Question about Meade ETX-90EC (325 x 90mm) Telescope
Won't move vertically
I replaced the right vertical adapter but it is still not working. The motor is running but it will not go vertical. Any suggestions?
    Problem Solver:
  • 15 Answers
Make sure the DEC clutch is tight enough.
Posted on Nov 05, 2009
Ds2130at vertical motor blue print schematic
Only Meade would have this information. Contact their customer service here:
http://www.meade.com/support/index.html
or they have a repair service--but they want the scope returned to them for repair.
Nov 26, 2011 | Meade DS-2060 (175 x 60mm) Telescope
I was given a Meade DS2130 reflector. Everything seems to work fine except the scope doesn't move in Altitude. The motor works fine and the white horizontal worm gear and vertical white gear turn...
ONLY Meade will have parts-- usually they want you to return the mount to them for repair-- call them here:
www.telescopeman.org
www.telescopeman.us
Aug 28, 2011 | Optics
Meade DS-2114S, can not get the vertical, up/down movement to work when using the autostar mode, can hear the motor drive working but no movement, the left / right moves fine, and the up / down moves fine...
The knob on the fork arm is tightened? Correct. You can slew manually, but cannot do a two star alignment?
Is all of this correct? Post a reply with additional information.
You have trained the drives -- correct?
Dec 22, 2010 | Meade TeleStar DS-2114ATSA Telescope
Motor tries but cannot move on the horizontal. Moves fine on the vertical. Usage only in Alt/Az mode. Only have the electronic controller that came with the scope.
You did tighten the AZ clutch? You did start from the HOME position? (turn the scope Counterclockwise to the hard stop)
Then you will either have to send it back to Meade for repairs, or open the bottom of the base, and look inside and see if the AZ worm gear is actually meshing with the motor. It could have come loose.
Meade customer service:
Oct 08, 2010 | Meade ETX-125EC (500 x 127mm) Telescope
Bought the scope about 4 years ago. Fairly light use and not used in last 12 months. Was checking it recently and replaced batteries etc. Horizontal motor movement is fine however no vertical motor...
Do a RESET on the hand controller. Re-enter Time, Date, and SITE, and CALIBRATE motors.
Also sometimes a bad hand controller cable will cause this. You can buy another cable directly from Meade. Call them here:
Aug 16, 2010 | Meade ETX-125EC (500 x 127mm) Telescope
I took apart the vertical support arm and need to insure that I am putting it back together properly as it will not currently move vertically, horizontal is ok
Here is the manual-
http://www.meade.com/manuals/TelescopeManuals/Reflectors/DS2000%20manual.pdf
If the motor does not work it can indicate-
A broken wire inside
A broken altitude motor
A broken motor control circuit board
Only the first one listed above can be fixed by you. The scope must be returned to Meade for either motor or electronic repairs.
Here is Meade's customer service web site:
Jun 27, 2010 | Meade DS-2114 ATS (325 x 114mm) Telescope
MEADE ETX 125 Motors have stopped
The ETX125 is notorious for bad motor control. Weasner's Mighty ETX web site has links to repair centers that are more reasonable than Meade. They also have a QA section to assist with diagnostics.
Jul 23, 2009 | Meade ETX-125EC (500 x 127mm) Telescope
Meade ETX-90EC (325 x 90mm) Telescope Logo
104 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Geoff
Rich Lewis
Are you a Meade Optic Expert? Answer questions, earn points and help others
