Question about Uniden Atlantis 250 Marine Radio
Constant beep, channel number and tx flashing
When my atlantis 250 is turned on it has a constant beep and has the channel # and " tx " flashing. unable to transmit or receive transmission won't change channels or anything. turning power on and off doesn't help and neither does removing the battery.
  • andreworiord Dec 21, 2008
    I have the same problem, It was fine one day and the next this happened! any solutions?
Ok this problem is caused by the spring mic jack
Getting rusty
Posted on Jul 14, 2016
  • bones588 Jul 14, 2016
    Sorry the speaker microphone port just push something into it will fix the problem
    Ok this problem is caused by the speaker mic jack
    Getting rusty
2 Suggested Answers
SOURCE: Atlantis 250 - have no
me too. Also, transmit seems to work fine but the battery level indicator drops a lot after a few short transmissions.
Posted on Jun 13, 2011
Always starts on channel 16
This question has been around for quite awhile, but if anyone else requires the information, as best as I can tell from the owners manual (see below) on page 12, each time the radio is turned on, it starts on channel 16. I believe this to be an important feature in case the user is involved in an emergency situation.
(As a victim or as a possible rescuer.)
-Steve
http://www.uniden.com/pdf/ATLANTIS%20250om.pdf
Feb 06, 2014 | Uniden Atlantis 250 Marine Radio
I have an acer aspire 5750g Windows 7 Laptop, the bios version is Acer V1.05, every now and then the machine refuses to start and beeps constantly, what is the problem?
The beeping may actually be your pc attempting to tell you something. Count the number of beeps, and then search for your machine make, model, and number of beeps. Also, are any of the lights on the front of the machine flashing. Check to see if the flashing is constant, or if there is a pattern.
Jun 18, 2013 | Computers & Internet
When I plug my new Eflight 32 motor into the battery I get a constant beeping sound and the motor will not initialize. It was working until I unpluged it after binding the controller to my hand held...
Check your TX throtle stick is completly down. ESC beep if they detect signal from throtle channel on start.
Other cause could be you plug ESC in wrong channel in your RX
Mar 12, 2011 | E-Flite Rc Power 32 Brushless Outrunner...
When I press the push to talk button on my Motorola talkabout 250 there is a constant beeping noise and I cannot transmit
Generally a constant beep is the sign of a low or bad battery. However, it is noted the TalkAbout 250 is operated with AA batteries, and it is likely you have considered this and changed batteries. You might check your battery contacts, and clean them with a pencil eraser to assure they are making good connection. Otherwise, you may have a failing radio.
Best regards.
Nov 02, 2010 | Motorola Talkabout FRS 250 (14 Channels)...
It turns on but keeps beeping
The constant beep means that the channel you are on is not programmed. Try moving the channel knob to other channels. If it stops beeping, you are on a channel that is programmed. It is possible that none of the channels are programmed though.
Take it to a motorola dealer and they can program it for you.
Jul 15, 2010 | Motorola HT1000, MTS2000, MTX8000/9000...
When you turn the power on it just constantly turns on and off
Probably need to rebuild bad amp channel. Look for burnt resistor and rebuild that channel. if you plan to do it yourself let me know which channel . i can get you part numbers. Check big white resistors . Value should be .22 ohms. If open then thats your bad channel. Check outputs if they read 0 accross any leads thats the bad channel .
Mar 23, 2010 | Onkyo TX-SV535 Receiver
Channel number display will not turn off
are you using the TV tuner of the TX-42F30s or are you connecting via setup box
what happen if you change channel
the unit can be reset to factory mode.
Nov 15, 2008 | Westinghouse TX-42F430S Television
Uniden Atlantis 250 Marine Radio Logo
334 people viewed this question
Top Uniden Boating Experts
Steve
Steve
Mike Marcotte
Mike Marcotte
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Uniden Boating Expert? Answer questions, earn points and help others
