Question about HP Pavilion dv6000z Notebook
Hp pavilion dv 6747cl
Laptop was working set it down and got a white screen, turn it off and back on still white screen took out the ram and put it back in still white screen. can someone help me please?
    President:
  • 2,712 Answers
Looks like a faulty ribbon cable b/n the motherboard and the screen. I would get that checked first..
Posted on Oct 26, 2008
I got a hp pavilion dv 2500 i assumed had a bad charger port because the light would not turn on when it was plugged in. so i went ahead and bougt a new component for it, but still no charge. any othe
How old is the battery. It may not be holding a charge because it is so old. Try holding down F12 during boot up to see if it offers you a battery recalibration option. If it does, follow the on screen instructions to the letter. Best of luck
Dec 15, 2012 | HP Pavilion dv2715nr Notebook
Computer turns on but no screen or use of any functions
Open the RAM lid ( at the bottom laptop ) use a small screw driver (+)
removes the RAM memory module ( right and left at the same time )
Clean it up with a dry tissue or a white paper > specially the connector.
put it back on and you can try to turn it on
akee.4shared.com
Aug 15, 2011 | HP Pavilion dv6000z Notebook
Hp dv 6000 black screen problem
these is small hv board circuit, inside lcd is defective, needs to be replaced. send to repair.
Feb 09, 2010 | HP Pavilion dv6000z 15.4" Notebook Laptop...
Hello, I have a problem with hp pavilion dv
Try lowering your display settings when it is hooked up to the external monitor. Then try the laptop screen again.
Right click an open area of the desktop, select properties, click the display tab. In the lower left of the box there is a settings slider, try lowering the settings and see if it gets better.
Dec 13, 2009 | HP Pavilion dv6000z Notebook
HAVE HP PAVILION DV 9000 LAPTOP , WHEN I SWICHED ON MY LAPTOP IS ON BUT SCREEN IS NOT WORKING AND EVERY ONE MINUTER LAPTOP GETS AUTOMATICALY RESET. SO PLEASE GIVE ME REPLY WHAT IS THE PROBLEM?
I have had this same problem with a HP DV2000 and the problem is not the contrast light. What it is, is that the laptop thinks that the screen is been shut down that is why the light does not come on. The best way to solve this is to remove your keyboard first.
You can remove the keyboard by removing exactly 7 screws from your laptop back, there are 5 screws located under your battery and other two that are in the location of your RAM'S.
Just open them up and then you will notice that the key board pops out abit then just simply take it up and then just below the keyboard, on the same line where HP brand logo is on your machine there are two small clip types of pind, that you can remove and put back.
There is a clip that is hidden abit under the metal plate, so just try and remove that clip from its place using a needle or any long and thin object.
That will make the laptop not have the problem. But once you remove that the laptop constantly will think that the screen is open even if you close it. then after like a week or two you can put it back and all shall be fine if not then just remove it and keep it out.
You can then set your power options to shut down the screen light every 2 minutes or something like that so as to avoid the backlight being switched on all the time.
Hope this solves your problem.
May 28, 2009 | HP Pavilion dv9000z Notebook
Beep on starting the laptop
Try to take memory out and put it back in to make sure they are seated in the slots properly and no loose.
May 27, 2009 | HP Pavilion dv1000 Notebook
The screen go blank on my hp pavilon dv 2000. Why?
If you've checked the battery and power cables are connected properly then you've done as much as you can do, you'll need to take the laptop to a HP repair centre.
May 17, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Vertical white line on laptop display
Yes, this is a defective screen. The only fix is to replace the screen. It's called a column of dead pixels. Since it is under warranty, contact HP to have them warranty it out or take it back to the place you purchased it from for an exchange. Please take a moment and give this answer a good rating of fixya. Thank you.
Dec 26, 2008 | HP Pavilion dv7-1130us laptop
White computer screen
i got the same problem with my hp dv6000 couple of times, fixed it. it could be problem with ur video card or ur ram. try to take out the ram and put it back again. second time i got the same problem and i inserted my recovery disc and i was able to recover my laptop and it all went well. try these it might help u as well....
Oct 25, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion dv6000z Notebook Logo
219 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
