Question about Canon Office Equipment & Supplies
Canon ir 210 xerox machine e0604 problem how to slove
SOURCE: SST FOR CANON IR 210
some one please help me for getting service support tool for canon ir 210 , for rewritting the hard disk and also pls suggest for rewritting the hard disk
Posted on Sep 25, 2008
SOURCE: canon ir 3300 xerox machine display board not working
dispaly and pad is not working who to open it tell me the codes
Posted on May 26, 2009
redzventures
  • 149 Answers
SOURCE: I have an IR-3300 Model xerox machine. It was
The two problems may not be related. Adding toner should not under most circumstances cause copies to become light, unless the toner you are using is of a poor quality - I hope it is a Canon cartridge or quality generic. It sounds as though your fixing film or drum unit may need replacing, or perhaps you need to perform a install procedure. As the 'install - toner - start' option is free, try it first:
First press the head key and then the number '2' and '8' keys at the same time then press the head key again. This will take you into service mode - select 'copier' then 'install' then 'toner' then 'start'. This will run throught a cycle that takes a little while, I think about 599 seconds (sorry for been so accurate but unhelpful but that's what I remember from the display - never converted into minutes but you're welcome to).
But if you are having blurry or even dirty or light copies it may be the fixing film. When the copies are printed, immediately check if you can rub off the toner at all by rubbing the print with your fingers - if so this indicates that the fixing unit is not hot enough or there is not enough pressure - check that the fuser is in properly and that the jam release lever is not engaged.
Lastly, it could be your drum unit that is faulty or worn. Totest this you will need to try and stop the machine in the middle of printing before it reaches the fuser - open the front cover and latch down the transport bed with the green handle - remove the paper gently so as not to disturb the ink in any way and observe the image quality - if it is displaying the exact same symptoms then it is not your fuser and is probably the drum unit or dodgy toner - most likely the drum. However, if the image is fine, then it most definetely is your fuser film (and or perhaps the cleaning roller that cleans the film).
Good luck
Posted on Jul 31, 2009
SOURCE: Describe your canon ir 400 xerox machine error
i have duplexing problem
Posted on Jan 11, 2010
SOURCE: sir, i have canon ir
witt...... 10minits leater e677 in display
Posted on Aug 31, 2010
How i fixes error code e000002 i change new fuesr unite but the error code is not remove pleas help how to solve?
http://www.copytechnet.com/forums/canon/5317-canon-ir-2200-error-code-e000002-0000-a.html
Aug 10, 2014 | Canon Ir 2525 Copier new
Machine canon ir 400s error E051
hi sir my xerox machine IR 400 the error code e220
May 12, 2012 | Canon imageRUNNER 400S Copier
CAnon xerox Machine IR 2318 L Error code : E 000007-0000
My canon ir 2318L shows error**E000007-0000 how can i solve this problem
Feb 28, 2011 | Office Equipment & Supplies
Canon ir 3300 machine error code 0064, plz suggest
CLEAN THE DUST & WASTAGE INK ON TRANSFER CARONA IN MACHINE & RESTART IT .
Dec 20, 2010 | Canon imageRUNNER 400S Copier
Not getting dry prints using canon 3300 xerox machine
1) is it canon ir 3300 machine?
2) if it is what does it mean NOT DRY completely?
#) My ques is that you need to eplace fixing film
Jan 30, 2010 | Canon imageRUNNER 2270 Copier
Canon ir 3300 xerox machine display board not working
Feb 13, 2009 | Canon Office Equipment & Supplies
Not sure what you are trying to do but try
canon.com (drivers and downloads)
or
driver.com
Aug 14, 2008 | Canon Office Equipment & Supplies
21 people viewed this question
old marine
old marine
