Question about Nikon D50 Digital Camera with 18-55mm Lens
Nikon d50 freezing and showing r49 on lcd display
My camera is freezing up and not allowing the auto ficus mode to operate and then the manual is not producing clear photos
  • Anonymous Feb 28, 2009
    I'm having a similar problem. I, too, get error message. I have tried everything. Just as I'm ready to take the perfect shot, it freezes! I zoom out, then in...sometimes remove the lens completely, and that sometimes works! I wonder if sometimes I'm too close to the subject. Seems to be something with the focus??? I have a 28-300 Tamron zoom.
SOURCE: Nikon D50 LCD Display does not work
NatD, The D50 and indeed most SLR digital cameras [ I have a D40 ] does not allow you to take pictures using the LCD display ... this is by design, you are meant to use the viewfinder and the image you see through it is straight through the lens via a mirror block [ called a reflex pentamirror or prism ]. When the mirror is down such that you can see the image in the viewfinder it is obscuring the sensor [ the bit that takes the picture ] and when you take a shot the mirror lifts and the picture is recorded. Its this reason that DSLR's dont use the LCD to shoot, however there are a few now available that do let you do this, such as olympus, new panasonic one and higher end Nikon and Canon cameras. Hope this explains it without getting too detailed!
Posted on Dec 06, 2007
markevans
  • 148 Answers
SOURCE: Auto bracketing on a nikon d50
no. if you want more than 3, you will have to manually bracket those beyond the initial three. alternately, you can get a reading for settings then change to manual and continually adjust your aperture setting from whatever under exposure level you want to whatever over exposure level you want.
mark
Posted on Dec 22, 2007
SOURCE: Nikon CoolPix Flash Problem
This happened to me too!
Turn the dial to setup, push the menu button & select reset all. This will restore the defaults & let you use the flash again.
Posted on Mar 21, 2008
  • 48 Answers
SOURCE: nikon d50 highlights problem
That's the overexposed highlights display, to warn you when highlight details may be lost. Disable it by pressing the up arrow twice. First press shows you the histogram, second press shows pic only, no other info. It will remember this setting for all photos display (until you change it).
Posted on Feb 07, 2009
SOURCE: Nikon D50 flash not synchronizing
Ok this is a crappy fix but it works for me.
If your flash isn't syncing correctly make sure your on auto flash. when your flash flips up and you get the beep push the piece that holds the flash just a little forward. and walla your flash syncs up.
Posted on Feb 12, 2009
Nikon D50 displays code R14
I wouldn't suggest scrubbing your lens too hard with alcohol as that might damage it. What you're looking for is probably a full reset of the D50 camera, you can find instructions on how to do that here: Nikon D50 user manual
Aug 03, 2016 | Nikon D50 Digital Camera
Nikon D50 will not autofocus, the menue item 02 Autofocus is no highlighed and I can not set it
You should check two switches.
First, on your lens, be sure it's set to M/MA not M. That puts the lens in auto focus mode.
On the camera there should be a switch that shows C/S/M. If switched to M, it's on manual focus. Change this to S for single auto focus or C for continuous auto focus.
Jul 02, 2014 | Nikon D50 Digital Camera
My Nikon D50 in picture play back mode is giving pictures in multi colour not as pictures ?
I'm not sure what you mean by "multi-colour mode" but this page shows all of the possible playback display modes and describes them. Hopefully this helps you. I use a D7000 which is quite similar and I've never seen a multi-color mode. Nikon D50 SLR Review
Mar 23, 2014 | Nikon Cameras
Nikon D50 reads [-E-] in window not viewfinder and won't shoot.
This is the error code for having a lens with manual or auto aperature adjustment in manual mode with the camera in anything other than "M". You need to put the lens in the max aperature (usually it's red) and then move the small red switch to the red dot. I don't think anything else will give you this error.
Aug 25, 2009 | Nikon D50 Digital Camera
I want the on board flash to turn on manually
If you operate the camera in green Auto mode you don't control the flash, it controls you. Choose any other exposure mode (P is good if you normally use Auto) and the flash will only pop up when you press the release button on the side.
Dec 22, 2008 | Nikon D50 Digital Camera with 18-55mm Lens
Nikon D50 dropped and not working at all.
Put the lens on and try clicking on Manual mode with manual Focus
Oct 19, 2008 | Cameras
NO LCD display when shooting with brand new D40 ><
Most DSLRs (like the Nikon D50) don't have live view. In other words, in order to see the picture you must take it first.
About the auto review off, go to menu, "pencil" submenu, and the option is there (scroll until you see it)
With respect, you should read the manual. It's very comprehensive and needed. :)
Jan 04, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D50
Replace the button battery 1.5 voltsX2 your auto function will work properly.
Dec 29, 2007 | Nikon D50 Digital Camera with 18-55mm Lens
Dec 04, 2007 | Nikon D50 Digital Camera
Nikon D50 Digital Camera with 18-55mm Lens Logo
193 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
