Question about Sony SLV-685HF VHS VCR
Vcr does not run
I HOOKED UP MY RECENTLY PURCHASED USED SONY VCR MODEL# SLV-685HF TO MY JVC TV AND TUNED IT TO CHANNEL 3. WHEN I TURN ON THE SONY VCR REMOTE MODEL # V203A, BY PRESSING THE POWER BUTTON, THE VCR TURNS ON, THE POWER LIGHT GOES ON. BUT NOTHING ELSE WORKS. I.E.,I CANNOT CHANGE CHANNELS ON THE VCR, BUT I CAN CHANGE THE CHANNELS OTHE TV. I DO NOT HAVE A USER MANUAL FOR THE VCR. WHAT AM I DOING WRONG?
THANK YOU
    President:
  • 2,712 Answers
Try changing the channels on the VCR itself. If you can do that, then it would indicate a problem with the VCR's remote. If you are still unable to change channels on the VCR manually, it could indicate a circuitry problem, for which you will have to get the VCR serviced.
Posted on Oct 26, 2008
How do i set up my tv with my sony vcr
Hi Katie.. If you are using a coaxial cable to connect your TV and VCR, the TV needs to be tuned to channel 3 or 4. If you are using the Yellow, red and white cables, your TV should be on video mode to work.
Sep 14, 2015 | Toshiba 24AF42 24" TV
Sony SLV-775HF issue (power off, freeze, digital cable related?)
These guys have the owners manual and the service manual for your exact model; http://www.user-manuals.com/advanced_search_result.php?keywords=sony+SLV-775HF+manual&forward=plist&osCsid=a4cf756dbc2b6f254269ca22308687e5 Sorry I haven't been able to locate these for free anywhere, Sony do not have them available online. Here is the link to the Wow cable instructions - i couldn't find much in there but you may see something that helps out, check pages 65-67 to be sure you have everything hooked up right; http://www1.wowway.com/cable/pdf/WOWGuide.pdf Here is the link to the user manual for the explorer 3200; http://www.scientificatlanta.com/products/consumers/new_explorer2200.htm and here for the FAQs; http://www.scientificatlanta.com/products/consumers/FAQs.htm Hope this helps, if you get some more ideas but still no solution, please post back and i can try again :)"
Jan 28, 2007 | Sony SLV-775HF VCR
We have an antenna. Can't get Ch 3 on this tv to use our vcr/cd.
If you did a channel scan to build the channel list, the up/down channel will never bring you to 03, but you should be able to manually add the channel through the on screen menu system.
Alternately, simply punching in 03 (or 003) on the remote should force the TV to tune in channel 3.
Be sure the vcr is tuned to channel 3 as well, some are 3/4 switchable and default to channel 4 not 3.
A last resort if you can't get any of those to work is to get a cable splitter and run it in reverse with the 2 ended side going to the antenna and vcr and the single side going to the TV and doing another channel scan while the vcr is playing.
If none of these work, I'd need to know more about exactly how everything is hooked up.
ie - if the VCR is hooked into the component input on the TV, you need to switch the TV to A/V or composite or component rather than channel 3 etc. etc.
Mar 18, 2011 | Westinghouse SK-32H240S Television
Have Sony VCR model SLV-N80/N70 . Cannot get it to record using Samsung TV model SLV-N80,N70.
The television has nothing to do with recording. It is only required for playback. There are a number of possibilities depending on what equipment you have. Do you have cable, satellite, antenna? Your signal source has to be connected to the VCR either through the cable connector, or RCA video jacks.
If you have straight cable, connect the cable to the "ant in" connector on the VCR. The VCRs tuner will select the channel you want to record. If you are on antenna, you will need a Digital set top box (STB) to receive any channels.
If you have a satellite, cable box or digital STB, you must go from the output of the box to the input of the VCR. You can use the standard coax cable,but I would recommend using the audio/video cables for better quality. If using coax, the VCR will have to be set to either channel 3 or 4, depending on the boxes output setting. Using A/V jacks, the VCR will be set to "Line" or "Video" input.
Feb 26, 2011 | Sony SLV-N70 VHS VCR
I can not figure out how to change the time with my TV being hooked to a converter box with the VCR Sony N-50. Not to mention, I can't get it to show the picture. I think if I could see the picture I could...
See this web page:
http://sites.google.com/site/columbiaisax/diagram_dtv_tv_vcr.htm
for an explanation.
The TV converter box connects to the VCR and the VCR connects to the TV. Be sure you set the TV on channel 3 (or 4) if using a coax cable connection.
Jan 11, 2011 | Sony SLV-N50 VHS VCR
Where can I get a remote control for the Sony VHS SLV 685HS?
You can get a duplicate of the original remote (new or used) here: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=SLV-685HF&uuid=12875134515770 for the 685HF. I can not find the SLV 685HS is not a valid model that I can find at either Sony Parts or Remotes.com.
However, a refurbished remote for the SLV685HS is listed at: http://www.replacementremotes.com/SONY/Buy-RMT-V231A-RMTV231A-147555321-Video-Remote-Control.html . (E-bay also lists a few remotes for th SLV685HS; these listings may or may not still be valid.)
I hope this helps.
Oct 19, 2010 | Sony SLV-685HF VHS VCR
Want to record a television program on a channel higher than 16.
there must be a setup feature on the sony for channels that you get in your area?
Dec 18, 2009 | Sony SLV-D370P DVD Player/VCR
Sharp VCR hooked up to cable tv, i/p to vcr then out to tv.
I believe that I have the solution to that problem... When you are hooked up to cable or dish and use a VCR, you MUST have the program you wish to tape playing on the Cable or dish program, therefore the VCR needs to be tuned to channel 3 or 4 {whichever is the unused channel in your area) I believe that all you have to do is make sure that the TV is tuned to the channel you wish to tape and program the VCR to Channel 3 (at my area) or channel 4.
I hope this works for you. I have VCRs hooked up to all my sets and this is how mine work.
annabanana
Jan 23, 2009 | Televison & Video
Recording
First make sure you are hooked up in back. You can go either way. Cable out to tv, Cable or RF in from antenna should be from what you are using like cable, satellite, or just antenna. Then you should have set put on channel 3 or 4 and you can switch that in back of VCR also. Then if you don't see picture on screen with vcr on then find channel that you are coming in on like for satellite you need it to be on 3 or 4, cable you can just put it on the channel you want to record. The other way are from Video Jacks the red, white, yellow. If this is the way you are hooked in then you should look for video 1, 2 or which ever you are hooked into and find on set. then look on vcr for video or aux 1, 2 or depending on the one you are hooked in to. Hope this helps. If not then tell what you are using and what you have done so far!
Aug 16, 2007 | Sony SLV-998HF VHS VCR
Televison & Video Logo
444 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
