Question about Fahrenheat FUH5-4 Heater
Can you add a thermostat to a Fahrenheat FUH5-4 heater?
4 Suggested Answers
Buffalo12980
  • 625 Answers
SOURCE: fahrenheat wall unit
your on-off switch is faulty - need to replace it.
Posted on Dec 09, 2007
hotuna
  • 288 Answers
SOURCE: Electric baseboard heater
You need a meter, it will be hard without this! If you have 220v in the wall, then think of it like this; each wire is 120v. Test to each other, you get 220v. The thermostat is a double pole, you said. So think of it like this, its an adjustable temperature controlled switch that lets electricity through at the temp. you set it at. If you have 120v from one wire connected to one end of the element, and the other 120v connected to the other end of the element, then it will work. DO NOT CONNECT THE 120V TOGETHER. IT MUST GO THROUGH THE ELEMENT FIRST. The thermostat should be between the power from the wall and the element, to control the temperature.
Posted on Jan 09, 2008
  • 224 Answers
SOURCE: looking for bimetalic thermostat switch for the
My place of choice when purchasing for the warehouse is Grainger, if you have one close by. They usually have these items in stock or will get them for you quickly. Give them a try.
Posted on Dec 22, 2010
Bought a Fahrenheat 5' baseboard heater and a single pole thermostat to replace an old heater. What's the difference between a single and double pole thermostat? Which should I use? I have a 240v line...
Here is a link to the wiring instructions, which has detailed pictures and instructions. This should make it a lot easier. http://www.marleymep.com/en/multimedia-library/pdf/fahrenheat-pdf/products/f2500-series/F2500wiring.pdf
Feb 14, 2011 | Fahrenheat F2545 Electric Baseboard Heater
Where can i buy a thermostat for my heater fhu5-4b part # 5813-2050-000 Thanks Tom
Northern Tool sells ceiling mount Fahrenheat Heaters Try them, they may have it as an accessory or optional item.
Feb 09, 2011 | Fahrenheat Ceiling-Mount Industrial Heater...
My three pole switch burned out on the baseboard heater. Need replacement switch. Thanks
Representative from Fahrenheat contacted me and is mailing me the part
needed. Thanks for the web site.
Dec 23, 2009 | Fahrenheat Built-In Baseboard Thermostat...
Electric space heater contactor won't stay latched
Jumpered the bimetal thermostat and everything worked smoothly. Tried to clean contacts in thermostat with no luck, so ordered a replacement. At least it was cheaper than the contactor.
Dec 07, 2008 | Fahrenheat Ceiling-Mount Industrial Heater...
Add line thermostat to fahrenheat space heater
Just disconnect the other thermostat. You can leave it there just disconnet the wires
Nov 30, 2008 | Marley Electric Hydronic Baseboard Heater,...
Fahrenheat baseboard heater
no this is normal for this type of heater during its run time,I hope this makes you feek a little better!
Oct 24, 2008 | Fahrenheat Built-In Baseboard Thermostat...
Fahrenheat wall unit
Dec 07, 2007 | Fahrenheat ECP1524 Wall Mounted Panel...
How do I wire up my fahrenheat F25408 baseboar heater?
Baseboard heaters are easy to hitch up. You can have a wall mounted thermostat or an integral thermostat. The diagram I have is for the integral thermostat. Follow the diagram and it should work.
Nov 28, 2007 | Fahrenheat Electric Convector Baseboard...
Fahrenheat FUH5-4 Heater Logo
200 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
