Question about Garland Kitchen Ranges
Adjusting pilot flame on Garland G286 Range.
I have a Garland Range G286. I always thought the oven pilot burned too high so I had a serviceman lower it during a recent visit. Now the thermocouple doesn't stay hot enough to keep the pilot lit. How can I adjust the size of the oven pilot flame on this model?
2 Suggested Answers
  • 3 Answers
SOURCE: I have a Garland stove series #G286, the oven won't stay lit.
it sounds like a venting problem, the oven heats up and it not venting,it will put the pilot out.
Posted on Oct 16, 2009
Aug 27, 2009 | Garland H286 Gas Kitchen Range
Every couple of days the pilot light goes out.
Hello. It sounds like you are able to relight it, and all is good till the next time. I would suggest replacing the thermocouple for the oven, and cleaning the pilot. The pilot is probably dirty, they draw dust into them while burning, and thermocouples are reasonably priced. You could be having a problem with your pilot safety, the part with the red button that you push to relight the pilot, however it is easier, and cheaper to get a new t'couple,and clean the pilot first.
You can go to: www.garland-group.com or call them for parts 1.800.424.2411. There are many part suppliers online that can get what you need.
Hope that helps, and thank you.
Feb 04, 2009 | Garland H286 Gas Kitchen Range
When Oven turns off so does oven pilot
Hi there, it is possible of the pilot being too close, but usually does not have that effect, unless the pilot is too small. But if you replaced the pilot, it should be clean, so next I would look at the gas pressure, if this is too low, the flame won't have proper burning speed, and strength, and could get drawn out. The control valve may be of the type that has a regulator built in, you may need someone skilled at gas pressure measuring, to do this, your gas supplier, appliance professional, plumber, should be able to do this.
Let us know, and thank you.
Jan 29, 2009 | Garland GPD-60-2 Gas Double Oven
Ovens won't work.. pilot safeties keep dying..
Hi, just wanted to ask, are you sure the safety valves are bad? seems strange that 2 would go bad like that. I have seen thermocouples ( $7 to $12 ) improperly installed,routed, not an OEM part,dirty pilots, affect them alot more often than a bad safety ($150 to $250). There is no baffle plate behind the safety, however, if mounted properly, it should be well out of any heat range that would be causing any problems. Are you sure it isn't "front venting" ? meaning the exhaust, or part of it, has to escape out of the front of the unit, causing it to overheat? this can be caused by a few things, something blocking,covering,in the flue. Your gas pressure too high, or no regulator at all, sooting, clogged orfice causing gas to burn in the burner, alignment of orfice to burner, etc.. Hope all that helps, let us know :)
Dec 31, 2008 | Garland H283 Gas Kitchen Range
Garland stove oven pilot light does not stay lit
If there is any adjustment, it would be a small screw on the oven control accessible with the oven control knob removed. This adjustment affects the size of the top burner pilots, but I'm not sure about the oven. The oven pilot orifice may have an obstruction, or if the flame is actually normal size where it covers the thermocouple when it burns, you may have a thermocouple problem.
Dec 22, 2008 | Garland H283 Gas Kitchen Range
Garland Range
You may need to hold the red button for a couple minutes...
Apr 23, 2008 | Garland H284-24G Kitchen Range
Commericial stove oven problems
the end of the thermo coupling needs to be in the flame of the pilot light
Apr 22, 2008 | Garland H283 Gas Kitchen Range
Garland stove pilot light problem, again but different
I'm not familiar with Garlands. When I run into a similar problem with other stoves of that vintage (Wedgewoods, etc.) I trace the pilot lines piece by piece, from the manifold to the pilot burner, if necessary opening a connection or two to see where I'm getting gas and where I'm not.
Is there a needle valve for adjusting the pilot flame? Is there gas getting all the way to the pilot burner? When it's the pilot burner itself that's the problem, I take it apart, brush/blow/shake out the crud, and run a small drill (#79 or so) through the orifice.
Dec 19, 2007 | Garland H283 Gas Kitchen Range
Oven pilot light will not stay lit on Garland 6 burner, double stove, salamander commercial in home
Use a needle right where the pilot flame comes out. Should do the trick. GOODLUCK!!
Dec 16, 2007 | Garland H283 Gas Kitchen Range
Oven pilot light won't light
It is usually a bad thermocouple. Mine had only had a weak pilot flame and the problem turned out to be a corroded and leaking pilot gas line. It was leaking whee it enters at the bottom of the oven chamber.
Mar 05, 2007 | Garland H286 Gas Kitchen Range
Kitchen Ranges Logo
32 people viewed this question
Top Garland Kitchen Ranges Experts
John Tripp
John Tripp
joneable
Level 1 Expert
Are you a Garland Kitchen Range Expert? Answer questions, earn points and help others
