Question about Texas Instruments TI-83 Plus Calculator
Calculator freezes (TI-83)
My calculator is frozen on a particular screen. I can't turn it off properly, becuse no buttons will work. I hve to take the batteries out to shut it off. Any suggestions on how to unfreeze it? Thanks
  • 2 more comments
  • knorulss Oct 29, 2008
    help
  • drewmcd621 Nov 04, 2008
    I have the same thing only if I hit a few buttons it sometimes un-freezes
  • Lexipo Nov 24, 2008
    my screen is frozen how do i fix it?
  • lmw3225 Dec 08, 2008
    mine's doing the exact same thing.
  • 32 Answers
SOURCE: TI-83 Plus Silver Edition 1.14
That means that you know your calc crashed. This can be caused by taking out the batteries durring running time, happened just randomly. Well nothing to fear just press clear and it should go away but if it stays on that screen you have problems and is best to try some of these methods. Take out all the bateries and press and hold the on button for 30 seconds. Put the batteries back in and it should have reset. Warning you should archive everything incase this happens. To archive go to 2nd mem and hit enter to put a astrick next to the app (meaning archived)
Posted on Sep 16, 2008
SOURCE: Find the antilog on the TI-83 Plus for finding pH in chemistry problems
how do i find the anilog on my calculator i have a texas instrument ti-30
Posted on Oct 15, 2008
  • 8 Answers
SOURCE: TI-83 Plus calculator--fractions
just type it in, e.g. 1/2 or 3/5. if you want to have answers display as fractions, press [MATH] ENTER.
Posted on May 08, 2009
  • 7993 Answers
SOURCE: my TI-83 plus calculator doesn't work
As battery gets drained, the screen contrast dims. But when you change batteries, some times the contrast is reset to some low value and the screen appears dead: it is so light that you do not see anything, and you think the calculator is malfunctioning. This is the most frequent reason users think the calculator refuses to turn ON. And I hope that is the case now.
To correct that, you must increase screen contrast: draken the screen a bit. To do so
  1. press [2nd] key and release it.
  2. Press the Up arrow and HOLD pressure.
  3. Keep pressing the arrow key until screen is dark enough.
If that solve your problem that is good, rate the post accordingly.. If that does not, do not get irate and berate the post. Post a comment here describing what you did and what message (if any) calculator returned, and I will give you further diagnostic steps.
Posted on Jan 21, 2010
  • 102366 Answers
SOURCE: My TI-89 calculator turns on, but gets stuck on window editor
If you're willing to have all RAM cleared, try a hard reset.
Press and hold the 2ND, Left-arrow, and Right-arrow keys.
Press and release the ON key.
Posted on Feb 20, 2010
The on button on my ti-83 is working but that is the only button working as far as I can tell because the screen stays blank
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible. Does it?
Sep 04, 2011 | Texas Instruments TI-83 Plus Calculator
My ti 83 calculator turns on but nothing shows
TI calculators have an annoying habit of dimming the screen, especially when the batteries are changed, so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
May 20, 2010 | Texas Instruments TI-83 Plus Silver...
I want to adjust the brightness and contrast on my TI-83 calculator
Turn the calculator on. Press and release the 2ND button. Press and hold the up-arrow key to increase contrast/darken the screen or the down-arrow key to decrease contrast/lighten the screen.
Apr 08, 2010 | Texas Instruments TI-83 Plus Calculator
Calculator freezing and shutting off
I see that you have an earlier version of the OS. You should update it to version 1.19 available at education.ti.com. Click the dowloads >> Apps and software menu.
The most likely reason for the RAM cleared is a depleted backup battery.
You might want to solve the problem and the update all at one go.
Check this article in the TI FAQ and Knowledge base for the procedure. The article contains an internal link to the OS Installation procedure.
Before you start on this journey, make sure the batteries (main and backup) are in a good state. Many OS installation failures happen because of quasi-depleted batteries.
Hope it helps.
Nov 03, 2009 | Texas Instruments TI-83 Plus Calculator
TI-83 Calculator RAM cleared
To clear the message press [CLEAR]
If calculator shows message after you turn it [ON], it may be due to drained backup battery. If you have to change it make sure you have main batteries in and in good state, and installed.
If calculator appears frozen, press [2nd] [QUIT] to interrupt what it is doing.
I see you do not have the latest ROM (OS). You should download the latest ROM (1.19) and install it.
Use the education.ti.com link to download the TIConnect software. Install it on your computer. Run the TIConnect software. Connect the calculator to a computer (USB cable or TISilverLink cable or TI Graphlink black cable). Press the ON button, do not worry if you do not see anything on screen (contrast may be too light).
In TIConnect main window, click the TI Device info button. The software will try to detect the calculator. If the answer is NOT FOUND on any of the ports, click the communication settings at the bottom of the window.
Select Device: enter you calculator model
Select Cable: SilverLink, USB,
Select port : USB1 or COMx
and click OK. The TI connect software will give you some messages if communications with calculator cannot be established.
If you establish communications with the calculator, press the Update button in TIConnect main window. Install OS directly to the calculator. You may update other installed applications.
If you cannot communicate with calculator with the computer try to update by cal-to-calc connection with a working calculator/
Hope it helps.
Sep 27, 2009 | Texas Instruments TI-83 Plus Calculator
Frozen calculator
http://epsstore.ti.com/OA_HTML/csksxvm.jsp?nSetId=90524&nUsePub=NO&JServSessionIdrootdlek22=z6c2ohx3v1.n6LzoN8M/AzOnMTOogTxpQOUtxCLbx0Ka0--&jttst0=6_23871,23871,-1,0,&jtfm0=&etfm1=&jfn=ZGC5A4DDBCF3F0595853A68C079E5256B1556E2E93FB96ACB00A6AFBBC9B77BE7654B72492D9041952FB73A07FF7EFF0FB73
Here's a link to the troubleshooting thread from Texas Instruments about this particular problem, hope this helps!
Jul 10, 2009 | Texas Instruments TI-84 Plus Silver...
TI-83 Plus will not let me view a table
I have just done what you said you had done, but I got a nice, correct table of values. You might have discoverd a secret command to clear memory.
Cheers.
Apr 14, 2009 | Texas Instruments TI-83 Plus Calculator
RAM Cleared
This is kinda a weird situation. Because it's usually the other way around. Your ram will clear if your calculator is frozen. So take out all 5 batteries from the back. Even the back up battery. Then reset it again. 2nd then + then 7 then 1 Then 2. Good luck.
Oct 22, 2008 | Texas Instruments TI-84 Plus Calculator
Can not use graph function
How do I fix my Ti 83 calculator's window range error and do the graph?Because without that fixed I can't do my graph atall.
Oct 19, 2008 | Texas Instruments TI-83 Plus Calculator
Ti 83
Remove one of the AAA batteries. Press and hold CLEAR while reinstalling the AAA battery. Continue holding CLEAR button and press ON. Release buttons and press CLEAR again.
Jan 02, 2007 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
122 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
