Question about TruTech PLV16320 Television
Trutech LCD TV 32"
My picture will become lighter, as though someone just changed the picture setting, and then darker. It will do this about every 5 minutes. The change is almost instant, as though someone just pushed the "picture" button. The button changes the setting from light, to natural, to soft, to custom.
  • 814 Answers
This problem could be a problem with the control board which is the master control for all of these functions. It could also be a problem with the power inverter board becoming intermittent in its operations. The back light could also be having a problem. You can call Tru tech customer service at these numbers. 1-888-252-6252 and 1-800-252-6123. I hope this helps you with your problem.
Posted on May 17, 2009
Update tv
Go to settings on the TV menu. It should be under picture and you can change the picture mode and auto dimming setting from ON to OFF...if you want to do an update.. then go to Sonys website .. key in your model number ..look for firmware updates then download this file onto a formatted USB flash drive.. remove and insert into TV and when turned on the set should pick up the update automactiaclly
Jan 09, 2014 | Sony BRAVIA KDL-32S5100 32 in. LCD HDTV
Black screen
Check its back-light inverter and back-light CCFL lamps.
Jul 12, 2013 | Sceptre X32BV-Naga 32 in. LCD TV
My mitsubishi 72 inch tv has gotten a very dark picture. What can I do to fix this?
adjust the color go to the menu and change the color meter to darker or lighter and your welcome
Nov 05, 2012 | Mitsubishi Televison & Video
My LG TV has suddenly become darker all across the bottom of the screen (10cm strip) it still has colour but is darker. In left hand corner it is considerably darker and depending on what you are watching...
Hi; your TV has burn screen or comes from one image left on the screen for too long, it can get burned into the screen, making it visible at all times. You can actually eliminate most screen burns with the use of a PC computer and a black and white screen saver. This trick eliminates screen burn after a period of several minutes because the black and white screens flash quickly, removing all traces of color from the screen. This will eventually eliminate any burned images on the LCD screen. you can do it by creating a DVD picture slide with only black and white image. you can use a computer to make DVD picture slide first go to paint brush and draw only white then save as white.jpg. second burn it into nero or other dvd burner third play it to your DVD player connected to you LCD has to be played in full screen let the white image display on your HDTV for several hours or even overnight. It should remove any burned-in images or ghosts. hope this help...............
Sep 13, 2011 | LG 32LD350 32 in. LCD TV
Short crackle sound emits from speaker during scene changes
Actually, it is a failing component. Quick scene changes often place demands on the power supply. I would guess that the noise is more prevelant when the scenes change from darker ones to lighter ones. Since this set is so new, request a warranty exchange. This set needs to be serviced. Return it to the place of purchase and ask for a replacement. Usually if the set is less than 30 days old, they just exchange it for you.
Oct 08, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Picture has become progressively dark 27'' TV JVC AV-27320
disgaussing will not help this problem..i am scared your picture tube problem or try to change the crt socket first it is not cost much
Jul 01, 2009 | Televison & Video
Dvd picture is darker than tv picture
Most sets have electronic service adjustments. Contact manufacture for nearest service center.
Mar 06, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
"melting" screen image
the problem is the backlight not lit evenly.
have the backlight inverter board checked for correct ac ht and if that is okay then u will have to replace the backlight.
Jul 10, 2008 | Polaroid Televison & Video
LG LCD Tv picture goes black but the sound still works
Next time it goes dark do a flash light test to see if your inverter board is fubar.
May 03, 2017 | LG M4200C 42 in. HDTV-Ready LCD Television
Strange picture issues
check near lineoutput transformer low value resistor eiher open circuit or high needs technician
Mar 18, 2007 | Samsung DynaFlat TX-P3064W 30" TV
TruTech PLV16320 Television Logo
48 people viewed this question
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
