Question about Mitsubishi WD-52725 52". Rear Projection HDTV
Ballast 52725 fix
How do I fix the ballast on my mits 52725?
  • 927 Answers
Good Day;
Replace it if that's your problem. Good Luck, big IRISH.
Posted on Nov 03, 2008
I have a Mitsubishi WD-52725 Projection TV. I
Call MITS, and try to get a tech to assist. Green timer flashing is "waiting for CPU to boot". Normally 70 seconds after plug-in. If doesn't stop, then not booting, and you won't be able to turn on. It only boots after being unplugged.
Apr 22, 2010 | Televison & Video
Mits WD52725 DM Board
Dan,
I would causion removing the DM board in this unit. It is buried and the real problem is that there is many capasitors across all the boards of the chassi assy that could go bad. Replacing the ones on the DM will not guarantee fixing the dreadful green Blinking
LED. The only way I have known it to be fixed properly is to actually send the chassi assy. to Mitsubishi for them to refurb it. The negitive thing is that it is exspensive and they will only refurb it through aAuthorized Misubishi Repair Facility.
Cost would probly be around 800.00 to 900.00.
I know it is not what you wanted to hear,
but that is mt take on it.
Hope this helps,
Skyassoc
But it is the
Jun 01, 2009 | Mitsubishi WD-52725 52". Rear Projection...
You can find any of the PC Boards for Mitsubishi TVs at Discount Merchant.com for 69 dollars
May 29, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Timer light blinking green
you need the repair kit for the DM you can get the kit at the following link whic contains the capacitors and step by step instructions on how to do the repair
http://servicemanuals.vstore.ca/product_info.php/pName/v26-dlp-dm-pwb-repair-kit/cName/repair-kits
May 23, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Need DM or FMT PC board
If the front light of the TV is blinking green suspect caps are bad and change them yourself, google for cap locations
Nov 21, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Mits diamond vision 65
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Dec 26, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Sound but no picture on my HD-52725 (slightly over 1 yr old). The TV menu DOES come up but other than that, it's just a blank screen. I replaced the lamp about 3 weeks ago. It was working fine yesterday...
The new bulb that went bad I purchased for less than $130.00 from http://www.Discount-Merchant.com/ . When I called them they immediatly sent me a new bulb free. Their number is 1-619-710-2637. A very good coumpany to do business with. They are also considering selling ballast for dlp TV's for around $200.00. The TV repair place that I have been going to told me that maybe the ballast made the bulb go out and it would cost between $600.00 and 800.00 to have them fix it. My TV is a Mitsubishi WD52725. dodger1
Nov 20, 2006 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
49 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
