Question about DeLonghi ESAM 5500M
How do you grease a delonghi esam 5500
Had the machine for 8 months and need to know how to grease the brewing unit
SOURCE: Delonghi dcm 485 power on but will not brew
My dcm485 turns on but won't brew coffee and it is not that it needs cleaning. On mine, this component has failed:
http://www.datasheetcatalog.com/datasheets_pdf/S/F/2/2/SF226E.shtml
Bypassing this part allows you to make coffee - but its likely that the pot will overheat, melt and catch fire without it (unless you stand there and manually turn off the pot as soon as its finished).
Also, this may have failed because another part failed.
Posted on Mar 18, 2008
EwingElect
  • 276 Answers
SOURCE: Dear Sir, Do you know where I could download an
Hi. If you have not yet had any success, try http://www.delonghi.com.au/support/instruction_manuals/EAM_series.pdf
Posted on May 25, 2010
Testimonial: "Great Service, just what I needed !Many Thanks"
SOURCE: descaling a delonghi magnifica ESAm04
I had this problem too. The instruction manual says to turn the steam knob only half way counter-clockwise after pressing the button for 5 seconds, but you need to turn it ALL the way to have the procedure start (at least, that was the solution with my machine). Good luck!
Posted on Jul 08, 2010
SOURCE: hello i have an Delonghi esam
I had this problem until I realised that you need to switch the machine off by pressing the on/off button on the front of the machine first *before* switching it off at the back and unplugging it. This moves the infuser unit further to the bottom and then allows you to take it out.
Posted on Nov 11, 2010
SOURCE: delonghi perfecto esam 5400 instruction manual. I
A small stone got pretty stuck in the grinder of my Delonghi esam 5400. Anyone knows how to remove it?
Posted on Mar 22, 2011
DELONGHI ESAM 5500 WON'T MAKE CAPPUCCINO SAYS GRINDS TOO FINE, BUT WILL GRIND AND MAKE REGULAR COFFEE
have you tried cleaning it as described in your user manual,, can you hit the button for regular grind? there are alternatives, a coffee grinder if failry cheap at 10 dollars US,,
Jun 07, 2016 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Delonghi ESAM 5500 no hot water/milk just says "Heating Up, Please Wait"
Apparently the heating element has gone to that place where they can not be fixed .
Nov 25, 2015 | DeLonghi Coffee Makers & Espresso Machines
Press clean button error message on delonghi ESAM 5500
Hi Susanah
my deLonghi also wants a clean now and then. In your situation I Would disconnect the machine, wait awhile then connect again and see if she still wants a bath or it is an error .
good luck
kolbrun
ps there is always the troubleshooting page in the manual,
Aug 12, 2015 | DeLonghi ESAM5500
Delonghi 3500s coffee machine not producing hot water or steam from water outlet/milk frother
Hey Everyone,
I had this exact same problem.
Check out my video of how to fix it.
Video: https://youtu.be/_SbGiD4LeCc
Hope it helps!
Jun 25, 2014 | Coffee Makers & Espresso Machines
While Brewing Bin Full Lights Came On
Check the housing where the bin sits is clean and free of coffee and other debris
Apr 18, 2014 | DeLonghi Coffee Makers & Espresso Machines
Sometimes the pucks do not fall into removable container. How do I fix this?
Make sure the swinging arm at the top of the brew unit moves easily. Check nothing on the brew unit is damaged. Servicing the brew unit might help.
Brew Unit
The transmission can wear out prematurely due to the brew unit becoming stiff. The piston in the brew unit should move smoothly and fairly easily. Keep the brew unit in good service by occasionally removing the piston to clean and re-grease the two big red o-rings using a food-safe grease. To pop the piston out the top, gently remove the plastic u-clip from the base of the shaft underneath, paying attention to which way up it goes for reassembly.
Jan 22, 2012 | DeLonghi Esclusivo Magnifica ESAM3300...
DeLonghi ESAM 5500M Logo
83 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
