Question about Yamaha Televison & Video
Ymaha DVD-C750 won't open
Put in a disc. Won't play; now can't open to get out the disc. Tired unpluging and repluging. Doesn't fix the problem. What do I do now?
AJIN G
  • 6694 Answers
SOURCE: My disc tray won't open
hi,
You have to check two things.
1. You have to check the tray loading belt in the mechanism. To see the same you should remove the mechanism.because the loading belt is beneath the cd tray. As it is cyberhome it will be very difficult to remove the mechanism for an user. if your capable for doing the same then make try. Because you have to remove the top cover then the back panel, then the mechanism. Take care the mother board is attached to the mechanism.
2. You have to check the cyberhome dvd player will show this type of complaint if the Spindle motor is faulty (oppen or short ). Spindle motor is one on which the cd rotates. It will not cost a lot.
ok
Posted on May 05, 2011
Demonic-2011
  • 508 Answers
SOURCE: I have a soniq b100 disc player, which only
Sorry, no there isn't much you can do at a consumer level with this player, except, if you still have a manufacturer's warranty, taking advantage of it and sending the unit back for warranty repair/replacement (whichever they suggest to you). It is clearly malfunctioning, beyond user control - send it back as a warranty claim (if you still have one on this model). It won't cost you in repairs that way.
Don't put up with a defective product, send it back - get it fixed under warranty free of charge (if applicable), or the unit replaced (again, if under warranty, free).
It won't cost hundreds of dollars and shouldn't take forever to resolve this simple case. Good luck. This is something the manufacturer should worry about; not you.
Posted on May 06, 2011
  • 11 Answers
SOURCE: We have a Panasonic Blu
It sounds like the bluray laser is worn out. Try cleaning the lens with a Blu-ray lens cleaner. If that dosen't help it might be the blu-ray laser it self. The laser is dead. If you are under warranty the call the manufacture for service. Shop around for current retail prices. Bluray players have gone down alot and it might be better to go ahead a buy a new player.
Posted on May 24, 2011
  • 411 Answers
SOURCE: I just purchased new blank Maxell dvd-rw
Get a CD/DVD laser lens cleaner - the kind with optical quality brushes sticking out of the bottom of the disk. Run this in the player/recorder a couple times. Should clear it up.
You can get them at Best Buy, Radio Shack, online, etc...
Posted on Jun 16, 2011
alpug
  • 1961 Answers
SOURCE: was working fine, suddenly anytime
Hello Sir!
May I ask you first, is the disk that you're trying to play are the same disk that you played before with the same player and works fine? IF yes, then that is a lens problem.
You can clean the lens first with a cotton buds moisten with an alcohol and gently wipe it on the lens.
But first, you will need to take the cover off to access the laser lens.
T
here is a ribbon wire that connects between the mainboard and the pick up lens (optical lens) when cleaning of the lens did not solve the problem, try examining the ribbon connector make sure this ribbon is properly fitted to the terminal socket try detaching the connector and re insert it. If still it did not work then you have to replace the spindle motor.This motor is the one spinning the disk. Once this motor is faulty there will be no reading from the disk....
The part no. of the motor is printed on the motor sticker(surface) good luck!
Posted on Jul 29, 2011
Magnavox ZC320MW8 door stays open
f the tray won't open or close properly, check the belt for dirt or wear. Then check the tray for misalignment. If needed, remove, clean, lubricate, and reinstall the tray following the instructions in the owner's manual.
God bless you
Sep 27, 2012 | Magnavox ZC320MW8 DVD Recorder Refurbished
I can't get my DVD disc to eject. It will play but won't eject? Any suggestions
You should try unplugging the DVD player from its power source then plugging it back in. Now try to open it and if that doesn't work than you'll probraly have to take it apart to get the disk out but sometimes the DVD players can get worn out or if you have a cheaper DVD player it might just be freezing up on you. I have had these problems before. I just took the DVD player apart to get my disk and then trashed it.
Jan 23, 2012 | GoVideo DV2150 DVD Player/VCR
Compact Disc rewritable DVD player won't load or play
Check the data connector on the rear of the drive. If this doesn't work you may need a new drive, they are cheap and readily available.
Jan 19, 2012 | Lenovo Computers & Internet
Getting a C 13 70 disc is dirty message only for DVDs that I'e burned recently. I bought a new pack of blank DVDs, the same kind I've always used, but every movie I burn on these new ones, they...
Hello, welcome to Fixya!
Was this player playing previously? And how long have you been using this player? I suspect the lens of the player. Once the lens of the player becomes weak, it won't play discs any longer.
The first thing my mind goes to, is the lens. The lens id responsible for reading/loading data on discs. So if the lens is unable to read the disc, there is no way the player is going to play the disc.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or probably, a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Good luck.
Nov 03, 2011 | Sony DVP-SR200P DVD Player
Won't read d d keeps saying bad disk
Good luck.
Oct 05, 2011 | Curtis DVD1041 Player
Sony RDR-GX360 won't respond to any buttons on unit or remote. Only function that works is power button. Disk tray won't even open.
Try unplug,replug the unit back like about an hour later for the unit for resetting itself back to factory setting.If getting the same result the unit might have a shorted motor drive for the disc tray.Or shorted control panel on the unit itself.Well,this thing a basic DVD player only wright?If u can tries take it aparts and check out tries to repair it ur self that great.If u tries the shops,not worth it.Trash it.These basic DVD player only are very cheap now.U can get one brand new like $40 dollars.
Aug 11, 2011 | Sony DVP-S360D DVD Player
When i put in a dvd into my player, it says no disc, and won't play, when it does accept the disc, it doesn't play it, then a "C:13:00" starts blinking. I should be able to just put in a...
It's most likely dirty, though it could be failing. The lasers have an average life span of 3 years, under normal use.
Several companies make CD/DVD laser lens cleaners. You want the kind with optical quality brushes on the bottom side. You simply put it in, let is spin up and play, then take it out. It may not play the first couple times you put it in, but it will be cleaning the lens and pickups.
If that doesn't do it, I'd start looking at sales for a new player.
Jul 05, 2011 | Sony Televison & Video
Mum tried to play computer disc in my all-in-one tv/dvd player!now it buzzes but won`t open...help?!
Unplug from wall and let the reset action take over. Replug and see if that will eject the disk
please leave feedback
Feb 21, 2011 | Televison & Video
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Televison & Video Logo
56 people viewed this question
Top Yamaha Televison & Video Experts
Larry Stiles
Larry Stiles
 Grubhead
Grubhead
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
