slow and even stops moving even when the wheel is turning. what could be the problem?
Um, how long since the last clean and oil? Sounds like the machine has seized due to old dry oil preventing things from moving. Avoid using the machine until the problem is addressed or the motor may be damaged. (Do this and you will be surprised at how nicely your 930 will run!)
Bernina 930 Record Oil Diagram
am looking for bernina 930 service manual dropped the feed dogs and they...
Mar 17, 2017 | Bernina Sewing Machines
I am looking for a bernina 930 service manual. I dropped the feed dogs and they will not come back up.
Most likely they have seized due to lack of regular oiling. I have used the following method on several older seized Berninas with great success. Just be sure to NOT get any oil near the 930 basting stitch mechanism (about the middle of the needle bar) or it will most likely lock the machine.
This is a diagram for the Bernina 830 Record, but it will give you a good idea of what & where to look for oil ports.
I've never used this source (use at your risk):
Bernina record 930 electronic service manual
Nov 25, 2016 | Bernina Sewing Machines
Bernina 930 change needle position
Look at the knob which creates the zig-zag stitch (1-4) at the top right of your 930. In the center of that is a silver knob that rotates right and left. That silver switch moves the needle position right and left.
Mar 22, 2015 | Bernina Sewing Machines
How can I fix the needle assembly on my Bernina 930 Record...it all of the sudden doesn't move up and down?
There is a screw-in "hub", a round thingie, to tighten on the end of the machine, in the middle of the big spinning wheel. Hold the wheel and turn the hub clock-wise to tighten it ("Righty-Tighty, Lefty-Loosy).
It may be a bit tight to start with, they can "jam" open. Just turn it firmly as needed.
The reason the hub tightens and loosens is so you can run the machine quite fast when filling a bobbin up with thread without having all the gears and werkin's clatter as you do so.
Here is a VIDEO (better than just a photo, yes?) on how to operate your very model sewing machine! https://www.youtube.com/watch?v=drLD66Wa7U0
Aug 04, 2014 | Bernina Sewing Machines
Bernina 1030 needle not moving up or down
I believe the 1030 has a basting stitch, similar to the 930 Record. If the basting stitch is not run regularly, it may lock up the machine requiring a technician's expertise to get it working again.
Mar 31, 2013 | Bernina 1008
How to twin needle sew with bernina 930
The manual should show how to use a twin needle. You can download a manual here:
BERNINA Support Machine and Accessories Finders and Software Support...
Jul 07, 2012 | Bernina Sewing Machines
May 23, 2009 | Bernina Virtuosa 150
Sep 16, 2007 | Sewing Machines
Sewing Machines Logo
515 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
