Question about Dishwashers
The eco light is flashing constantly on my Dishlex Global 300 dishwasher, it is making a noise like a pump is running continously, but the unit will not operate. Can you give me some possible faults and solutions. Regards Dave
    Brigadier General:
  • 6,966 Answers
The symptoms on a Dishlex Global 300 dishwasher:
  • eco light is flashing constantly;
  • noise on pump running continuously;
  • but the unit will not operate.
Possible corrective actions include:
  • water level - pls check incoming water pressure, filter, water level sensor, water valve;
  • base/bottom overflow sensor - there is a float switch in the base of the machine inside a small plastic dish. Behind the kick panel, access through a metal lid/panel/cover secured by 2 small screws. Dry completely the area;
  • Air/dry/ventilate the unit/system for a couple of days;
  • reduce incoming water pressure.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 26, 2008
  • Sam T Apr 28, 2012
    It was the float switch beneath the dishwasher. Note for those looking for the panel to remove. Once you get the kick panel off right in front of you is a galvanised metal that runs the whole width of the machine. Its held in place by two hex screws (easily removed) and then you will expose the machinery at the bottom of the dishwasher. Right in front and at about midpoint you will see the small plastic dish that has been described. Use an absorbent cloth like a chamois and Bob's your uncle. If this doesn't work the float switch is not the issue.
  • Dishwashers Master
  • 13,433 Answers
An overflow of water into the base of the machine.
There is a float switch in the base of the machine in a small plastic dish.
There is a metal cover with 2 small bolts that have to be removed to get to it.
get the overflow cleared.
    Once you get the kick plate off you will see a galvanised panel that runs the width of the machine. It is held in place by two hex screws (easily removed). Take the panel off and then you will have exposed the underneath of the pump machinery at the bottom of the machine. About mid line in the machine and in the front as you look at it you will see the plastic dish and if it has water in it then use a Chamois or other absorbent cloth to dry it out. Voila and the machine should start. If this solution doesn't work the problem is not with the float switch so need to look elsewhere.
    Scholar:
  • 155 Answers
You can try to remove the kick plate and empty the overflow container. You may have to take the galvanised panel after removingthe kick plate to get full access to the container.
  • 19,396 Answers
Try first unplugging power cord for ten minutes, It can be a faulty drain pump or a faulty control.
Hi there, we have had our dishlex 300 dishwasher switched off for a while and today I turned it on. I started a cycle and it stopped after a few minutes and then the Eco button started flashing. I opened...
Hi just read your posting.Now the reason these dishwashers flash ECO is because there is either water in the bottom tray or your drain pump is open circuit.Is the machine making a pumping noise when it is flashing the ECO light,or is it completely silent?Please reply on additional information and I am sure I can help you.Looking forward to your reply.
Sep 12, 2010 | Dishwashers
The eco light is flashing constantly on my Dishlex Global 300 dishwasher, it is making a noise like a pump is running continously, but the unit will not operate. Can you give me some possible faults and...
its an overflow of water into the base of the machine.
Oct 26, 2008 | Dishwashers
Dishlex Global 300 starts to fill with water, then
ok this sounds like your water has stopped coming in or timed out b4 the pressure switch is activated. hold eco button down, u will hear a beep then a light will come up, keep pushing the button until u see the light.reply and tell me which light has come up, and i can help u fix the problem.
Apr 24, 2010 | Dishwashers
Dishlex Global 300. Eco light flashing and nothing happens.
could be the water inlet valve or solenoid
Jan 25, 2010 | Dishwashers
Pump motor runs continuously, ''Eco'' flashes continuously
Hi
soyunds like it flooded the base
You need to dry out the base of the machine thoroughly and it should re set
Feb 14, 2009 | Electrolux 24 in. EDW5505EPS Stainless...
Dishlex global dishwasher, stuck on eco, eco light flashes and drain pump runs
Try turning the taps on harder, I read that someone else had the same problem and this fixed it for them.
Aug 18, 2008 | Dishwashers
Dishlex global 300 dishwasher, eco light flashing sounds like pump noise but not working
Try taking the dishwasher out of its wall space and tipping it back and forth. Apparently the weight of water gathering in some component triggers the 'eco' function. Failing that, last time it happened to my dishwasher i waited a week for the repair guy to arrive, by which time the water had evaporated and there was no longer a problem..
Jul 26, 2008 | Dishwashers
Dishlex dishwasher global 300. Dishwasher continues to drain with ECO light flashing. Service manual says it is due to an incorrect fill level or fill line.
Some diswashers have a sump in the bottom with a float switch. If the water level overflows the float will activate the switch which will kill the machine and run the drain pump continuously.
Jul 01, 2008 | Dishwashers
Dishwashers Logo
601 people viewed this question
Top Dishwashers Experts
