Question about Whirlpool GEW9250 Electric Dryer
Won't start, beeping sounds
Whirlpool Duet Dryer won't start. All lighs are on, drying time dislplayed, but when press START it beeps several quick triple beeps, time flashes on dilsplay, but the dryer won't start. I unplugged it for about 8 minutes and same thing happened. Please help!
  • 3 more comments
  • ddurieux Oct 26, 2008
    Thank you, I tried, however my wife says the light hasn't worked in a while, guess it burned since I used to find the door left open many times. I did notice that the switch didn't make a click sound when I press it, should it do it? Guess I have to first replace the light bulb and pick it up from there.
  • spool Nov 25, 2008
    same problem, I changed bulb and pushed door button several times, unplugged it and still same thing, please help me! Thanks
  • alain_plourd Dec 02, 2008
  • Anonymous Mar 15, 2014
    My dryer is beeping while drying. It's starts up after around 10-15 minutes of drying. Everything seems to be working fine except the beeping. Please help us?
  • Anonymous Mar 27, 2014
    it beeps several times and then the time flashes.
    sometimes the light in the dryer is on and sometimes it is not. I have already unplugged and plugged it back it in, nothing.
    President:
  • Whirlpool Master
  • 2,651 Answers
Sounds like the door switch might be an issue,, does teh tub light go on /off as you open the door??? if not try manually pushing the switch in a few times.
Posted on Oct 26, 2008
  • 2 more comments
  • Ron Coons
    Ron Coons Oct 26, 2008
    shhhh. heres a little trick, dont know why it happens, but ive never had a faulty switch,. turn off the power supply, the switch itself pops out fron the front of the unit, witha small screw driver pry from the side if the switch as if you WERE gonna change it, as you twist and torque the switch out it will generally "pop" out and start tot operate again ( youll here it "clicking" as you depress it) without even pulling it completely from holder or replacing. at least thats how its always worked for my, worth a shot
  • Christine Custodio Nov 23, 2011
    THANK YOU! I just happen to find your "little trick" solution as I have been looking for a solution to fix my dryer. I popped out the switch, twisted and jimmied it until I heard a "pop" and the dryer started to work again!! My dryer was down for 5 days and your fix took less than 2 mintues! THANKS YOU!!
  • Elena May 27, 2013
    Thank you Ronald you saved me money
  • ashley
    ashley Mar 14, 2014
    That did the trick Ron. Thank you! We were getting ready to pull the entire dryer out to try to unplug it! Thank God I found your comment via Google search. The gray pop out button in the lower right hand corner when you open the door was working as it was supposed to, but I pushed it in and out a few times and wiggled it around just in case. Closed the door and low and behold the dryer came back on. Praise Jesus, because I have about 8 loads of laundry to do today.
Thank you, thank you, thank you! It worked for me too!
Posted on Jul 14, 2012
Dryer won't start, push the start button it just beeps
It is possible you have a broken drum belt. You may need to call a qualified service man as changing a belt can be tricky.
Oct 01, 2015 | Whirlpool Duet WED9550WW 27" Electric...
Kitchen aid gas dryer lights up but won't start
What is the model number? Look inside the door jamb.
Oct 19, 2012 | Whirlpool GEX9868J Electric Dryer
Cycle light flashing. won't let it start. when i hit start button it beeps 2 times quickly
Very common issue, check the door switch when you press it in you should hear a click, If you have a volt meter we can walk you through this repair.
http://www.appliancerepairlesson.com/
Mar 01, 2011 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Start button will not initiate on cycle. Get 3 beeps.
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jun 20, 2010 | Whirlpool GEW9250 Electric Dryer
Can not get my dryer to turn on
There is a set of instructions available at www.AnyoneCanFixIt.com for this problem. Specifically at:
http://www.anyonecanfixit.com/household.htm
It's a quick and easy fix.
Aug 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dryer won't start when start button is pressed and held
check door "close"contact button/switch usually the culprit..
Aug 02, 2009 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Beeps but doesn't start
Duet dry lights up, hit the start button and it just beeps and lights flash. but will not start.
Mar 01, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool Duet Dryer WED9600 Beeping during drying
Dear Customer
Please perform the following
please rate this,thank u
Dec 16, 2008 | Whirlpool GEW9250 Electric Dryer
Blinking light cycle won't start
sounds as if you have a bad door latch assy, the unit is not recognizing the door closed, so when the button depressed probly only beeps 3 times at you. check the lock/latch for an obvious broken part
Nov 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Duet Dryer will not start, Press control on, Start, then it beeps
try tripping your circet breakers dont assume that just because it lights up both lines are working you can have a partial tripped breaker and just be getting 110 to the drier its easy enough to just go ahead and reset the breakere if that dont work get back to me
Dec 08, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GEW9250 Electric Dryer Logo
1,523 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
